What tire pressure to run?
Here's how to do this:
The principle is to match the original load carrying capacity. The starting point is the vehicle tire placard.
I can't tell which jeep your new tires went on, so I am going to guess the '05. Tire Guides doesn't list the various Jeep models as you've described them in your signature, but I am going to take a guess the pressures listed on the vehicle tire placard are 33/33 and the tire size is P225/75R16. Please check to be sure that is correct.
If that is correct, in order to carry the same load as a P225/75R16 does at 33 psi, a P245/75R16 needs to use 26 psi.
- BUT -
If you can match the load carrying capacity at a lower pressure, it's a good idea to match the original spring rate of the tire, which is mostly about inflation pressure (unless you are changing springs and shocks, too!) - so I would recommend using the originally spec'd 33 psi.
And that would be your new starting point. Some folks like to modify from there to achieve a different goal that the engineers at the factory had in mind.
Oh, and one other point: A P245/75R16 requires a minimum of a 6 1/2" wide rim. I think your Jeep has 7" wide wheels, but you need to check. If you try to use a rim that is too narrow, the vehicle will wander and follow the ruts in the highway, as well as be sensitive to cross winds.
Thanks for the help everyone!
@Capriracer, I'm running 8" wide rims now, how does that effect pressure? (vs 7 stock)
From a load carrying capacity point of view, it doesn't.
