A Leaf in my Oil Bottle!
by Scout1
01/22/18 12:11 AM
Spark Plug Socket
by The Critic
01/21/18 10:55 PM
allen (hex) wrench sets
by spasm3
01/21/18 10:05 PM
Oil Disosal Mineral versus Synthetic
by gahorn
01/21/18 09:54 PM
Kia optima sx 2.0 GDI turbo 5w-40
by timur38
01/21/18 09:12 PM
Here it is!!! First TGMO 0W-16 UOA 2018 I4 Camry
by kaminski54
01/21/18 09:00 PM
Valvoline synpower/ maxlife synpower OCI miles??
by ZraHamilton
01/21/18 08:33 PM
Contacting Me for Amsoil
by Pablo
01/21/18 07:39 PM
Pentosin Oils
by dogememe
01/21/18 07:24 PM
57.000 miles Nissan Sentra, basic maintenance
by sirgerman
01/21/18 06:36 PM
Hi-vis Jacket for Next Riding Season ...
by LoneRanger
01/21/18 06:25 PM
popcorn maker
by zrxkawboy
01/21/18 05:55 PM
Ravenol or Bizol full synthetic motor oil
by BKTX
01/21/18 05:53 PM
Home Buys Columbus, OH closeout oils
by skyactiv
01/21/18 05:27 PM
2 mile sniper kill
by Malo83
01/21/18 04:46 PM
2016 Volvo XC60 - "Don't be that dad"
by rooflessVW
01/21/18 04:28 PM
2017 Mustang 5.0 Oil Advice
by Passport1
01/21/18 04:00 PM
"Raw" water is now a thing...
by 5AcresAndAFool
01/21/18 03:31 PM
Champion Labs PH400 CUT OPEN (UNUSED FILTER)
by car51
01/21/18 03:14 PM
NAPA PLATINUM and Fran XP fails
by Gixxer8989
01/21/18 03:13 PM
nielkfj, moshe, shooter667, Antozik, Toddytt
63989 Registered Users
17 registered (bbhero, gmh101357, Brad_C, CleverUserName, Antozik, Farmer, 1 invisible), 820 Guests and 12 Spiders online.
63989 Members
65 Forums
277033 Topics
Page 1 of 2 1 2 >
#4632675 - 01/12/18 04:49 PM What tire pressure to run?
HoosierJeeper Offline
Loc: WI
Feels like I've been posting a lot in this section lately... oh well, I'll try to stop eventually. smile
Walmart put 35PSI in my new tires (245/75/16 Hankook Dynapro ATMs, P rated). Does that sound about right for my Liberty? Weight wise I'm guessing it's probably around 4600-4800 lbs once you add in the winch, skid plates and rock rails. Door sticker is irrelevant at this point, I think, not a factory size. I'd do the chalk test but I'd have better luck playing pickup sticks with my butt cheeks than finding a dry section of pavement here for awhile. smile
15 Jeep KL Limited V6: VWB 5W20
07 LR3 SE V8: VWB 5W30
05 Jeep KJ Limited: Maxlife 5W30
96 Jeep XJ Country:Pennzoil HM 10W40
#4632693 - 01/12/18 05:02 PM Re: What tire pressure to run? [Re: HoosierJeeper]
StevieBoy Offline
Loc: Central Florida
My G.C. recommends 33/36 psi front/rear in 265/50R20's. Never heard of such a thing! What is the point of a 3 psi difference between front & rear?
2018 Grand Cherokee Limited
25th Anniversary Sterling Edition
#4632713 - 01/12/18 05:22 PM Re: What tire pressure to run? [Re: HoosierJeeper]
Loc: WI
My LR3 specs 33 in the front and 42 in the back!
#4632730 - 01/12/18 05:35 PM Re: What tire pressure to run? [Re: HoosierJeeper]
Jimzz Offline
Loc: NoVA
I do about 35 in the front and 33 in the rear.
yup
#4632785 - 01/12/18 06:26 PM Re: What tire pressure to run? [Re: HoosierJeeper]
Alex_V Offline
Loc: Campbellsville, KY
What is sidewall max PSI?
I'd probably run the fronts 4-6 PSI higher than the rears. The rears, primarily transmitting power to the ground, will have a tendency to wear in the center, where the fronts will tend to wear on the sides from doing the steering. The fronts also carry a bit more weight.
I like Chevy and Valvoline.
