No Poly-tics :) Rambling On
by Zee09. 10/20/18 08:10 AM
Michigan Police Vehicle Test Results
by tenderloin. 10/20/18 08:04 AM
1992 Olds Eighty Eight with 36,000 miles
by atikovi. 10/20/18 07:16 AM
ISUZU 3.9l Diesel 4bd1
by Wreckage. 10/20/18 04:11 AM
Repainted hood- when is it safe to wash and wax?
by PlzRepond. 10/20/18 01:23 AM
75w90 vs 75w140
by SnowDrifter. 10/20/18 12:38 AM
Wash and Spray Wax
by Marco620. 10/20/18 12:05 AM
Marine fuel injection musings
by OVERKILL. 10/19/18 09:45 PM
Finding a new mechanic
by AZjeff. 10/19/18 09:30 PM
Castrol Stop-Start oil
by Silver. 10/19/18 09:13 PM
5.7 vortex Fresh air hose?
by Serolim. 10/19/18 09:11 PM
New Oil Refiner (Frantz) purchased from Ed
by FlyNavyP3. 10/19/18 08:45 PM
1988 Dodge B250 Conversion Van Shocks?
by petes67bird. 10/19/18 08:44 PM
20KW Standby Generator Recommendations
by MParr. 10/19/18 08:15 PM
2003 Diamante, SHU 5W40, 6817m OCI
by Spetz. 10/19/18 07:48 PM
Can you tell a difference between a 305 and 350
by ram_man. 10/19/18 07:45 PM
Changing Fuids
by Snagglefoot. 10/19/18 07:38 PM
unreng, lzhome, keninger, Werdage, Frank_C
66249 Registered Users
74 registered members (beanoil, alarmguy, Audios, atikovi, 2003f7, Blueskies123, 7 invisible), 1,682 guests, and 26 spiders.
Topics292,212
Posts4,876,159
Members66,249
Most Online2,494
Oct 17th, 2018
High zink oil for built high boost cummins? #4628782
01/08/18 11:16 PM
01/08/18 11:16 PM
Conroe, TX
NVRENUFF Offline OP
NVRENUFF  Offline OP
Conroe, TX
I need to find a good oil for my 12v cummins. Itís fully built, 16:1 compression, roughly 65psi boost, 140# over stock valve springs with hardened pushrods. Originally built for a drag truck, now itís in what I want to be a daily driver and tow vehicle. Turned the power down to about 550-600, so nothing crazy. Just need some oil recommendations to help longevity with all the extra stress in the valve train.
Re: High zink oil for built high boost cummins? [Re: NVRENUFF] #4628786
01/08/18 11:29 PM
01/08/18 11:29 PM
Indiana
redneck47441 Offline
Indiana
On competition diesel they seem to be big on Brad Penn. I like Amsoil Marine seems to have alot of zinc.
Re: High zink oil for built high boost cummins? [Re: NVRENUFF] #4628807
01/09/18 12:05 AM
01/09/18 12:05 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Might want to go with softer valvesprings.
Re: High zink oil for built high boost cummins? [Re: Linctex] #4628938
01/09/18 08:08 AM
01/09/18 08:08 AM
Michigan
A_Harman Offline
A_Harman  Offline
Michigan
I agree. If you're not turning the engine over 3200 rpm, stock valve springs are fine. (As a matter of fact, the stock valve spring on a Cummins is designed with enough load margin to control the valve up to 50% above rated power rpm.) Extended idling and low rpm operation on the street puts a lot of contact stress on the cam.
1985 Z51 Corvette track car
2002 Camaro Z28 LS1/6-speed
2001 Dodge Ram 2500 diesel
1972 GMC 1500 shortbed project truck
Re: High zink oil for built high boost cummins? [Re: NVRENUFF] #4628975
01/09/18 09:13 AM
01/09/18 09:13 AM
Conroe, TX
NVRENUFF Offline OP
NVRENUFF  Offline OP
Conroe, TX
I was turning it to 4,800rpm, but doubt Iíll go over 4,000 now. Would like to keep the ability to play around a little. Lol.
