1992 Olds Eighty Eight with 36,000 miles
by atikovi. 10/20/18 07:16 AM
ISUZU 3.9l Diesel 4bd1
by Wreckage. 10/20/18 04:11 AM
Repainted hood- when is it safe to wash and wax?
by PlzRepond. 10/20/18 01:23 AM
75w90 vs 75w140
by SnowDrifter. 10/20/18 12:38 AM
Wash and Spray Wax
by Marco620. 10/20/18 12:05 AM
Marine fuel injection musings
by OVERKILL. 10/19/18 09:45 PM
Finding a new mechanic
by AZjeff. 10/19/18 09:30 PM
Castrol Stop-Start oil
by Silver. 10/19/18 09:13 PM
5.7 vortex Fresh air hose?
by Serolim. 10/19/18 09:11 PM
New Oil Refiner (Frantz) purchased from Ed
by FlyNavyP3. 10/19/18 08:45 PM
1988 Dodge B250 Conversion Van Shocks?
by petes67bird. 10/19/18 08:44 PM
20KW Standby Generator Recommendations
by MParr. 10/19/18 08:15 PM
2003 Diamante, SHU 5W40, 6817m OCI
by Spetz. 10/19/18 07:48 PM
Can you tell a difference between a 305 and 350
by ram_man. 10/19/18 07:45 PM
Changing Fuids
by Snagglefoot. 10/19/18 07:38 PM
Subaru Forester tire pressure?
by Joeescape63. 10/19/18 07:30 PM
PC Duron Synthetic 5W40
by PeterPolyol. 10/19/18 06:43 PM
unreng, lzhome, keninger, Werdage, Frank_C
66249 Registered Users
62 registered members (94astro, AndyB, atikovi, Audios, 2dogs, audi_guy, 6 invisible), 979 guests, and 30 spiders.
Topics292,206
Posts4,876,094
Members66,249
Most Online2,494
Oct 17th, 2018
Coolant Reservoir Level In Winter #4626940
01/07/18 02:03 PM
01/07/18 02:03 PM
Illinois, U.S.A
RamFan Online sleepy OP
RamFan  Online Sleepy OP
Illinois, U.S.A
Quick question for you guys on an observation I made this morning. It's 22* here (finally warm!) and decided to do a quick once-over on the CX-5 while it was in the driveway. Everything was good to go, as expected, except for the coolant. On the reservoir tank it read about 2" below the low line, I popped the Rad cap and it was full to the top. Mind you this is on a cold engine.
The system is clearly full, I'm not having any external leaks and my UOAs don't indicate an internal leak. It seems as though the very cold temps are causing the fluid to be pulled into the block, I'm just surprised by the amount.
Any others notice this much variance with their reservoir tanks?
18 Giulia Ti Sport
+2.0l turbo - 2k - Factory fill & filter
16.5 CX-5 Touring
+2.5l - 49k - SynPower w/ Maxlife 0w20 - PureOne - 8k/1yr
Re: Coolant Reservoir Level In Winter [Re: RamFan] #4626946
01/07/18 02:13 PM
01/07/18 02:13 PM
North Carolina
Rat407 Offline
Rat407  Offline
North Carolina
To me the coolant level is supposed to be at the full line cold. It doesn't matter if it is summer time cold after sitting over night or winter cold. It should be at the full line cold. That is my understanding. When the engine has been off for it to cool down to existing outside temp.
2002 Silverado 5.3 0w-20 AMSOIL
Re: Coolant Reservoir Level In Winter [Re: RamFan] #4626950
01/07/18 02:16 PM
01/07/18 02:16 PM
SE British Columbia, Canada
Snagglefoot Online content
Snagglefoot  Online Content
There definitely is a coefficient of expansion for the fluid. How cold did it get and have you driven the vehicle yet.
SF
If you want the job done right......do it yourself.
Re: Coolant Reservoir Level In Winter [Re: RamFan] #4626951
01/07/18 02:16 PM
01/07/18 02:16 PM
MIchigan
Warstud Offline
Warstud  Offline
MIchigan
As the coolant heats up it expands and goes into the reservoir. When it cools it gets drawn back into the radiator. Just like cooking something on the stove with a pan half full. It gets hot enough it boils over.
Re: Coolant Reservoir Level In Winter [Re: Snagglefoot] #4626956
01/07/18 02:24 PM
01/07/18 02:24 PM
Illinois, U.S.A
Illinois, U.S.A
SF
We've had lows in the negatives for the past 7-10 days. Just yesterday morning was -10*F on the drive to the office. This morning it was driven 2 miles then parked in the driveway for about an hour and a half before I did the once-over.
