Originally Posted By: bowlofturtle
I have one of these for the past 10 years.
The dual drain hole helps a LOT for cars the rush out oil at you. Most my cars are 4-6qts. This has a nice thick lip around it, only problem i can ever see is if the drain bolt fell inside ( has never happened to me on 30+ oil changes)
https://north40.com/midwest-can-9-quart-closed-top-oil-recovery-drain-pan-model-6601
Same here. I've use this one for many years.
