No Poly-tics :) Rambling On
by Zee09. 10/20/18 08:10 AM
Michigan Police Vehicle Test Results
by tenderloin. 10/20/18 08:04 AM
1992 Olds Eighty Eight with 36,000 miles
by atikovi. 10/20/18 07:16 AM
ISUZU 3.9l Diesel 4bd1
by Wreckage. 10/20/18 04:11 AM
Repainted hood- when is it safe to wash and wax?
by PlzRepond. 10/20/18 01:23 AM
75w90 vs 75w140
by SnowDrifter. 10/20/18 12:38 AM
Wash and Spray Wax
by Marco620. 10/20/18 12:05 AM
Marine fuel injection musings
by OVERKILL. 10/19/18 09:45 PM
Finding a new mechanic
by AZjeff. 10/19/18 09:30 PM
Castrol Stop-Start oil
by Silver. 10/19/18 09:13 PM
5.7 vortex Fresh air hose?
by Serolim. 10/19/18 09:11 PM
New Oil Refiner (Frantz) purchased from Ed
by FlyNavyP3. 10/19/18 08:45 PM
1988 Dodge B250 Conversion Van Shocks?
by petes67bird. 10/19/18 08:44 PM
20KW Standby Generator Recommendations
by MParr. 10/19/18 08:15 PM
2003 Diamante, SHU 5W40, 6817m OCI
by Spetz. 10/19/18 07:48 PM
Can you tell a difference between a 305 and 350
by ram_man. 10/19/18 07:45 PM
Changing Fuids
by Snagglefoot. 10/19/18 07:38 PM
unreng, lzhome, keninger, Werdage, Frank_C
66249 Registered Users
77 registered members (bbslider001, ABomb369, alarmguy, Audios, atikovi, 2003f7, 6 invisible), 1,709 guests, and 25 spiders.
Topics292,212
Posts4,876,159
Members66,249
Most Online2,494
Oct 17th, 2018
Page 2 of 2 1 2
Re: Compilation of TPMS relearning by manufacturer [Re: Shannow] #4545697
10/16/17 10:52 PM
10/16/17 10:52 PM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
Oh goody. Can somebody school me on TPMS in the 16 Camry. I want to buy a set of winter wheels for them. TIA grin
Thick oil is better grin2
Re: Compilation of TPMS relearning by manufacturer [Re: Shannow] #4557251
10/28/17 01:13 PM
10/28/17 01:13 PM
Southeastern, PA
ryster Offline
ryster  Offline
Southeastern, PA
Originally Posted By: Shannow
Tried the deflate method to try to get the TPMS to reset per one or more of the GM tests.
Didn't work, so instead had the cross front rear rotation pressure numbers, and two tyres showing low pressure alarms even 'though I'd pumped them back up.
$40 delivered got a reset tool off ebay...
The GM "deflate" procedure was pretty much eliminated starting with the 2012 model year. For 2012+ you typically need the relearn tool. I purchased one here in the USA for $16 delivered. It turns out the dealer wasn't relearning the TPMS after rotations, and the individual readings in the display were incorrect. The relearn tool worked like a charm, and now I don't have to worry about whether or not the dealer does it when they rotate the tires.
2015 Chevrolet Equinox LT AWD
3.6L V6
Re: Compilation of TPMS relearning by manufacturer [Re: andyd] #4557253
10/28/17 01:15 PM
10/28/17 01:15 PM
Southeastern, PA
ryster Offline
ryster  Offline
Southeastern, PA
http://toyota.custhelp.com/app/answers/detail/a_id/8413/~/how-does-the-tire-pressure-monitoring-system-work-in-my-2015-camry%3F
The 2015 and 2016 should work the same, I would think.
