Adjusting Alternator Voltage
by George7941
19 minutes 51 seconds ago
what if i dont know what to use
by VTAK
26 minutes 33 seconds ago
Magnatec - intelligent molecules?
by PeterPolyol
29 minutes 0 seconds ago
Goodbye Encore, hello Soul!
by csandste
Today at 12:34 PM
7.3 drain plug torque
by mobilaltima
Today at 12:26 PM
'09 Kia Sedona - to change or not to change (oil)?
by Number_35
Today at 12:19 PM
I Think Spring Is Finally Here
by Warstud
Today at 11:48 AM
NAPA GOLD 7055 UN USED CUT OPEN
by car51
Today at 11:26 AM
Broken Cat
by Stelth
Today at 10:32 AM
How often do you use your moonroof?
by mclasser
Today at 10:29 AM
Weird Electrical Issue.
by George7941
Today at 09:35 AM
Ever puchase movies from cable provider?
by ZZman
Today at 09:31 AM
Mann HU 711/51 X oil filter for Miniís $6.50 Amzn
by 1JZ_E46
Today at 09:30 AM
M1 Oil For My Trucks Engine
by BlueOvalFitter
Today at 09:30 AM
Toyota SofTex upholstery
by CincyDavid
Today at 09:09 AM
Castrol Dexron VI $5 QT at AA
by The_Cams
Today at 08:41 AM
Liqui moly engine flush
by gallydif
Today at 08:27 AM
Uneasy about Bosch Cartridge Filter
by tc1446
Today at 07:36 AM
Harvest King 0w20 Full Synthetic
by oilstudent24
Today at 07:22 AM
oil spec.
by ernied
Today at 07:03 AM
puma4440, zeroyon223, wade12345, rdatman, mowermon
64805 Registered Users
76 registered (Alko, 4WD, 2015_PSD, 2002 Maxima SE, 1.8Tango, 440Magnum, 8 invisible), 1816 Guests and 34 Spiders online.
64805 Members
68 Forums
282068 Topics
Page 2 of 2 < 1 2
#4633884 - 01/13/18 05:44 PM Re: Owners manual says use octane 87 or higher [Re: A_A_G]
ARB1977 Online   content
Loc: North Texas
Use what the manual calls for.
2015 Tacoma 4.0L 60K (as of 02/23/18)
Amsoil SS 0W30 / Toyota filter
2008 CRV 2.4L 172K (as of 12-18-17)
Maxlife 5W20 / M1 filter
#4633888 - 01/13/18 05:48 PM Re: Owners manual says use octane 87 or higher [Re: Linctex]
double vanos Offline
Loc: 5600 feet elevation, Arizona
Originally Posted By: Linctex
Originally Posted By: slacktide_bitog
If you're in a high-altitude area or ever visit one, you still have to use 87.... they can't use the 85 offered up there and that they still have to use 87 regardless of altitude smile
This is incorrect.
High altitude = less atmospheric pressure = less cylinder filling = less need for octane.
Every gasoline engine design in existence with an option for "high altitude" is a RAISED compression ratio, because power goes down as you go higher.
Problem is: now I have a full tank of less than 87 gas thatís able to make it from my high altitude purchase site to a lower elevation, maybe even sea level. Many cars can go far enough on a tank of fuel to make that low octane purchase a warranty buster.
Sabine Schmitz is the Queen of the 'Ring; Svetlana Kapanina is the Queen of the SKIES...
#4633903 - 01/13/18 06:05 PM Re: Owners manual says use octane 87 or higher [Re: double vanos]
ammolab Offline
Loc: Ruidoso, NM USA
This is incorrect.
"A warranty buster"? Never happen GI! If it worries you that much just take it EASY on the throttle until you can pump a few gallons of premium into that 86 octane swill.
2009 Honda CR-V
2011 BMW R1200R
2005 Kaw Ninja 250
1994 Jeep Wrangler 2.5L
2016 Chevy SS Sport Sedan
#4633947 - 01/13/18 06:56 PM Re: Owners manual says use octane 87 or higher [Re: GMBoy]
Linctex Offline
Loc: Waco, TX
Originally Posted By: GMBoy
Why all the trouble mixing 1/2 of 87 and 93 to get 90? Just press the 89 button and save all that unnecessary work.
