Weber gas grills & Weber 10 yr warranty
by Donald
07/18/18 05:50 PM
2008 Honda Odyssey oil and filter?
by CARJ
07/18/18 05:11 PM
Bugatti Veyron $21k oil change???
by wemay
07/18/18 05:07 PM
Nexen N Priz AH8 vs Hankook Ventus V2 Concept
by ET16
07/18/18 04:48 PM
1999 LeSabre to 2008 Lucerne
by Duffyjr
07/18/18 04:26 PM
Engine Oil "catch cans"
by TnMike46
07/18/18 04:17 PM
2018 Audi S4 4.5k mi Factory Fill
by Vigg
07/18/18 03:46 PM
RAGBRAI 2018
by DriveHard
07/18/18 03:23 PM
Bat houses?
by PW01
07/18/18 01:55 PM
Hub Centering Rings
by Char Baby
07/18/18 12:48 PM
Bad Discount Tire experience
by dwgwater
07/18/18 12:08 PM
2007 Accord coupe V6
by aquariuscsm
07/18/18 11:49 AM
Mystery Oil
by Zee09
07/18/18 10:52 AM
Mobil 1 EP good enough for non-aggressive drivers?
by Jasper8146
07/18/18 10:49 AM
2011 Durango 5.7L 125K PPHM 0W20 3K W/ Towing
by Mathew_Boss
07/18/18 10:27 AM
Eric The Car Guy's Mobil 1 AP Test
by camrydriver111
07/18/18 10:19 AM
Alignment: loading suspension in sloped driveway
by zorobabel
07/18/18 10:14 AM
Very Impressed with Fram Qualityc- CH10160
by rooflessVW
07/18/18 09:49 AM
Costco Canada Bridgestone Sale
by IndyIan
07/18/18 09:33 AM
Buying oil overseas, shipping to the US?
by d00df00d
07/18/18 09:23 AM
RYCOJO, Gunplt, bjay, javylsu, Jlb27537
65503 Registered Users
88 registered (Aero540T, 300m2000, 2015_PSD, 2009Edge, 12 invisible), 1499 Guests and 32 Spiders online.
65503 Members
67 Forums
287286 Topics
#4633011 - 01/12/18 09:10 PM 02 Frontier transmission question
milehigh Offline
formally milehighhyundai
Loc: CO
Hi all. I acquired a fixer upper 2002 Nissan Frontier this past week. It is a crew cab, 4wd and supercharged 3.3L that has 180k miles. Aside from the cosmetic issues that I purchased as a fixer upper, I have a question/concern about the AT.
First off, I have checked the fluid level and it is fine, and the color looks good with no nasty odor.
What I have noticed is a couple of things. The transmission takes about 3 or 4 seconds to engage into Drive. It is worse when the transmission is cold. Additionally, the shifting is very rough from 1st to 2nd, it feels much like a shift kit was installed. This too is much worse when cold, still occurs when warm but more muted. Also, when cold the shift from 2nd to 3rd will occasionally flare.
I plan to do a pan drop and filter change in the coming week. It is a Jatco 4speed, and requires Nissan J-matic fluid.
From what I have read is these are pretty stout AT's. Do ya'll think that a fluid change will resolve these issues? What transmission fluid and/or additives should I try? This truck will only see about 5-6k per year.
Thank you!
#4633033 - 01/12/18 09:27 PM Re: 02 Frontier transmission question [Re: milehigh]
bmwtechguy Online   content
Loc: South Carolina
Depending on whether it has a drain plug or easy access to ATF cooler lines (for an easy complete flush), I would do a fluid change/flush with Maxlife transmission fluid or other compatible fluid. See how it shifts after 20 miles or so. If still a bit harsh, you could add Lubegard Platinum. I also like Lubegard Red. I have added one of those to nearly every transmission service with great results for 25 years.
#4633111 - 01/12/18 11:38 PM Re: 02 Frontier transmission question [Re: milehigh]
boom10ful Offline
Loc: California
Thank you!
The harsh shift is normal for these transmissions. I have 2 of these right now a '98 and an '02 with 4 cylinder engines and they both kick when cold. I've used Valvoline Full Synthetic and had no problems.
Check and adjust your throttle cable if needed. Tighten until you see the butterfly move then go back until it's not open. Also check your throttle position sensor for the correct adjustment.
#4633489 - 01/13/18 10:34 AM Re: 02 Frontier transmission question [Re: milehigh]
ZebRuaj Offline
Loc: MN
Sounds about normal for my my father's 03 3.3 non boost. Everything feels slower and more mechanical.
Be happy you have boost. The 3.3 non boost is a slow turd.
~Shade tree mechanic for friends and family.
#4634019 - 01/13/18 08:49 PM Re: 02 Frontier transmission question [Re: milehigh]
milehigh Offline
Loc: CO
Thank you all. I'll be swapping with Maxlife and I picked up a bottle of Lubegard Platinum today. I'll report back next week with an update.
