A Leaf in my Oil Bottle!
by Scout1
01/22/18 12:11 AM
Spark Plug Socket
by The Critic
01/21/18 10:55 PM
allen (hex) wrench sets
by spasm3
01/21/18 10:05 PM
Oil Disosal Mineral versus Synthetic
by gahorn
01/21/18 09:54 PM
Kia optima sx 2.0 GDI turbo 5w-40
by timur38
01/21/18 09:12 PM
Here it is!!! First TGMO 0W-16 UOA 2018 I4 Camry
by kaminski54
01/21/18 09:00 PM
Valvoline synpower/ maxlife synpower OCI miles??
by ZraHamilton
01/21/18 08:33 PM
Contacting Me for Amsoil
by Pablo
01/21/18 07:39 PM
Pentosin Oils
by dogememe
01/21/18 07:24 PM
57.000 miles Nissan Sentra, basic maintenance
by sirgerman
01/21/18 06:36 PM
Hi-vis Jacket for Next Riding Season ...
by LoneRanger
01/21/18 06:25 PM
popcorn maker
by zrxkawboy
01/21/18 05:55 PM
Ravenol or Bizol full synthetic motor oil
by BKTX
01/21/18 05:53 PM
Home Buys Columbus, OH closeout oils
by skyactiv
01/21/18 05:27 PM
2 mile sniper kill
by Malo83
01/21/18 04:46 PM
2016 Volvo XC60 - "Don't be that dad"
by rooflessVW
01/21/18 04:28 PM
2017 Mustang 5.0 Oil Advice
by Passport1
01/21/18 04:00 PM
"Raw" water is now a thing...
by 5AcresAndAFool
01/21/18 03:31 PM
Champion Labs PH400 CUT OPEN (UNUSED FILTER)
by car51
01/21/18 03:14 PM
NAPA PLATINUM and Fran XP fails
by Gixxer8989
01/21/18 03:13 PM
nielkfj, moshe, shooter667, Antozik, Toddytt
63989 Registered Users
25 registered (CleverUserName, bbhero, Antozik, carloz, Boczech, ctechbob, 1 invisible), 914 Guests and 13 Spiders online.
63989 Members
65 Forums
277033 Topics
#4631321 - 01/11/18 10:54 AM Best oil for 1999 Lexus GS300? Need opinions...
joshua777 Offline
Loc: San Diego, CA
I know this topic has been beaten over the head 1,000 times and trust me I've read every forum, many being from yeeeaaarrrrs ago. I currently have 196,XXX miles on my 1999 GS300 and have used Mobil 1 High Mileage Full Synthetic 5W-30 for about 2 years now. It's great, but I still burn through about 1 quart every 5,000 miles. I've been thinking about switching over to 10W-30 in a few months, since I live in San Diego, and summer weather will be here before I know it. When I make the switch, I was wondering opinions on Pennzoil Platinum High Mileage 10W-30 and Mobil 1 10W-30 High Mileage Full Synthetic. I want to get other's opinions, say money is no object when choosing between the two, which one would you guys recommend? I've recently read claims that Pennzoil is better and keeps the engine cleaner, and just helps maintain better than Mobil 1, but it's impossible to get non-sponsored opinions in 2018.
Edited by joshua777 (01/11/18 10:55 AM)
Edit Reason: typo
#4631358 - 01/11/18 11:31 AM Re: Best oil for 1999 Lexus GS300? Need opinions... [Re: joshua777]
raytseng Offline
Loc: CA
i have a 1998 gs300. it did well on Pp and pup 5w30 normal. One oci i used m1 and had increased consumption.
However this engine still needed a .5qt topoff say halfway through my 7500oci. At the end of the oci the stick was in thr middle and ready to change.
I would suggest you try a different brand and stick with spec. Obviously M1 isnt making you happy. I don't know why you are staying loyal to it and going so far as to go offspec before trying a non m1. If it turns out the same on PP at least you know.
Edited by raytseng (01/11/18 11:35 AM)
#4631383 - 01/11/18 11:46 AM Re: Best oil for 1999 Lexus GS300? Need opinions... [Re: joshua777]
Anthony Offline
Loc: GA
I would keep running M1 HM and move to their 10w40 grade.
95 Nissan Hardbody V6 - M1 HM 5w30
13 Nissan Titan - Pennzoil Platinum 5w30
17 Ford Mustang GT - Pennzoil Platinum 5w20
#4631385 - 01/11/18 11:47 AM Re: Best oil for 1999 Lexus GS300? Need opinions... [Re: joshua777]
raytseng Offline
Loc: CA
As far as the engine and performance and perceived cleanliness, I've found the engine to run slightly better if the fuel has some ucl. Also the rest of your maintenance is going to play a larger role over your oil.
As far as fuel, in particular shell vpower was smoother than chevron premium. I think the shell addpack has more ucl.
Or if you want to roll your own, using maintenance level dose of redline si1 with any station is best at providing the increased smoothness (and injector cleaning)
Note I've driven and maintained my gs for 20years so buttdyno is finely calibrated so take my experience and expertise into account. Of course its your car so do whatever you want with it.
Edited by raytseng (01/11/18 11:56 AM)
#4631410 - 01/11/18 12:04 PM Re: Best oil for 1999 Lexus GS300? Need opinions... [Re: joshua777]
CT8 Offline
Loc: Idaho
Oil is oil .Try different brands 1qt in 5,000 miles isn't bad and what is the causeof the oil consumption if not the oil brand or type.
