49 years ago today....
by pbm
14 minutes 6 seconds ago
Why do we care so much about oil?
by camrydriver111
24 minutes 46 seconds ago
Which one should I sell/keep?
by SevenBizzos
Today at 12:18 PM
What's Shakin' at Amazon Today?
by TheLawnRanger
Today at 11:43 AM
2018 Hyundai Accent
by zeke1985
Today at 11:15 AM
Fresh footage of my Corvette on-track
by dparm
Today at 09:41 AM
Hedge trimmer "resin solvent"
by Rand
Today at 09:21 AM
Micrometer-digital
by Gito
Today at 09:00 AM
MMO and LSPI?
by KCJeep
Today at 08:49 AM
Sludged 2010 Cobalt 2.2 making noises
by jk_636
Today at 08:32 AM
Now oil pump while I have the pan off?
by callbay
Today at 07:19 AM
Anyone Remember DMSO Solvent ?
by LoneRanger
Today at 06:52 AM
aluminun bed in f150 pick um ups
by edwardh1
Today at 06:29 AM
Lawnmower 2cycle and 4cycle fuel
by Greaser73
Today at 04:00 AM
Rotella T6 5W40, 5000Mi, 1991 Ford 460 - RV
by MutantGarage
Today at 12:23 AM
2013 SUBARU Outback, M1EP 0w20, 14190mi, 74465 tot
by NO2
Yesterday at 11:52 PM
91 Ford 460 - noisy lifters at Idle when hot
by MutantGarage
Yesterday at 11:49 PM
Great deal on PP 5w30
by 60ampfuse
Yesterday at 11:48 PM
Motorcraft, 5W-30, 2425 miles, 2018 3.5 F EcoBoost
by cdlamb
Yesterday at 11:40 PM
Off-Road Trailer Tires
by troutfisher
Yesterday at 09:55 PM
TA128, Elantra16, Peterbilt52, CarllT100, 99SK04GTX
65515 Registered Users
87 registered (4WD, andyd, 2010Civic, AandPDan, 2004tdigls, 12 invisible), 1702 Guests and 30 Spiders online.
65515 Members
67 Forums
287355 Topics
Page 2 of 2 < 1 2
#4597415 - 12/07/17 06:53 PM Re: Newbie intro and guidance request [Re: Linctex]
Blinddog Offline
Loc: MI
Linctex, I like the idea of blocking exhaust ports and soaking the combustion side, I was heading in this direction originally but assumed I would have to do one cylinder at a time to close the valves.
Edited by Blinddog (12/07/17 06:54 PM)
#4597439 - 12/07/17 07:13 PM Re: Newbie intro and guidance request [Re: Blinddog]
Blinddog Offline
Loc: MI
Yes Kira, My proposal was to overfill the engine beyond piston height with Simple Green, pull plugs to prevent hydro lock, drop the exhaust to monitor what is coming by the pistons and occasionally roll the engine over by hand. Oldmoparguy, after Simple Green flush, my plan was to flush crankcase with mixture of diesel, oil and an alcohol (Drygas/911) using the same method as the Simple Green flush. Of course I would follow up with some quick oil changes as well. I hope you can expound on why you are opposed to non petroleum products being used. I know this is very out of the ordinary and I am unsure myself of the results/pitfalls. I would like to hear your thoughts and experiences. I have not yet committed to any method. Thanks again to all.
#4597519 - 12/07/17 08:49 PM Re: Newbie intro and guidance request [Re: Cujet]
Blinddog Offline
Loc: MI
On the contrary, I have run numerous test on carbon-ed pistons. After 24 hrs in SG the carbon is 98% gone without wiping or rubbing. After 48 hrs even the toughest carbon is completely gone. the active ingredient in Simple Green is Tetrapotassium pyrophosphate crystal, .05% Interestingly, the soap you get at the paint store for washing walls prepainting, TSP, is the same stuff, Tetrapotassium pyrophosphate crystal but at a 5% concentration. I have added the TSP soap to the Simple Green and now running a test with this solution to see if required soak time is decreased.
