Originally Posted By: JHZR2
NOACK values are necessary for an informed consumer to objectively assess the suitability of a lubricant for certain applications. It is clear that NOACK values are intrinsically not a proprietary value, given that at minimum, a "less than" value is invoked for certain specifications to be met, and other vendors clearly publicize the values in their product data sheets. It is well known that Pennzoil products offer superior NOACK values, based upon third party assessments. When can we expect to see reporting of actual NOACK values for all Pennzoil products, 0w-16 included?
Noack volatility numbers have been the only reason I began to use Pennzoil products, and with them no longer listed I am seeking other oils now. I know many others in the same camp. If a product is truly superior, would you not want to make it known to the informed consumer that is not affected by advertisement efforts?
