ST Conventional SN Plus
by motorguy222. 10/19/18 02:42 AM
schaefferoil or Amsoil
by s2krunner. 10/19/18 02:29 AM
Pennzoil conventional oil meets api sn plus
by chris_84. 10/18/18 11:45 PM
TGMO in new Honda turbos?
by BTLew81. 10/18/18 11:26 PM
'02 Explorer Sport Trac: 302k mile update
by 14Accent. 10/18/18 10:43 PM
BMW 335 Quick Coolant Change
by antonmnster. 10/18/18 09:58 PM
190k miles
by Marco620. 10/18/18 09:56 PM
tire rotation/jack location
by mobilaltima. 10/18/18 09:23 PM
Apparently I'm not allowed to...
by BMWTurboDzl. 10/18/18 08:41 PM
2014 Cruze 2.0, AMSOIL DHD 7k miles 68k total
by Rat407. 10/18/18 08:32 PM
Stabilizer needed for 5-6 month storage?
by Quattro Pete. 10/18/18 08:29 PM
Clearance ST filter cut open
by barkingspider. 10/18/18 07:56 PM
0W20 Required for Jeep Auto Stop/Start
by harbor. 10/18/18 05:42 PM
School buses + Colder Temps = MPG Nosedive
by RayCJ. 10/18/18 05:20 PM
Meguiars Wax
by dslofti. 10/18/18 04:41 PM
Whyssosseriouss, TNflash, The74impala, Ryan1122, ston123
66244 Registered Users
21 registered members (Duke, CT8, cjcride, Black_Thunder, bbhero, ctechbob), 788 guests, and 30 spiders.
Topics292,163
Posts4,875,176
Members66,244
Most Online2,494
Oct 17th, 2018
Suggestion for a good brake drum? #4633637
01/13/18 02:09 PM
01/13/18 02:09 PM
Buffalo, New York
JimmyJohns Offline OP
Buffalo, New York
I can't seem to find a good set of drums these days. My truck had centric drums and within a week they were warped. My mothers car, 2000 buick century, got a set from Auto plus, house brand, and the first set were warped the first day, I mean bad. Second set warped in a week, all brake components are new back there and it's properly adjusted.
What brand of drums can some of you recommend? I'd get these drums turned but I'm afraid it might just happen again.
Re: Suggestion for a good brake drum? [Re: JimmyJohns] #4633656
01/13/18 02:28 PM
01/13/18 02:28 PM
Buffalo, NY
JTK Offline
JTK  Offline
Buffalo, NY
In the Buffalo area, I've used Napa and CarQuest drums without issue. I don't recall what specific "brand" they were though. It's been awhile since I've owned or worked on a car with rear drums.
2017 Ram 1500 4x4, 3.6L. 2016 Nissan Quest SV (Babe magnet IV)
Re: Suggestion for a good brake drum? [Re: JimmyJohns] #4633668
01/13/18 02:39 PM
01/13/18 02:39 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Napa costs more, but worth it.
OEM should be fine, but again.... cost$$$$$
Re: Suggestion for a good brake drum? [Re: JimmyJohns] #4633688
01/13/18 03:06 PM
01/13/18 03:06 PM
VA
Gebo Offline
Gebo  Offline
VA
In my experience, OEM from GM. Same thoughts on brake pads as well.
'98 LEX LS400 280K
'00 LEX GS300 195K
'02 4Runner 225K
'05 Lex LS430 85K
'06 Toyota Highlander 145K
'09 Lex IS350 85K
'07 Lex GX470 60K
Amsoil in all engines, transmissions and differentials
Re: Suggestion for a good brake drum? [Re: JimmyJohns] #4633732
01/13/18 03:50 PM
01/13/18 03:50 PM
Buffalo, New York
Buffalo, New York
Good to know, I'll check prices and hopefully it will be the end to my issues. Thanks guys
Re: Suggestion for a good brake drum? [Re: JimmyJohns] #4633788
01/13/18 04:47 PM
01/13/18 04:47 PM
USA
slacktide_bitog Offline
USA
If you can convert to rear discs, that might be the better option, depending on how easy or difficult is for your Century.
Re: Suggestion for a good brake drum? [Re: JimmyJohns] #4633852
01/13/18 06:09 PM
01/13/18 06:09 PM
On the road Midwest
Ihatetochangeoil Offline
On the road Midwest
What he said ^^^^
Since rear brake pads for a 2000 Buick Century are available on eBay in disc brake style; https://www.ebay.com/sch/i.html?_odkw=wh...ds&_sacat=0
I'm willing to bet it's a bolt up parts swap if you'd like to upgrade to disc brakes. Do as you wish; my two cents worth is I'd spend a Saturday morning at a salvage yard and buy one side of cheap junk parts just to see if they will mate up and bolt on. Once you know the answer, buy new parts with confidence.
2003 Lesabre
2004 Lesabre
2004 Impala
If ur NOT doing UOA then you're throwing away good oil or your engine is already damaged. Choose.
Re: Suggestion for a good brake drum? [Re: JimmyJohns] #4633871
01/13/18 06:32 PM
01/13/18 06:32 PM
Hawaii, USA
anndel Offline
anndel  Offline
Hawaii, USA
NAPA premium on my 1993 Toyota pickup. It's been on about 3 years now and no warping.
Re: Suggestion for a good brake drum? [Re: JimmyJohns] #4633991
01/13/18 09:06 PM
01/13/18 09:06 PM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
OEM from scrapyard?
Re: Suggestion for a good brake drum? [Re: JimmyJohns] #4635300
01/15/18 02:05 AM
01/15/18 02:05 AM
California
nthach Offline
nthach  Offline
California
It's all a roll of the dice these days. Buy the one that strikes a balance between price and warranty.
Re: Suggestion for a good brake drum? [Re: JTK] #4668855
02/17/18 04:26 PM
02/17/18 04:26 PM
Florida
artificialist Offline
Florida
They used Raybestos for a while, but I don't know if they still use Raybestos.
2010 Lancer Ralliart Sportback
Re: Suggestion for a good brake drum? [Re: JimmyJohns] #4669335
02/18/18 08:41 AM
02/18/18 08:41 AM
Watertown, New York
cronk Offline
cronk  Offline
Watertown, New York
I have had good luck with Centric drums and rotors.
Are you sure your not adjusting the shoes to far out? It will heat up the drums and cause warping like you are describing.
2008 Ford F350
2003 Chevy Cavalier
2011 Nissan Quest
1986 Pontiac Trans Am
1940 Ford 9N Tractor
Amsoil lubes and filters!
