Chevy Silverado, Tire and Suspension question
An 05 Silverado we owned had 265/70/17's as OEM IIRC. We downsized at tire time to 245's. Ride was marginally improved.
Biggest improvement was from a set of Gabriel Ultras. An amazingly cheap shock with a great ride for all light and medium duty trucks.
Originally Posted By: glock19
OP, I think you know what you need to do. If you want the stock ride you need to go through the suspension components and tires to confirm everything is in good shape and as close to stock as possible.
Thats exactly what I am doing. 1) Removed aftermarket leveling kit. 2) New shocks 3) corrected all inflation pressures and 4) will replace with stock sized tires later.