'13 Cruze, 1.4T, 109K
'85 GMC C3500, 454, 128K
'82 Mercedes 300CD, OM617 turbo, 164K
'67 Suburban, 350, 331K
#4632813 - 01/12/18 06:42 PM Re: What tire pressure to run? [Re: HoosierJeeper]
das_peikko Offline
Loc: San Antonio, TX
35PSI is the standard that most tire shops go by.
#4632825 - 01/12/18 06:53 PM Re: What tire pressure to run? [Re: HoosierJeeper]
Nick1994 Offline
Loc: Phoenix, AZ
The door sticker isnít for the dry stock weight of the vehicle, itís for the max loaded point of the vehicle too.
But I usually add a couple PSI. 36 psi in the Jeep and Sonata.
2015 Hyundai Sonata 2.4L 71k M1 AFE 0w30 & OEM
2000 Toyota Camry 2.2L 227k M1 AFE 0w30 & Wix
1996 Jeep Cherokee 4.0L 145k Napa 10w30 & Fram Ultra
#4632841 - 01/12/18 07:07 PM Re: What tire pressure to run? [Re: das_peikko]
Aero540T Offline
Loc: MI
Interesting. I worked at a tire shop for a little bit and we went by the door sticker as it varied by type of vehicle. As a general rule at least
2004 Jeep Grand Cherokee Limited 4.7L (wifeís) M1HM & PL
2002 Ford Taurus 24V M1HM & M1EP
2001 Dodge Ram 1500 5.9L 4x4 M1HM & M1EP
1993 Yamaha FZR 600
#4632868 - 01/12/18 07:31 PM Re: What tire pressure to run? [Re: HoosierJeeper]
Linctex Offline
Loc: Waco, TX
I wish a published list were available of tire psi BY POUNDS OF LOAD each tire carries!
My F150 is very front heavy, so gets more PSI in front tires, than in back.
#4632870 - 01/12/18 07:32 PM Re: What tire pressure to run? [Re: Aero540T]
Linctex Offline
Loc: Waco, TX
I have never ever seen a tire shop guy look at the door sticker.
35 psi is VERY common
#4632934 - 01/12/18 08:14 PM Re: What tire pressure to run? [Re: HoosierJeeper]
Loc: WI
I want to say max is 44. It's 0 degrees out so that's my best guess.
I would run different pressures front/rear but the tcase would pitch a fit, they have to be within a pound or two of each other for it to shift in/out of 4WD smoothly.
#4632938 - 01/12/18 08:16 PM Re: What tire pressure to run? [Re: Linctex]
Aero540T Offline
Loc: MI
I donít disagree. And it wasnít every vehicle as you start to figure it out. Most passenger cars were 32 if I remember correctly.
1993 Yamaha FZR 600
#4632946 - 01/12/18 08:19 PM Re: What tire pressure to run? [Re: HoosierJeeper]
JohnnyJohnson Offline
Loc: Wet side WA
My Hankook tires are rated at 51 PSI my car calls for 34 PSI. I run them at 40 PSI. Better MPG more than 0W-20 ever gave me. About a mile per gallon in town and a 2+ MPG increase on the open road.
2004 Toyota Corolla 116802
Out: Mobil 1 10-30 Bosch Premium
In: QSUD 5W-30 Purolator One 112500
2006 Duramax 73642
#4632989 - 01/12/18 08:51 PM Re: What tire pressure to run? [Re: das_peikko]
Dumc87 Offline
Loc: Florida
This.
When I first started airing up tires, I went by the door sticker. In a busy shop environment, you'd be surprised at how time consuming that can be. Some cars don't even have the sticker, or the numbers are illegible. For a myriad of nuance reasons, 35 PSI is a standard.
Now, some cars, like Corolla's, I can remember being around 32/33 PSI front and rear. If I notice I'm working on one of those, I'll put in 33 PSI. But I also realize that so many tires I work with, are being driven by a person who doesn't make it a habit of checking the air. So I end up putting 35 PSI in anyway, knowing it's better for the vehicle to be a tad over recommended PSI than being under; especially when MPG's are more important than handling, for most.
Edited by Dumc87 (01/12/18 08:55 PM)
'90 Z32 - PP HM 10w30
'98 ZJ - PYB HM 10w40
'02 G20 - QS UD 5w30
'09 Matrix - QS UD 0w20
#4632996 - 01/12/18 08:57 PM Re: What tire pressure to run? [Re: JohnnyJohnson]
Dumc87 Offline
Loc: Florida
When I do tire pressure checks, I sometimes ask what a person wants to run in their tires for this very reason. 40 PSI is pretty high for a Corolla, but if that's your preference and you've seen a good reason to do so, then 40 PSI it is.
Page 1 of 2 1 2 >