#4631473 - 01/11/18 01:07 PM Re: Best oil for 1999 Lexus GS300? Need opinions... [Re: joshua777]
Vlad_the_Russian Offline
Loc: NC
I had that engine in my IS300 and it definitely ran the happiest on 0w40 oils. Mobil1 0w40, if you wanna stay with the same brand, or Pennzoil Euro 0w40 at Walmart are good choices. Castrol 0w40 made the engine a bit more sluggish.
Just my 2 cents from personal experience with that engine. I even tried 0w20 in it, did not like it though. 0w30, 5w30, and 0w40 are your best bets. Some 5w40s made it too sluggish, just like Castrol 0w40.
#4631540 - 01/11/18 02:10 PM Re: Best oil for 1999 Lexus GS300? Need opinions... [Re: joshua777]
LeakySeals Offline
Loc: Hudson, NH
1 quart is not that bad considering the engine and year. Yes you may consume more M1 HM, but the reason is better flow. Want less consumption? Use a thicker poor flowing oil. You need to know why its consuming. If its rings or blocked oil control holes, HM oil won't help you. If its rubber valve seals (blue smoke at startup) then yes, it will help by plumping them up. When is the last time you replaced the PCV valve? I know that era had issues with the PCV system.
06 Escalade 6.0L AWD 155k. M1 EP 5w30 Fram TG
03 Maxima 3.5L Unknown miles ST 10w30
#4631598 - 01/11/18 03:19 PM Re: Best oil for 1999 Lexus GS300? Need opinions... [Re: CT8]
Leo99 Offline
Loc: NJ
Exactly. Try different oils and the best one might lessen the oil consumption to 25 oz per month instead of 32 oz.
My Rav4 uses a bit of oil. Maybe 1.5 qts every 5000 miles. I used whatever HM oil I can get for cheap. Right now it has Castrol green bottle in it. I find that switching oils works best for it. Next change will be ST HM and then maybe Pennzoil HM and then Valvoline Max.
Without data you're just another person with an opinion. W. E. Deming
2003 Corolla 250,000 miles
2004 Rav4 333,000 miles
2015 Camry 40,000 miles
#4631720 - 01/11/18 06:08 PM Re: Best oil for 1999 Lexus GS300? Need opinions... [Re: joshua777]
fdcg27 Offline
Loc: OH
A car of nearly twenty years with 200K using a quart in 5K isn't consumption at all.
I wouldn't even try to chase this down with different oil brands.
Won't likely matter.
All you can do is ensure that the PCV system is flowing properly and that the PCV valve itself is working.
Other than that, motor on in this fine old-school Toyota design and just dump in a quart every 5K.
The old GS and LS cars are very nice to drive and seem to hold up very well.
17 Forester 6K M1 AFE 0W20
12 Accord LX 78K M1 AFE 0W-20
09 Forester 95K M1HM 10W-30
01 Focus ZX3 118K PP 5W-20
96 Accord LX 104K T5 10W-30
95 318i
#4631771 - 01/11/18 06:44 PM Re: Best oil for 1999 Lexus GS300? Need opinions... [Re: joshua777]
JC1 Offline
Loc: Oshawa, Ontario Canada
Try some Liqui Moly Motor oil saver and keep using the M1 5w-30 HM.
https://products.liqui-moly.com/motor-oil-saver-3.html
2015 Grand Caravan SXT Plus 5w-20 PPPP/Wix Filter
1997 Honda Civic CX 5w-30 PPPP/Mahle Filter
#4631779 - 01/11/18 06:54 PM Re: Best oil for 1999 Lexus GS300? Need opinions... [Re: fdcg27]
maverickfhs Offline
Loc: VA
+1 Million, 1 quart after 5K is nothing. Cheap insurance and these cars are built like TANKS smile
2008 Civic EX 198K/AT
2003 Civic LX 155K/AT
2006 Acura TSX 172K/AT
2008 Civic LX 156K/AT
#4631795 - 01/11/18 07:10 PM Re: Best oil for 1999 Lexus GS300? Need opinions... [Re: joshua777]
Gebo Offline
Loc: VA
I'd use the Pennzoil in the 5w30 weight just for fun. It may not use as much oil or it may use more. You'll never know until you give it a try.
'98 LEX LS400 280K
'00 LEX GS300 190K
'02 4Runner 225K
'05 Lex LS430 80K
'06 Toyota Highlander 140K
'09 Lex IS350 80K
#4632685 - 01/12/18 04:58 PM Re: Best oil for 1999 Lexus GS300? Need opinions... [Re: raytseng]
joshua777 Offline
Loc: San Diego, CA
I've used Shell VPower, exclusively, for about 5 years now. I will never use any other gas, incredible stuff.
#4632688 - 01/12/18 05:00 PM Re: Best oil for 1999 Lexus GS300? Need opinions... [Re: fdcg27]
joshua777 Offline
Loc: San Diego, CA
Yeah that's basically how I feel, 1 quart every 5,000 isn't that bad. There's literally nothing wrong with the car. This is the biggest, and only, "problem."
#4636780 - 01/16/18 02:09 PM Re: Best oil for 1999 Lexus GS300? Need opinions... [Re: joshua777]
spiderbypass Offline
Loc: Stewartstown PA
Mobil 1 0w40 fs is hard to beat. Maybe 5w50 Mobil 1 fs ior 15w50 in Warmer temps.
Insecurity with overcompensation are the root of evil deeds.