Because the cost per octane number is ridiculous, that's why.
It's cheaper to blend.
#4633948 - 01/13/18 06:58 PM Re: Owners manual says use octane 87 or higher [Re: double vanos]
Linctex Offline
Loc: Waco, TX
HUH?
What vehicle?
Most modern ECU controlled engines adjust timing & mixture to compensate just fine.
#4634435 - 01/14/18 10:06 AM Re: Owners manual says use octane 87 or higher [Re: Linctex]
GMBoy Offline
Loc: Texas
True - Cheaper by $2. Shell near me is 2.19 for 87, 2.69 for 89 and 2.99 for 93. If you took 20 gallons to fill up it would cost you $51.80 split 10 gal 87 and 10 gal 93 or $53.80 straight 20 gal of 89.
#4635517 - 01/15/18 08:58 AM Re: Owners manual says use octane 87 or higher [Re: Alex_V]
Gary Offline
Loc: N. VA
Originally Posted By: Alex_V
My Cruze is a port-injected gas, turbo I-4 with 9.5:1 compression - it's technically an 87 engine but the results every time I've put regular in it tell me it likes 89 or better a WHOLE lot more. Run at least a full tank, or several, of 89 or premium in it, then pump a bunch of regular in it and see if you notice a difference in idle quality and acceleration.
The higher is useless if 87 spec'ed doesn't necessarily apply to turbos as you've noticed. You may have even more power / response at 93. I go for that over watching MPG.
Gary /BMW CCA '91
VWs-Hondas-BMWs E36 Mti-Acura/'14 Toyota Camry V6/'15 Lexus IS 350 F Sport
Castrol Edge/Magnatec 0w-20/BrgStn stock/Mich Pilot SS
#4636687 - 01/16/18 12:56 PM Re: Owners manual says use octane 87 or higher [Re: ARB1977]
A_A_G Offline
Loc: D-town
Yeah...that would be great if the manual was a little more detailed...
"Fuel recommendation: Unleaded gasoline with pump octane number 87 or higher required"
It mentions nothing about why a higher octane should be used.
Edited by A_A_G (01/16/18 12:57 PM)
#4636738 - 01/16/18 01:28 PM Re: Owners manual says use octane 87 or higher [Re: A_A_G]
Nick1994 Online   content
Loc: Phoenix, AZ
Originally Posted By: A_A_G
I don't mind running 89 since I already do in my two other vehicles. I'm more worried about getting the best fuel economy out of it.
The average cost of 87 octane fuel is $2.53 per gallon and 89 octane fuel is $2.81. A difference of $0.28 per gallon, or 11% more. If you get 31 mpg with 87 octane, youíd need to get 34.4 mpg on 89 octane just to break even.
Itís like driving a diesel vehicle trying to save money, in some instances it can happen, but the fuel cost is so much more, it better get WAY better fuel economy to start making sense, as far as saving money on fuel.
2015 Hyundai Sonata 2.4L 76k PU 5w30 & OEM
2000 Toyota Camry 2.2L 227k M1 AFE 0w30 & Wix
1996 Jeep Cherokee 4.0L 145k M1 HM 10w40 & Fram Ultra
#4637101 - 01/16/18 07:09 PM Re: Owners manual says use octane 87 or higher [Re: A_A_G]
SilverFusion2010 Offline
Loc: Crawfordville FL
Try it, see what the car does. It depends on how itís programmed
2010 Ford Fusion SE 3.0L V6, 175k miles M1 AFE 0w-20
#4638660 - 01/18/18 10:44 AM Re: Owners manual says use octane 87 or higher [Re: A_A_G]
circuitsmith Offline
Loc: Wash, DC
My Matrix runs a little peppier with 89 octane when the ambient temp is above 90F.
Doesn't improve MPGs though.
On a road trip to see the eclipse I got to run some 89 octane ethanol free (cheap in South Carolina) and got 40 MPG.
2006 Toyota Matrix 5-sp. 1zz-fe 5000mi/12mo OCI
Any major brand dino 5w-30 on sale
Page 2 of 2 < 1 2
