Goodbye Encore, hello Soul!
by csandste
04/21/18 12:34 PM
7.3 drain plug torque
by mobilaltima
04/21/18 12:26 PM
'09 Kia Sedona - to change or not to change (oil)?
by Number_35
04/21/18 12:19 PM
I Think Spring Is Finally Here
by Warstud
04/21/18 11:48 AM
NAPA GOLD 7055 UN USED CUT OPEN
by car51
04/21/18 11:26 AM
Broken Cat
by Stelth
04/21/18 10:32 AM
How often do you use your moonroof?
by mclasser
04/21/18 10:29 AM
Weird Electrical Issue.
by George7941
04/21/18 09:35 AM
Ever puchase movies from cable provider?
by ZZman
04/21/18 09:31 AM
Mann HU 711/51 X oil filter for Miniís $6.50 Amzn
by 1JZ_E46
04/21/18 09:30 AM
M1 Oil For My Trucks Engine
by BlueOvalFitter
04/21/18 09:30 AM
Toyota SofTex upholstery
by CincyDavid
04/21/18 09:09 AM
Castrol Dexron VI $5 QT at AA
by The_Cams
04/21/18 08:41 AM
Liqui moly engine flush
by gallydif
04/21/18 08:27 AM
Uneasy about Bosch Cartridge Filter
by tc1446
04/21/18 07:36 AM
Harvest King 0w20 Full Synthetic
by oilstudent24
04/21/18 07:22 AM
oil spec.
by ernied
04/21/18 07:03 AM
Great dog story to start your day!
by AZjeff
04/21/18 06:51 AM
BITOGers in the wild west
by Shannow
04/21/18 03:54 AM
'10 Wrangler 5,350 Miles Cam2 5w30 Synavex
by montero1
04/21/18 03:31 AM
puma4440, zeroyon223, wade12345, rdatman, mowermon
64805 Registered Users
82 registered (andyd, alphadog, Astro14, 2015_PSD, aquariuscsm, 1JZ_E46, 4 invisible), 1814 Guests and 45 Spiders online.
64805 Members
68 Forums
282065 Topics
#4632780 - 01/12/18 06:20 PM PO133 vs. PO171 Leaking Intake Manifold Gasket
willbur Offline
Loc: sw ohio
Greetings All-
my 04 Vibe/Toyota Matrix/Corolla 1.8 lit up CEL. Stored Code was PO133- O2 sensor (front) slow response. Toyota TSB indicated likely cause was a leaking intake manifold gasket in cold weather (common problem). My question: why code PO133 (slow O2 response) and not PO171 (lean mixture)? PO171 makes a lot more sense than a slow responding O2 sensor.
Repair is very simple and minimal cost ($3.50) for Fel-Pro Gasket.
#4632808 - 01/12/18 06:38 PM Re: PO133 vs. PO171 Leaking Intake Manifold Gasket [Re: willbur]
das_peikko Offline
Loc: San Antonio, TX
Nevertheless, as long as you're not getting coolant mixed in with your oil, you should be happy.
#4632837 - 01/12/18 07:04 PM Re: PO133 vs. PO171 Leaking Intake Manifold Gasket [Re: willbur]
Leo99 Online   content
Loc: NJ
I replaced that gasket on my Corolla due to a CEL. I forget the code number. It is a very simple repair.
Without data you're just another person with an opinion. W. E. Deming
2003 Corolla 250,000 miles
2004 Rav4 333,000 miles
2015 Camry 40,000 miles
#4632876 - 01/12/18 07:36 PM Re: PO133 vs. PO171 Leaking Intake Manifold Gasket [Re: willbur]
Rolla07 Offline
Loc: MTL, CANADA
I did get the PO171 about 4 years ago. The P0133 could be linked to same thing. If you never replaced the gasket, may as well replace it first and clear the code and see if it comes back. If you havent done it yet.. it wont hurt to clean the MAF airflow sensor and the throttle body if it hasnt been done in awhile. Not to say its linked to your issue.
Edited by Rolla07 (01/12/18 07:36 PM)
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
#4632908 - 01/12/18 07:57 PM Re: PO133 vs. PO171 Leaking Intake Manifold Gasket [Re: willbur]
barkingspider Offline
Loc: socal
Replace the manifold gasket and the tensioner o ring, clear the code and see if it comes back. If it does, u may need new O2 sensor
06 Cadillac Escalade Ext
17 Cadillac ATS (wife)
05 Toyota Camry (daughter)
11 GMC Canyon off-road (daily)
#4633007 - 01/12/18 09:03 PM Re: PO133 vs. PO171 Leaking Intake Manifold Gasket [Re: barkingspider]
willbur Offline
Loc: sw ohio
Thanks All-
I initially bought an O2 sensor (OE Denso) thinking since the car has 120k miles on it, the O2 sensor has got to be lazy and responding slowly and it would not hurt to replace it. The PO133 code convinced me, too. I have been aware for a long time the leaking intake gasket is a known problem but because the car ran so well (and still does), why mess with it. I guess now is the time.
Just curious about the codes..