18 Giulia Ti Sport
16.5 CX-5 Touring
Re: Coolant Reservoir Level In Winter [Re: RamFan] #4626961
01/07/18 02:37 PM
01/07/18 02:37 PM
Colorado Springs
Drew99GT Offline
Drew99GT  Offline
Colorado Springs
I've noticed this as well; if it's very cold, it will be w little low; once it warms back up into the 50s/60s, it's back to where it should be. Seems logical and normal to me.
Re: Coolant Reservoir Level In Winter [Re: RamFan] #4626963
01/07/18 02:37 PM
01/07/18 02:37 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
I observed the same thing with a VW golf, the system filled to the correct level at 70f in the garage (overnight) then put outside where it sat for 2 days.
It went down below 0f and took 200ml to bring it back up to the same level. I removed the excess once I knew exactly how much the difference was.
VW sometimes will flash a red coolant light meaning the coolant is low in very cold temps, the contacts were to high in the bottle, a revised bottle with the contacts lower is now regular production and for service and addresses this issue.
Re: Coolant Reservoir Level In Winter [Re: RamFan] #4626974
01/07/18 02:46 PM
01/07/18 02:46 PM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
The coolant does contract a little when it's really cold. I would make sure at freezing or 32F it's at cold full. If it's below cold full at 0F no big deal.
2015 Ford F250 w/Powerstroke
Re: Coolant Reservoir Level In Winter [Re: RamFan] #4626984
01/07/18 02:54 PM
01/07/18 02:54 PM
MIchigan
Warstud Offline
Warstud  Offline
MIchigan
Depends on the temp you added the coolant last. Full at 70 degrees wont be full at 10 degrees. Just like tire pressure.
Re: Coolant Reservoir Level In Winter [Re: Donald] #4627034
01/07/18 03:47 PM
01/07/18 03:47 PM
Illinois, U.S.A
Illinois, U.S.A
This is my thought as well.
18 Giulia Ti Sport
16.5 CX-5 Touring
Re: Coolant Reservoir Level In Winter [Re: RamFan] #4627086
01/07/18 04:32 PM
01/07/18 04:32 PM
Columbus,Nebraska
Yah-Tah-Hey Offline
Yah-Tah-Hey  Offline
Columbus,Nebraska
Fill the coolant reservoir to the full line and forget it.
Re: Coolant Reservoir Level In Winter [Re: RamFan] #4633147
01/13/18 01:33 AM
01/13/18 01:33 AM
VA
Thax Offline
Thax  Offline
VA
When its really cold, nearly every vehicle I service has low coolant in the reservoir. Ive come to expect it and top it off to the fill line on the reservoir. Seems to me as normal thermal contraction and expansion. As long as the radiator is filled all is well.
2000 Ford Explorer Limited 5.0L AWD
2018 KIA Soul EX 2.0L
ASE P2 Parts Specialist
AIA Import Part Specialist
KIA certified Senior Technician, Hybrid certified.
Re: Coolant Reservoir Level In Winter [Re: RamFan] #4634235
01/14/18 07:24 AM
01/14/18 07:24 AM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
After sitting overnight, I make sure the level is up to the cold mark. That's it and I do not worry where it ends up when the engine is warm.
The "thinking" man's friend.
Re: Coolant Reservoir Level In Winter [Re: Thax] #4636922
01/16/18 05:12 PM
01/16/18 05:12 PM
Illinois, U.S.A
Illinois, U.S.A
My thoughts exactly. Went down to the Mazda dealership and bought some FL22 ($25/gal!), this way I know with 100% certainty I've got the correct fluid for a top off.
18 Giulia Ti Sport
16.5 CX-5 Touring
Re: Coolant Reservoir Level In Winter [Re: RamFan] #4637061
01/16/18 07:34 PM
01/16/18 07:34 PM
CA
raytseng Offline
raytseng  Offline
CA
if your coolant doesnt have a leak then your fluid loss is evaporative and mostly water as it expands it pushes a volume of hot vapor out the overflow and as it cools it sucks back in dry air. ethylene glycols boiling point is much higher than h20 so the vapor is mostly h20. Your remaining coolant is therefore concentrated.
Therefore, if you are splitting hairs and concerned about the correct topoff, you should topoff with distilled water, not coolant.