Re: High zink oil for built high boost cummins? [Re: NVRENUFF] #4628977
01/09/18 09:15 AM
01/09/18 09:15 AM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
Yup, high spring pressures are there only to control ramp contact and prevent bounce or valve float. If operating in normal RPM range, I'd cut back on spring pressure too. Once the load is reduced, any premium HDEO with around 1,200 PPM ZDDP will be fine smile
Re: High zink oil for built high boost cummins? [Re: NVRENUFF] #4629222
01/09/18 01:16 PM
01/09/18 01:16 PM
Reno, Nevada
Langanobob Online content
Langanobob  Online Content
Reno, Nevada
Diesel engine builders have a deeply held belief that stronger valve springs are needed, not to prevent high RPM valve float, but to prevent high turbo induced manifold pressure from lifting valves off their seats at much lower than redline RPMís. Iím not a Diesel engine builder, just tossing this concept out there for discussion.
Re: High zink oil for built high boost cummins? [Re: Langanobob] #4629238
01/09/18 01:28 PM
01/09/18 01:28 PM
Texas
440Magnum Offline
440Magnum  Offline
Texas
That's an easy calculation. Manifold pressure in PSI multiplied by intake valve area in sq. inches is the amount by which the spring seat pressure in pounds is reduced due to pressure on the back of the valve.
'66 Dodge Polara & '69 Dodge Coronet R/T both 440/727
'08 Ram 1500 4.7/545RFE
'12 Challenger SRT8 392/6-speed
'99 XJ 4x4 4.0/AX15, '14 WK2 4x4 3.6/8HP
Re: High zink oil for built high boost cummins? [Re: 440Magnum] #4629523
01/09/18 06:13 PM
01/09/18 06:13 PM
Reno, Nevada
Reno, Nevada
Yeah but...the pressure on the combustion chamber side of the valves is never zero so to some extent there should be a compensating effect. That seems to be the opinion of automotive engineers who don't subscribe to turbo pressure lifting valves.
Re: High zink oil for built high boost cummins? [Re: NVRENUFF] #4629732
01/09/18 08:53 PM
01/09/18 08:53 PM
BrocLuno Offline
BrocLuno  Offline
You have to be making serious pressure to even be a factor in valve lifting. If you are making 2 atmospheres (30 PSI) on 1.5 sq in of valve surface and you have 120# of seat pressure, you still have over 50# of seat pressure which is all some engines have to start with.
And I have always had a devil of a time keeping head gaskets in engines with 30 PSI frown
I'm more worried about clamping pressure, than a valve wandering off the seat ...
Re: High zink oil for built high boost cummins? [Re: Langanobob] #4631926
01/11/18 10:45 PM
01/11/18 10:45 PM
Michigan
A_Harman Offline
A_Harman  Offline
Michigan
Let's think about the 4-stroke cycle, and when the intake valve(s) could be blown off their seat(s).
1. During the power stroke, cylinder pressure is obviously much higher than intake manifold pressure, peaking at ~2400 psi for a fairly modern diesel engine, and decreasing to ~180 psi at exhaust valve opening. So there is no way the intakes will be blown open.
2. During the exhaust stroke, after cylinder pressure has blown down to match exhaust manifold pressure, is the most likely time the intakes can be blown open. If exhaust manifold pressure is equal to intake manifold pressure, there is no net pressure force acting on the valve, so it remains seated with the net force of the valve spring closed load. In most turbodiesels, exhaust manifold pressure will be higher than intake manifold pressure due to the small turbine housing inlet area. But I expect in high performance applications where turbo lag is tolerated, intake manifold pressure can be higher than exhaust manifold pressure, so there may be a net pressure tending to blow open, but this would only be on the order of ~10 psi (as a guess).
3. During the intake stroke, the valves are open, so the issue is moot.
4. During the compression stroke, the valve closes, trapping the fresh charge air at some pressure close to intake manifold pressure. Then the ascending piston causes cylinder pressure to rise above intake manifold pressure, making it impossible for the valves to blow open.
On the other side of engine breathing, it is a real concern for exhaust valves blowing open in applications where exhaust brakes are used. Cummins used to have different exhaust valve springs for those applications, that had high seat loads. I recollect that 60 psi was the design pressure for those springs.
Re: High zink oil for built high boost cummins? [Re: NVRENUFF] #4638464
01/18/18 08:36 AM
01/18/18 08:36 AM
TX & ON
ofelas Offline
ofelas  Offline
TX & ON
The white stripe "60psi" marine springs are 150psi at the seat.
They are rated at 60psi above the stock 90psi springs.
Good to use 10 degree keepers & larger chrome moly locks with beehive springs, and doesn't hurt to use these with the "60psi" springs at higher rpms either.
91.5 W250-CTD/HDD
81 W150-318/9.5:1/pure 91/ZRT
01 Ram-360 Kenne Bell/pure 91/ATM
62 Savoy LW-413 MW-SS/13.5:1/VP110/RD30
