Weber gas grills & Weber 10 yr warranty
by Donald
Today at 05:50 PM
2008 Honda Odyssey oil and filter?
by CARJ
Today at 05:11 PM
Bugatti Veyron $21k oil change???
by wemay
Today at 05:07 PM
Nexen N Priz AH8 vs Hankook Ventus V2 Concept
by ET16
Today at 04:48 PM
1999 LeSabre to 2008 Lucerne
by Duffyjr
Today at 04:26 PM
Engine Oil "catch cans"
by TnMike46
Today at 04:17 PM
2018 Audi S4 4.5k mi Factory Fill
by Vigg
Today at 03:46 PM
RAGBRAI 2018
by DriveHard
Today at 03:23 PM
Bat houses?
by PW01
Today at 01:55 PM
Hub Centering Rings
by Char Baby
Today at 12:48 PM
Bad Discount Tire experience
by dwgwater
Today at 12:08 PM
2007 Accord coupe V6
by aquariuscsm
Today at 11:49 AM
Mystery Oil
by Zee09
Today at 10:52 AM
Mobil 1 EP good enough for non-aggressive drivers?
by Jasper8146
Today at 10:49 AM
2011 Durango 5.7L 125K PPHM 0W20 3K W/ Towing
by Mathew_Boss
Today at 10:27 AM
Eric The Car Guy's Mobil 1 AP Test
by camrydriver111
Today at 10:19 AM
Alignment: loading suspension in sloped driveway
by zorobabel
Today at 10:14 AM
Very Impressed with Fram Qualityc- CH10160
by rooflessVW
Today at 09:49 AM
Costco Canada Bridgestone Sale
by IndyIan
Today at 09:33 AM
Buying oil overseas, shipping to the US?
by d00df00d
Today at 09:23 AM
RYCOJO, Gunplt, bjay, javylsu, Jlb27537
65503 Registered Users
88 registered (Aero540T, 300m2000, 2015_PSD, 2009Edge, 12 invisible), 1499 Guests and 32 Spiders online.
65503 Members
67 Forums
287286 Topics
#4633455 - 01/13/18 10:11 AM VW 1.6tdi - CJ4 instead of VW507?
Donkeye Offline
Loc: Denmark
Hey!
I'm a bus mechanic, so I have plenty access to free CJ4 oils, 5w-30 vecton fuel save e6/e9.
Would it kill my car, a SEAT Ibiza 1.6tdi (common rail) if I used the CJ4 oil, instead of VW507? Cheers.
#4633660 - 01/13/18 01:31 PM Re: VW 1.6tdi - CJ4 instead of VW507? [Re: Donkeye]
shDK Offline
Loc: Denmark
Jeg ville ikke bekymre mig om det. Både cj4 og e6/e9 er ret høje krav.. og er også beregnet til partikelfilter, den skal også have en HTHS på min. 3.5 ligesom VW 507.00 normen. du kunne for en sikkerheds skyld skifte ved dobbelt interval når nu olien er gratis. Men vil mene olien er helt på højde
Edited by shDK (01/13/18 01:34 PM)
#4634017 - 01/13/18 08:42 PM Re: VW 1.6tdi - CJ4 instead of VW507? [Re: Donkeye]
JFAllen Offline
Loc: Albury, NSW
Will it cause problems?
Almost certainly not, HOWEVER:
The big difference between CJ4 oils and 504/507 blends is the ash (SAPS) content. 1% for CJ4 and 0.6% for 504/507. With the EGR/DPF systems on modern small displacement TDi's, blends are specifically designed to limit carbon build-up (especially in the intake tract.) Also the vast majority of CJ4 oils are Mineral G2 oils, thus tend to have higher NOACK values. All 504/507 oils are synthetic and as a result have higher viscosity indices and lower NOACK.
Higher NOACK values for large Diesel engines are not really an issue, as the sump's are massive 10->20L+ is not uncommon for on-road use (sumps in excess of 100L are common on large stationary engines and mining equipment.) Thus the oil, even in constant high load applications (say a generator or a mining truck hauling up hill) tends to remain cooler than in a small displacement passenger diesels. The large units also tend to have massive oil coolers.
Further more they operate at lower RPM (often <2000,) and with complex multi stage filtration systems; CJ4 oils are great for use in their intended applications. Buit not ideal for a small VW 1.6 (oddly enough)
I'm sure there are punters running far worse oils in their VW TDi's, but VW spent a great deal of time, engineering and money ensuring that their engines with the 504/507 spec is the best combination when all things are considered.
I personally use 504/507 Shell Helix Ultra 0W30 in my vehicles (which are not from VW) as it's SN rated and has a VI of >200 with a very low NOACK (can't remember specifically.) It's not that expensive (even in Australia) and is good piece of mind.
Regards
Jordan
Edited by JFAllen (01/13/18 08:44 PM)
#4634188 - 01/14/18 03:00 AM Re: VW 1.6tdi - CJ4 instead of VW507? [Re: Donkeye]
Garak Offline
Loc: Regina, Saskatchewan, Canada
Much was covered, and I couldn't even begin to build upon what shDK said. wink What I would add is that the Vecton would not kill your cats. The E6 lube is low phosphorus.
Plain, simple Garak.
2008 Infiniti G37 - Shell ROTELLA T6 Multi-Vehicle 5w-30, NAPA Gold 7356
#4634210 - 01/14/18 04:12 AM Re: VW 1.6tdi - CJ4 instead of VW507? [Re: Donkeye]
zeng Offline
Loc: Malaysia
Concur with JF Allen on the above observations between CJ4 vs VW507.
Having said this,typically used in diesel work machines under low speed,high torque,high load and high temperature, I'm of the opinion that a CJ4 E6 E9 Vecton 5W30 is more than adequate in protecting a super-light duty (from the perspective of work machines) 1.6 tdi, hence it could not kill the tdi.
The pertinent question to ask is their respective OCI's, not protection capability per se.
JMHO.
Edited by zeng (01/14/18 04:13 AM)
#4641967 - 01/21/18 01:54 PM Re: VW 1.6tdi - CJ4 instead of VW507? [Re: Donkeye]
Bailes1992 Offline
Loc: South Wales, UK
If the engine burns relativity little oil I would use it and not look back! Rein in the OCI's a little bit and get a few UOA done before you start to extend them again.
'13 Suzuki Jimmny - '16 Dacia Duster 1.5DCi 4WD
'96 LR Defender 300TDi - '12 BMW 320d
Engine Oil - Fuchs Titan XTL GT1 5w40
Gearbox Oil - Fuchs Sintofluid 75w80
Diff Oil - Fuchs Sintopoid 75w90
#4643746 - 01/23/18 08:01 AM Re: VW 1.6tdi - CJ4 instead of VW507? [Re: Donkeye]
bigjl Offline
Loc: London, England
I can't see what is to be gained apart from a tiny financial saving at the expense of peacs of mind
16 S350d LWB 25k Mobil Super 3000 XE 5w30
17 Smart ForFour Auto 6.5k Mobil 1 0w40 FS
#4654709 - 02/03/18 10:32 AM Re: VW 1.6tdi - CJ4 instead of VW507? [Re: Donkeye]
Kamele0N Offline
Loc: Slovenia EU
https://www.oilspecifications.org/acea.php
ACEA E6/E9 more than good for any passenger car equiped with DPF filter...
thumbsup
2011 Hyundai i30 1.4 CVVT Shell Helix Ultra 5w40
1997 Toyota Landcruiser KZJ95 3.0 TD Shell Rimula R6M 10w40
