Originally Posted By: maxdustington
Originally Posted By: SilverSnake
I worked in the Marine industry for 7 years and have owned 11 boats myself. My opinion is that boat trailers in general are of extremely poor quality. Corrosion on components like nuts and bolts is common place especially for trailers put in salt water. I used to advise customers to spray down the questionable components of their boat trailers with S-100 Corrosion Protectant. It is a clear spray that will stop existing corrosion and prevent future corrosion. Use every time before launching your boat and you will not have a problem.
I think it is because they never really get a safety inspection and are not used enough by a non professional for bad quality to be obvious? You can clearly tell the pro grade utility/dump trailers around here from the scrub models. Here in Ontario only the truck needs a safety inspection annually for a GVWR of over 10k lbs I believe. My old man used to haul a dump trailer with his 2000 GMC G3500 and he sold that trailer when it started to rust because mini buns made more sense for him running a residential construction company. We also had to repair the wiring on the trailer for his jet ski in 2015 or so and it was a 2008 with low hours.
I know that a new cheap RV can be a real heap just from research I have done, but any piece of gear can turn to dust in the hands of a noob.
EDIT:
@Irv I would try a synthetic wood, or impregnate the wood with fibreglass resin. Pressure treated would also work but it is still wood and will rot at the end of the day.
Thanks guys.
When you say synthetic wood, are you talking about the newer wood that is now being used quite frequently for decks and the like?
I was thinking pressure treated would be a lot better than what is currently on the trailer (non pressure treated, I think?) Like my boat lift, I believe the biggest problem is the carpeting that wrapped around the whole piece of lumber, not just partially covered.
With my lift, when I replaced those boards with PT wood, I cut the carpeting so it only covered the necessary sections, or the top part where my boat rested rather than covering the whole board. (pic below)
It's been a few years now and I like the looks/feel a lot better. Imo, the wood is lasting longer so I think a combination of the PT and only covering what is necessary with the carpeting has certainly helped.
I may try the same with my trailer bunks but I will have to be extra careful to ensure I cover enough in case the bunk(s) tilt on me while under water or loading.