3.6L V6
Re: Compilation of TPMS relearning by manufacturer [Re: Shannow] #4558969
10/30/17 06:40 AM
10/30/17 06:40 AM
Ontario, Canada
StevieC Offline
StevieC  Offline
Ontario, Canada
I have only ever had Dodge's with this system. Dodge Caravan and Dodge Journey I guess I never thought about tire rotation affecting where it shows on the display. I'm also happy that my vehicle is smart enough to figure it out on its own. wink
'18 Dodge Grand Caravan GT - Valvoline (Break-in)
'06 Santa Fe - 535,000km AMSOIL SS 0w30 / ATF
Re: Compilation of TPMS relearning by manufacturer [Re: skyactiv] #4565318
11/05/17 09:40 PM
11/05/17 09:40 PM
Texas
4WD Offline
4WD  Offline
Texas
After 20 hours of flight I can grab my iPad/phone & check each tire pressure on vehicles back home.
Think speed sensors alone must have rotation to determine a speed change related to air pressure
Re: Compilation of TPMS relearning by manufacturer [Re: Shannow] #4569592
11/10/17 09:06 AM
11/10/17 09:06 AM
NE,Ohio
Rand Offline
Rand  Offline
NE,Ohio
Jeep/mopar is easily one of the best systems out there..
unlike subaru's afterthought abortion of a system.
Jeep system.. put tires wherever it just works and tells you pressure of each tire... sensors are $8-10 each at the dealer.
Subaru system > Can only store 4 sensors max. Total cluster if you use 2 sets of wheels.
needs expensive tool(150$+)
Doesnt tell you pressures. Idiot light to tell you of possible issues.
Sensors around $40-$50 each.
I have no experience with 2017+ Subaru I think they might be migrating to a better system finally.
Re: Compilation of TPMS relearning by manufacturer [Re: Shannow] #4601208
12/12/17 04:18 AM
12/12/17 04:18 AM
British Columbia, Canada
jtr990 Offline
jtr990  Offline
You should have seen some Mitsubishi vehicles (Lancer, Outlander, Outlander Sport/RVR, and Mirage - the US-spec, TPMS-equipped Mirage; the Canadian-market Mirage doesn't use TPMS on its wheels).
Relearning the system on those vehicles was completely different from the standard OBD-II procedure. I had to use a Snap-On Modis Ultra to enable the relearn procedure and use the Bartec Tech400 SD as the trigger tool. Despite a few hiccups, it worked out all right.
Re: Compilation of TPMS relearning by manufacturer [Re: Shannow] #4601213
12/12/17 04:31 AM
12/12/17 04:31 AM
'Stralia
Shannow Offline OP
Shannow  Offline OP
'Stralia
Found out that the Oz reset instructions are wrong.
Had to put the spare on the other day due to a screw in the right rear...spare has no TPMS and was showing the left rear...let down the left front and the right front showed flat.
So the Oz instructions in the owner's manual are Bass Ackwards, and you have to treat it as LHD.
Re: Compilation of TPMS relearning by manufacturer [Re: Shannow] #4633883
01/13/18 06:42 PM
01/13/18 06:42 PM
N. VA
Gary Offline
Gary  Offline
N. VA
You wonder with the complexity of resets, etc why don't they just use actual TPMS sensors in each wheel with a direct pickup alongside. The Lexus needs no resetting when rotating tires.
Gary /BMW CCA '91
VWs-Hondas-BMWs E36 Mti-Acura/'14 Toyota Camry V6/'15 Lexus IS 350 F Sport
Castrol Edge/Magnatec 0w-20/BrgStn stock/Mich Pilot SS
Re: Compilation of TPMS relearning by manufacturer [Re: Gary] #4691191
03/11/18 08:41 AM
03/11/18 08:41 AM
Kansas
nutdriver Offline
nutdriver  Offline
Kansas
In case anyone is looking there is a similar link to import procedures.
http://jameshalderman.com/images/import_tpms_relearns_1-4.pdf
Re: Compilation of TPMS relearning by manufacturer [Re: Shannow] #4816421
07/17/18 01:50 PM
07/17/18 01:50 PM
Ohio
hallstevenson Offline
Ohio
So when a tire place offers "free" rotation, will some charge for the relearning process ? Our cars only have a single light that tells us (at least) ONE of the tires has low pressure, not which it is. Will the sensors still work if a tire has low pressure ? I presume it will.
Page 2 of 2 1 2
