Greetings All-
my 04 Vibe/Toyota Matrix/Corolla 1.8 lit up CEL. Stored Code was PO133- O2 sensor (front) slow response. Toyota TSB indicated likely cause was a leaking intake manifold gasket in cold weather (common problem). My question: why code PO133 (slow O2 response) and not PO171 (lean mixture)? PO171 makes a lot more sense than a slow responding O2 sensor.
Repair is very simple and minimal cost ($3.50) for Fel-Pro Gasket.
