A Leaf in my Oil Bottle!
by Scout1
01/22/18 12:11 AM
Spark Plug Socket
by The Critic
01/21/18 10:55 PM
allen (hex) wrench sets
by spasm3
01/21/18 10:05 PM
Oil Disosal Mineral versus Synthetic
by gahorn
01/21/18 09:54 PM
Kia optima sx 2.0 GDI turbo 5w-40
by timur38
01/21/18 09:12 PM
Here it is!!! First TGMO 0W-16 UOA 2018 I4 Camry
by kaminski54
01/21/18 09:00 PM
Valvoline synpower/ maxlife synpower OCI miles??
by ZraHamilton
01/21/18 08:33 PM
Contacting Me for Amsoil
by Pablo
01/21/18 07:39 PM
Pentosin Oils
by dogememe
01/21/18 07:24 PM
57.000 miles Nissan Sentra, basic maintenance
by sirgerman
01/21/18 06:36 PM
Hi-vis Jacket for Next Riding Season ...
by LoneRanger
01/21/18 06:25 PM
popcorn maker
by zrxkawboy
01/21/18 05:55 PM
Ravenol or Bizol full synthetic motor oil
by BKTX
01/21/18 05:53 PM
Home Buys Columbus, OH closeout oils
by skyactiv
01/21/18 05:27 PM
2 mile sniper kill
by Malo83
01/21/18 04:46 PM
2016 Volvo XC60 - "Don't be that dad"
by rooflessVW
01/21/18 04:28 PM
2017 Mustang 5.0 Oil Advice
by Passport1
01/21/18 04:00 PM
"Raw" water is now a thing...
by 5AcresAndAFool
01/21/18 03:31 PM
Champion Labs PH400 CUT OPEN (UNUSED FILTER)
by car51
01/21/18 03:14 PM
NAPA PLATINUM and Fran XP fails
by Gixxer8989
01/21/18 03:13 PM
nielkfj, moshe, shooter667, Antozik, Toddytt
63989 Registered Users
18 registered (bbhero, Brad_C, CleverUserName, Antozik, Farmer, fields, 1 invisible), 840 Guests and 12 Spiders online.
63989 Members
65 Forums
277033 Topics
Page 2 of 2 < 1 2
#4629755 - 01/09/18 08:08 PM Re: Magnetic drain plugs and UOA sampling? [Re: CleverUserName]
UncleDave Offline
Loc: Ca.
Bhopkins - do you know about iso codes?
Fitermag claims they've done the test and its worth an iso code drop at minimum if not more.
UD
Uncle Dave
Cat 3126/2 MB3500/Titan/RX400H/17 Ridgeline
700HP V10/ 725HP BBC/ Raptor 700/ KFX450/ YZ250/Onan 8K/ Cat3011C
#4629832 - 01/09/18 09:27 PM Re: Magnetic drain plugs and UOA sampling? [Re: Linctex]
CleverUserName Online   content
Loc: California
Originally Posted By: Linctex
Originally Posted By: Snagglefoot
"M12x1.75x21 Magnetic Drain Plug ..... It includes a 5/16" diameter high temperature Neodymium magnet.
I don't stop with just one....
Magnets are 8mm N50 neodymium
This is the best and most cost effective option, however those of us who have cartridge filters canít use this method.
#4630967 - 01/10/18 10:15 PM Re: Magnetic drain plugs and UOA sampling? [Re: UncleDave]
BHopkins Offline
Loc: Utah
UD
I am unfamiliar with ISO particle count as a unit of measurement used in used oil analysis. I've never seen this on any of my UOA reports or any of those shared here on BITOG. Your question did lead me to again visit the Filtermag website and read much of their "science" that explains why they work. It's kind of ironic. Their claims of better results than an oil filter alone is based upon a 20 micron filter. But the kind of person that is so concerned about particles in their oil most likely aren't using a 20 micron oil filter.
2013 Subaru Outback 2.5i - Royal Purple 0W-20 & NAPA Gold filter
2003 Oldsmobile Alero 3.4 - M1 5W-30 & NAPA Gold filter
#4630985 - 01/10/18 11:33 PM Re: Magnetic drain plugs and UOA sampling? [Re: CleverUserName]
UncleDave Offline
Loc: Ca.
Not ironic at all. ISO codes are used by lots of industries as a measurement of particle contamination .
Machinery lubrication has excellent articles on the system as well you can look more here.
A real 20 micron filter is about as tight as you can get and still have it be a full flow.
A Real world example that would match would be a filtermag on Fram ultra thats a 20 [email protected] 99+ full flow filter.
UD
Edited by UncleDave (01/10/18 11:37 PM)
Uncle Dave
#4630989 - 01/10/18 11:48 PM Re: Magnetic drain plugs and UOA sampling? [Re: CleverUserName]
UncleDave Offline
Loc: Ca.
Unless you paid for particle count you wouldn't have got one on your UOA, but I bet if you look harder here you'll se one here and there, but most don't do it.
Here a link real oil analysis place so you can learn about the " science" .
https://polarislabs.com/what-is-particle-count/
The science is real. Did Filtermag run the test and are those results ? You either believe them or not like any other manufacturer
UD
Edited by UncleDave (01/10/18 11:51 PM)
Uncle Dave
#4631070 - 01/11/18 06:14 AM Re: Magnetic drain plugs and UOA sampling? [Re: CleverUserName]
alarmguy Offline
Loc: South Carolina
Originally Posted By: CleverUserName
I recently installed a dimple magnetic plug in my engine oil pan.
Has anyone ever tried taking the material captured on the magnet and re-introducing it back into the drained oil, mixing thoroughly, and then grabbing a sample for UOA analysis? If so, how did you do it?
Anybody see flaws in this idea, or have a better solution ?
Impossible to do, as others in here have said, it would be like trying to cut open a filter and dumping any metal back into the oil.
Makes no sense, even if it made sense, it would be impossible as any metal on the plug would not mix evenly back into the oil as those particles are now magnetized and will cling together.
I do understand your reasoning, Im a big believer in magnetic oil plugs but what you are trying to do is impossible.
Look at it no differently then using a high quality filter.
If your REALLY that set on knowing if the magnet changes the outcome of a UOA (which it wont) simply do a run without the magnet, the same thinking would be if one oil filter was much better then the other.
Hope this helps :o)
Again, Im a big believer in magnetic oil plugs but it is not going to affect the outcome of your UOA anymore then any oil filter.
I personally like the "goldplug" brand, I hate the price, price is retarded, but rock solid super strong magnetic oil plugs.
Linctex also gets an award with the magnets he places in his oil filter, quite unique idea. (photos are in this thread)
Edited by alarmguy (01/11/18 06:28 AM)
14 Road King (current)
08 VStar 1300 Tourer
07 Suzuki C50
Page 2 of 2 < 1 2
