New Oil Refiner (Frantz) purchased from Ed
by FlyNavyP3. 10/19/18 08:45 PM
1988 Dodge B250 Conversion Van Shocks?
by petes67bird. 10/19/18 08:44 PM
20KW Standby Generator Recommendations
by MParr. 10/19/18 08:15 PM
2003 Diamante, SHU 5W40, 6817m OCI
by Spetz. 10/19/18 07:48 PM
Can you tell a difference between a 305 and 350
by ram_man. 10/19/18 07:45 PM
Changing Fuids
by Snagglefoot. 10/19/18 07:38 PM
Subaru Forester tire pressure?
by Joeescape63. 10/19/18 07:30 PM
PC Duron Synthetic 5W40
by PeterPolyol. 10/19/18 06:43 PM
Shops not willing to do hard work?
by JHZR2. 10/19/18 05:55 PM
Wix 57173, 7400 miles
by JLTD. 10/19/18 05:09 PM
04 Pontiac GP AC Blower or AC Heat Controller
by clarkflower. 10/19/18 04:55 PM
What is Viscosity Index?
by BlakeB. 10/19/18 03:49 PM
Brake Fluid Difference
by Y_K. 10/19/18 02:54 PM
weber auto youtube talking about ATF
by bionictony. 10/19/18 02:30 PM
Acura MDX Key Problem- Urgent request please!
by methusaleh. 10/19/18 02:11 PM
Beef failures,,,yep
by CourierDriver. 10/19/18 01:07 PM
Rear brakes wearing faster than fronts?
by Ddub. 10/19/18 12:52 PM
unreng, lzhome, keninger, Werdage, Frank_C
66249 Registered Users
95 registered members (bdcardinal, bcossa2001, Appaloosa, AZjeff, 99cyclone, 11 invisible), 1,477 guests, and 34 spiders.
Topics292,193
Posts4,875,827
Members66,249
Most Online2,494
Oct 17th, 2018
Any tips to install a spring? #4633719
01/13/18 03:38 PM
01/13/18 03:38 PM
Deplorable in apple valley, ca
Chris142 Offline OP
Chris142  Offline OP
The brake pedal return springs on my tractor are off. I have them. I cant figure out how to stretch and install them. They are very stiff.
Any tricks besides vice grips and screwdrivers?
02 Wrangler durablend 10w40
87 F250 traveler 15w40
04 Tahoe super-s 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Any tips to install a spring? [Re: Chris142] #4633722
01/13/18 03:41 PM
01/13/18 03:41 PM
ME
eljefino Offline
eljefino  Offline
ME
Many screwdrivers. Stick little wedges between each spring coil. Don't give any one position too much or you'll stretch them permanently.
Is there a way you can get all-thread in the middle with appropriate nuts and washers to make an inside-out spring compressor/ expander?
Re: Any tips to install a spring? [Re: Chris142] #4633728
01/13/18 03:47 PM
01/13/18 03:47 PM
Chris142 Offline OP
Chris142  Offline OP
I dont think so. The spring is only 3 inches or so long
Re: Any tips to install a spring? [Re: eljefino] #4633740
01/13/18 03:58 PM
01/13/18 03:58 PM
SD
zrxkawboy Offline
zrxkawboy  Offline
SD
Coins work well for this, too.
"Think of all the Ford owners who will someday want an automobile." John Dodge
Re: Any tips to install a spring? [Re: Chris142] #4633741
01/13/18 03:59 PM
01/13/18 03:59 PM
CA
spackard Offline
spackard  Offline
CA
A bent rod with a notch in the end, won't do it?
https://www.youtube.com/watch?v=MIyESaecC2s
(They sell just the rod, and I have one laying around somewhere, but it's been awhile since I've needed one.)
Re: Any tips to install a spring? [Re: Chris142] #4633753
01/13/18 04:12 PM
01/13/18 04:12 PM
Toronto Canada
WobblyElvis Offline
WobblyElvis  Offline
Toronto Canada
Springs can be dangerous. Use protective eye wear.
Re: Any tips to install a spring? [Re: Chris142] #4633756
01/13/18 04:17 PM
01/13/18 04:17 PM
n.c.
gman2304 Offline
gman2304  Offline
n.c.
I used a ratcheting strap to stretch the spring out and then a large screw driver to persuade it on on my old JD tractor. Be careful, this could be dangerous and is a tough procedure.
Re: Any tips to install a spring? [Re: Chris142] #4633761
01/13/18 04:19 PM
01/13/18 04:19 PM
Chicago, IL
EdwardC Offline
EdwardC  Offline
Chicago, IL
I was going to suggest a similar tool that I saw ETCG use on springs for a drum brake replacement, might be useful. I like the idea of coin spacers though!
It was something like these.
https://www.weselltools.com/brake-spring...7UaArCvEALw_wcB
https://mobiledistributorsupply.com/lis4...RIaAre4EALw_wcB
Re: Any tips to install a spring? [Re: Chris142] #4633934
01/13/18 07:42 PM
01/13/18 07:42 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Pictures of the springs?
If they have hooks (tension springs), I use a loop of wire or cable clamped in a vise-grip
Re: Any tips to install a spring? [Re: Chris142] #4633946
01/13/18 07:54 PM
01/13/18 07:54 PM
'Stralia
Shannow Online content
Shannow  Online Content
'Stralia
No advice here...every one I've ever done was at considerable personal risk
Re: Any tips to install a spring? [Re: Shannow] #4635012
01/14/18 07:56 PM
01/14/18 07:56 PM
Chicago, IL
EdwardC Offline
EdwardC  Offline
Chicago, IL
I think you're thinking of a suspension spring compressor.
Re: Any tips to install a spring? [Re: EdwardC] #4635106
01/14/18 09:13 PM
01/14/18 09:13 PM
ME
eljefino Offline
eljefino  Offline
ME
Stretching brake drum type springs ain't fun, either... trying to work it over the "nail" using the tip of a screwdriver, sparks flying, etc.
Re: Any tips to install a spring? [Re: eljefino] #4635893
01/15/18 04:41 PM
01/15/18 04:41 PM
Virginia
GravelRoad Offline
GravelRoad  Offline
Virginia
Spring Pull Tool https://www.ebay.com/itm/Genuine-MTD-732-0571-Spring-Pull-Tool/232260443358?epid=1713027439&hash=item3613cd1cde:g:8G4AAOSwiYlaGIxS
I have and use three different sizes of these type of spring pull tools. work very well.
Also used a piece of looped starter rope many times, just make it into a loop, put on gloves, hook the spring and pull into place.
edit: I use these tools on lawn and garden equipment not farm tractors.
2016 Subaru Outback Premium 2.5. PP 5w30 oem filter
2018 Hyundai Kona 1.6T. Lifetime dealer free oil/filter change