#4597749 - 12/08/17 06:03 AM Re: Newbie intro and guidance request [Re: Blinddog]
demarpaint Offline
Loc: NY
If you were to fill it with SG and allow it to soak overnight which SG would you use? The green or the light purple? Light purple is aluminum friendly, the green not as friendly. Would you plan on turning the engine over by hand around 12 hours into the soak?
My only concern would be my assurance of getting all the simple green out of the engine before even thinking of starting it up.
God Bless Our Troops
#4598618 - 12/08/17 10:26 PM Re: Newbie intro and guidance request [Re: demarpaint]
Blinddog Offline
Loc: MI
Been testing on aluminum piston in an aluminum pie tin with the green SG. I see a slight discoloration in the piston after soaking for 48 hrs. Still trying to figure the out the best process.
#4598634 - 12/08/17 10:51 PM Re: Newbie intro and guidance request [Re: Blinddog]
eyeofthetiger Offline
Loc: South Carolina
I think this could work. Do you plan on dropping the oil pan after the last flush? It would be good to clear it of loosened debris.
Re-oiling the engine will be the hard part. Of course you need a way to prime the oil system before running the engine again, and that will take care of the bearings, but oil may not get to every part that needs it right away. The Simple Green will have completely degreased things such as piston rings and cam lobes. That it, unless you follow the SG fill by completely filling the engine with some kind of oil. Let it "soak" in tge oil, then drain it and refill it with the normal engine oil capacity.
2017 Ford Fiesta 1.0T - Valvoline SynPower 5W-20, Motorcraft FL910S
1988 GMC K1500 4.3/700R4 - Supertech 15W-40, Fram TG3980
1986 Ford Ranger 2.0 - uhh
#4599124 - 12/09/17 03:36 PM Re: Newbie intro and guidance request [Re: Blinddog]
Kamele0N Offline
Loc: Slovenia EU
Rather invest into some ester based oil...and proceed with normal OCI...esters will clean your engine...
Or to avoid higher expenses...buy only 1-2 quarts of ester based engine oil and add that amount inro your sump...
2011 Hyundai i30 1.4 CVVT Shell Helix Ultra 5w40
1997 Toyota Landcruiser KZJ95 3.0 TD Shell Rimula R6M 10w40
#4600267 - 12/10/17 09:41 PM Re: Newbie intro and guidance request [Re: eyeofthetiger]
Trav Offline
Loc: MA, Mittelfranken.de
That's the easy part, you can either but a tank with hose or make your own for under $30 with an old tank with a few qts of oil in it.
A thread adapter, valve and hose to fit in the oil pressure switch port will prime the whole system.
Basically you are making this..
https://www.oreillyauto.com/detail/seale...ool/t40/4735487
#4600904 - 12/11/17 05:31 PM Re: Newbie intro and guidance request [Re: Blinddog]
Oil_Flunky Offline
Loc: Michigan
I like Kano Kreen and Rislone Concentrate for dirty engines, as they allow you to drive the vehicle as they clean. The Rislone Concentrate double dose and drive for 100 miles, or Kreen idle purge using the whole quart can might be in order here.
Oil, you need it. Oil snobbery, you don't need it.
#4617248 - 12/28/17 09:49 PM Re: Newbie intro and guidance request [Re: Oil_Flunky]
Blinddog Offline
Loc: MI
Thanks Trav, I cut a few corners and made a rather crude "primer". Fortunately, on the boxer engine the oil sensor is sticking straight up at twelve o'clock. It also accepted a 1/8" pipe thread 6" nipple. From there I used 1 1/2" PVC with threaded adapters and large caps on each end. I drilled and tapped each threaded 1 1/2"cap to fit the 1/8" nipple on one end and a quick disconnect on the other. PVC assembly attached to nipple, sticking straight up, removed threaded cap, filled with oil, replaced cap, attached regulated (30psi) hose and let it flow. Repeated multiple times. I feel much better now that the bearing and gallerys have been flushed and lubricated. Tomorrow I will attach the exhaust and fire it up.
