Originally Posted By: wensteph
I'm all in with it. It will be my replacement for the '11 Touareg TDI I sold back to VW. Mid range diesel torque is like crack to me. I can't give it up.
The turbo eco gassers give you the same low/mid torque feel.
True. But I do tow, 5,000 to 6,000 lbs, and while a 2500 Duramax would be overkill, I think the new 1500 will somewhat match the ability of my Touareg. Similar curb weights, HP and TQ numbers with the VW having permanent AWD. I could tow at speed and get 12-14 with the VW. What I've been able to tell from an internet search is the Ecoboost would give 7-9. I put 173,000 miles on the 2011 Touareg so I certainly drive enough to get value out of the 'diesel premium'.
TLDR version is I like diesels.
The 2.8 diesel Colorado and Canyon would be a closer match for your Touareg. They have class leading towing when diesel equipped, rated at ~ 8k lbs. The ‘19 diesel 1500 will probably be rated around 11-12k lbs.
