So how much do you pay for gas?
by rollinpete
04/21/18 02:10 PM
Adjusting Alternator Voltage
by George7941
04/21/18 01:48 PM
what if i dont know what to use
by VTAK
04/21/18 01:41 PM
Magnatec - intelligent molecules?
by PeterPolyol
04/21/18 01:39 PM
Goodbye Encore, hello Soul!
by csandste
04/21/18 12:34 PM
7.3 drain plug torque
by mobilaltima
04/21/18 12:26 PM
'09 Kia Sedona - to change or not to change (oil)?
by Number_35
04/21/18 12:19 PM
I Think Spring Is Finally Here
by Warstud
04/21/18 11:48 AM
NAPA GOLD 7055 UN USED CUT OPEN
by car51
04/21/18 11:26 AM
Broken Cat
by Stelth
04/21/18 10:32 AM
How often do you use your moonroof?
by mclasser
04/21/18 10:29 AM
Weird Electrical Issue.
by George7941
04/21/18 09:35 AM
Ever puchase movies from cable provider?
by ZZman
04/21/18 09:31 AM
Mann HU 711/51 X oil filter for Miniís $6.50 Amzn
by 1JZ_E46
04/21/18 09:30 AM
M1 Oil For My Trucks Engine
by BlueOvalFitter
04/21/18 09:30 AM
Toyota SofTex upholstery
by CincyDavid
04/21/18 09:09 AM
Castrol Dexron VI $5 QT at AA
by The_Cams
04/21/18 08:41 AM
Liqui moly engine flush
by gallydif
04/21/18 08:27 AM
Uneasy about Bosch Cartridge Filter
by tc1446
04/21/18 07:36 AM
Harvest King 0w20 Full Synthetic
by oilstudent24
04/21/18 07:22 AM
puma4440, zeroyon223, wade12345, rdatman, mowermon
64805 Registered Users
77 registered (2strokeNorthstar, 4WD, 2dogs, 2015_PSD, 2002 Maxima SE, 1.8Tango, 9 invisible), 1717 Guests and 41 Spiders online.
64805 Members
68 Forums
282069 Topics
#4633294 - 01/13/18 08:14 AM Gear oils HKS (Japan) API GL-5, based on mPAO
Izb Offline
Loc: London, UK
Street and race proven HKS Gear Oil range has been renewed with clearly marked viscosities with a range of 5 different type varying from No. 90 to No. 250. You can always find the best grade yor your car. Using 100% synthetic non polymer oil for the most efficient lubrication from economy to high power applications which require strong load capacity and low friction.
https://www.hks-power.co.jp/en/product/oil/gearoil_g/index.html
A range of 5 different types varying from #90 to #250 are available for various applications. You can always find the best grade for your car. Using 100% synthetic non polymer oil for the most efficient lubrication from economy to high power applications which require strong load capacity and low friction.
G-900: 75W-90
G-1000: 75W-100
G-1200: 75W-120
G-1400: 75W-140
G-2500: 85W-250
Partnumbers for orders: https://www.hks-power.co.jp/en/product_search/product/323
Where to order: http://www.hks-global.com/en/affiliates/usa.html
Specifications of G-900/G-1000/G-1200/G-1400/G2500
KV100C: 20.42/26.74 /26.53 / 25.67 /101.50
KV40C: 123.80/182.70 /170.00/170.90 /857.00
VI: 190 /183 /181 /185 /214
PP: -50C /-42.5C /-42.5C/ -45C /-45C
Flash point: >200C / >200C / >200C/ 210C / 204C
Density (15ļC) 0.870/ 0.870 / 0.870/ 0.862 /0.876
Edited by Izb (01/13/18 08:27 AM)
#4633398 - 01/13/18 09:21 AM Re: Gear oils HKS (Japan) API GL-5, based on mPAO [Re: Izb]
Izb Offline
Loc: London, UK
About High-performance metallocene polyalphaolefin (mPAO):
https://www.exxonmobilchemical.com/en/pr...polyalphaolefin
https://www.exxonmobilchemical.com/~/media/chemicals/kl-media-assets/2017/10/25/10/50/exxonmobil_chemical_advanced_synthetic_base_stocks_enpdf.pdf
Edited by Izb (01/13/18 09:24 AM)
#4633450 - 01/13/18 10:08 AM Re: Gear oils HKS (Japan) API GL-5, based on mPAO [Re: Izb]
BJD78 Offline
Loc: Nebraska
Have never seen that brand here in Lincoln NE. I use Valvoline 75W90 for my Forester front and rear diff. A qt is about $5.00 to $6.00 at most any auto or farm store and I wont need to change it for another 50,000 miles. So far no issues even with the sub zero temps we have had. I will probably trade it before I get another 5K on it. Lucky if I put on 5 to 7 K miles on it in a year. So nice o be retired and not have to buy gas every week and drive every day to go to work anymore Tank of gas will last me a month or more now
2010 Forester:122K
2009 Sonata :189K
2010 Tucson:55K
OCI 5K to 7K using the cheapest dino oil I can buy,usually NAPA or TSC Travelers oil.
#4633481 - 01/13/18 10:28 AM Re: Gear oils HKS (Japan) API GL-5, based on mPAO [Re: Izb]
Mainia Offline
Loc: Upper midwest
I will be happier buying my Redline gear oil.
#4633484 - 01/13/18 10:30 AM Re: Gear oils HKS (Japan) API GL-5, based on mPAO [Re: Izb]
ZebRuaj Offline
Loc: MN
I'm the same with BJD78.
I'm sure its a great lube, but after joining BITOG, I no longer get the tinglies running pricey stuff. And my wallet is happier.
Somebody who's all about JDM will for sure want it for the stickers.
~Shade tree mechanic for friends and family.
#4634229 - 01/14/18 06:08 AM Re: Gear oils HKS (Japan) API GL-5, based on mPAO [Re: Izb]
Shannow Offline
Loc: 'Stralia
If a company can't even stick to the regular nomenclature with regard to viscosity grades (hint SAE J306), then to my opinion, every single claim that they make after that point is drawn into question.
#4635654 - 01/15/18 11:25 AM Re: Gear oils HKS (Japan) API GL-5, based on mPAO [Re: Shannow]
MolaKule Offline
Loc: Iowegia - USA
thumbsup thumbsup
Hatito Hakiwisilaasamamo Waswasimamo Howisiwapani - Shawnee for: "Hello," "Good Morning," and "here's hoping you feel good." smile