In summary, I traveled to Missouri to work on this oil consumption issue, approx 1 quart to 400 miles. I brought a new PCV valve but I found the old one to still work so I decided to move forward with flush method that I proposed above. After bench testing with carboned pistons I found a 48 hour soak in Simple Green will completely dissolve the carbon without rubbing or brushing.
My procedure: Purchased a can of Kreen from Kano Labs and had my daughter throw 1/2 can into the oil and start the preflush. She put about 300 miles on the Subaru with the Kreen. I warmed the vehicle up, drained the oil, drained the oil filter and put it back in place. I removed the PVC and crankcase vent hoses so I could verify the level of the solvent. I also pulled the plugs and dropped the exhaust so I could monitor what was coming into the combustion chamber. I then (over) filled the crankcase in an attempt to completely submerge the pistons. It took FIVE gallons of Simple Green and it eventually started coming out of the PCV threaded hole in the top of the engine. (I removed the PVC valve.) I observed that after 15-30 mins fluid began to drip out of two exhaust ports. After a longer period of time fluid started coming out of one of the spark plug holes. These two factors confirm that fluid was working its way past the piston rings. I let this soak for 48 hrs and I occasionally rotated the engine by hand to allow different valves to open and different cylinders to fill. After 24 hours I drained the solution, filtered it through a 400 and 200 micron filter, then refilled the engine. At 48 hours I drained the Simple Green and then created a diesel mixture to flush out the SG. I mixed one quart of oil and one bottle of dry-gas to four gallons of diesel. Filled the engine again, waited two hours occasionally baring the motor over. Drained that out. I attached my homemade primer mixed a dash of Kreen and a dash of dry-gas with two quarts of oil and pumped it thru the system. Installed new filter, filled with oil and a dash of dry gas. Tomorrow I'll see if I can wake Frankenstein up. I'am thinking of running the engine for 15-20 mins with no load and change the oil. Maybe the second oil chance after a few hundred miles.
#4631145 - 01/11/18 08:08 AM Re: Newbie intro and guidance request [Re: Blinddog]
thorromig Offline
Loc: BerksCounty/Pa.
Did you do a compression test on the cylinders? Very interested in your feed back overall on your "project!!" My best friend has a 2005 Subaru Baja with the 2.5L NA & it does not consume oil any longer since we have been running a HM 5W30 motor oil through it on 4000 mile intervals. When I initially started changing the oil for her -- it would consume about a quart overall in a 4000 mile interval just using regular SN conventional 5W30. I realize your situation & hers is totally different. Just food for the thought. We also the last 5 or 6 oil changes have only been running the Wix made Super Tech oil filter on it. This year she estimates she will hit the 100 thousand mile marker on the motor & 5spd manual trans.
00 Dodge Ram 5.2L 4x4 Edge 10W30 FU (91K)
08 Acura TL Type S 3.5L PUPP 5W20 FU (101K)
17 Jetta TSI SE 1.4L Turbo - Edge 0W40 FU (Hers) (4K)
#4633108 - 01/12/18 11:35 PM Re: Newbie intro and guidance request [Re: Blinddog]
Marco620 Offline
Loc: Kansan,Heckler Koch fan
Kreen with a high detergent oil from Shell Pennzoil. Might try the Liquimoly Motor Oil Saver. Seems to clean really well. Ever thought of trying to use water vaporization through throttle body to try and loosen the crud.
2015 Civic 170k mi.0w20 Redline/Archoil,HPS SRI,Yokohama/Borla Exhaust/Vibrant Resonators #1790/Tein Suspension
Go Nashville Predators!
Page 2 of 2 < 1 2
