Tankless Water Heaters - Any Suggestions?
by Miller88
01/19/18 02:29 PM
White FRAM FP-3600 Oil Filters
by CajunLariat
01/19/18 02:01 PM
2008 Civic LX Sedan not starting
by maverickfhs
01/19/18 01:58 PM
Wix XP efficiency
by ZraHamilton
01/19/18 01:46 PM
Can we upload files (PDF)?
by paulri
01/19/18 01:43 PM
What are your thoughts on tattoos?
by ZZman
01/19/18 01:06 PM
Engine teardown with weight comparison?
by BullittGT
01/19/18 12:59 PM
NAPA Gold or ?
by AZjeff
01/19/18 12:25 PM
Bye bye v10, hello F150 5.0
by snowflake
01/19/18 12:21 PM
Tips for kicking tires on a fixer-upper
by HawkeyeScott
01/19/18 11:57 AM
Autonomous Trucks
by Snagglefoot
01/19/18 11:09 AM
New member -- Acura -- oil/filter???
by Daulton
01/19/18 11:06 AM
ETCG Q&A With Valvoline Engineers
by Starman2112
01/19/18 10:55 AM
Factory Fill Oil for 3/4 ton diesel Pickups 2017 +
by Snagglefoot
01/19/18 10:38 AM
Got a spare bathtub?
by Quattro Pete
01/19/18 10:33 AM
SuperTech 20w50 Dino
by cjsiege
01/19/18 09:54 AM
Fake Unemployment benefit claim scam
by stockrex
01/19/18 08:20 AM
Greatest Country Song
by Virtus_Probi
01/19/18 07:16 AM
5w30 & 10w30
by Camprunner
01/19/18 07:10 AM
Who has better base stock 5w40 delo or rotella?
by Sealbilly
01/19/18 05:19 AM
froze, David1954, Ratcheteer, djsayat, Jay4
63963 Registered Users
95 registered (bernau, Astro14, barryh, AdamZ, 2009Edge, 10 invisible), 1740 Guests and 12 Spiders online.
63963 Members
65 Forums
276930 Topics
Page 3 of 3 < 1 2 3
#4633333 - 01/13/18 08:38 AM Re: Sludge remediation regimen: Toyota 3MZ-FE V6 [Re: coastsider]
dlundblad Offline
Loc: Midwest
Concern about crud or moisture buildup on or around fill caps as well as dipstick tubes isn't a huge concern. The areas are never allowed to get hot and the majority of the threads are posted during the winter months.
I've been worried about it before too.
03 Jeep WJ 4.0 197k Castrol Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 170k M1 0w40 Mann HU818X
97 Chevy Blazer 4.3 138k Synpower 5w30 Fram TG3980
#4633347 - 01/13/18 08:49 AM Re: Sludge remediation regimen: Toyota 3MZ-FE V6 [Re: coastsider]
alarmguy Offline
Loc: South Carolina
You have a good truck, would not be concerned with what you scrapped off with your finger.
With that said, yes, without question simply run an HEDO, change it every 4000 miles or so or 3 times a year (or check the manual for severe usage) depending of course it it will be a higher mileage highway vehicle (easy on the engine) or local low mileage vehicle (rough on an engine) - of course as you know, warmer climate makes it even more easy on the engine.
Personally I would not use a synthetic HDEO but thats up to you, my first preference is always conventional HDEO.
Edited by alarmguy (01/13/18 08:50 AM)
14 Road King (current)
08 VStar 1300 Tourer
07 Suzuki C50
#4633664 - 01/13/18 01:35 PM Re: Sludge remediation regimen: Toyota 3MZ-FE V6 [Re: FlyNavyP3]
Trav Offline
Loc: MA, Mittelfranken.de
Originally Posted By: FlyNavyP3
Originally Posted By: Trav
That engine has a crusty looking black baffle under the fill cap. If you want to know how it really looks pull a valve cover (no need to pull both just the easiest one) then you will know if you are dealing with any sort of buildup or a clean engine.
I wouldn't go much more than 3-4K OCI on these bad boys though depending on their use.
Concur with the baffle but disagree with the OCI length, I've had 1-3 ppm iron and aluminum as far out as 10,000 miles on UOA in the exact same engine. Everything from conventional to top shelf Synthetic, no difference, everything from 5w20 to SAE 30 to 20w50 no change. This engine isn't hard on oil in my experience.
Your probably right given your and the OP's location/climate. Up here in the north east with a lot of stop and go and short trips the 3.0 Toyota has a known issue for sludge even after they extended the warranty and supposedly took care of the problem.
Toyota themselves recommended 3K OCI and IIRC synthetic oil in the warranty extension letter I got some years ago.
#4634629 - 01/14/18 12:18 PM Re: Sludge remediation regimen: Toyota 3MZ-FE V6 [Re: Trav]
kschachn Online   content
Loc: Upper Midwest
Ture, but this is the 3.3L 3MZ-FE.
1994 BMW 530i, 222K
1996 Honda Accord, 251K
1999 Toyota Sienna, 387K
2000 Toyota ECHO, 264K
#4634683 - 01/14/18 01:22 PM Re: Sludge remediation regimen: Toyota 3MZ-FE V6 [Re: coastsider]
KL31 Offline
Loc: South OZ
Same engine here in a highlander and yes that's just how the filler hole looks.
Run the havoline if you have plenty. Absolutely no need to fork out money for something that will "clean" better because it won't clean much better and there's 99% nothing to clean if the engine has full service history. Just enjoy the car and maintain it best you can.
1995 MX-3 - KLZE swapped
Shell Helix Ultra 5W40
Wix 51356
Page 3 of 3 < 1 2 3
