No Poly-tics :) Rambling On
by Zee09. 10/20/18 08:10 AM
Michigan Police Vehicle Test Results
by tenderloin. 10/20/18 08:04 AM
1992 Olds Eighty Eight with 36,000 miles
by atikovi. 10/20/18 07:16 AM
ISUZU 3.9l Diesel 4bd1
by Wreckage. 10/20/18 04:11 AM
Repainted hood- when is it safe to wash and wax?
by PlzRepond. 10/20/18 01:23 AM
75w90 vs 75w140
by SnowDrifter. 10/20/18 12:38 AM
Wash and Spray Wax
by Marco620. 10/20/18 12:05 AM
Marine fuel injection musings
by OVERKILL. 10/19/18 09:45 PM
Finding a new mechanic
by AZjeff. 10/19/18 09:30 PM
Castrol Stop-Start oil
by Silver. 10/19/18 09:13 PM
5.7 vortex Fresh air hose?
by Serolim. 10/19/18 09:11 PM
New Oil Refiner (Frantz) purchased from Ed
by FlyNavyP3. 10/19/18 08:45 PM
1988 Dodge B250 Conversion Van Shocks?
by petes67bird. 10/19/18 08:44 PM
20KW Standby Generator Recommendations
by MParr. 10/19/18 08:15 PM
2003 Diamante, SHU 5W40, 6817m OCI
by Spetz. 10/19/18 07:48 PM
Can you tell a difference between a 305 and 350
by ram_man. 10/19/18 07:45 PM
Changing Fuids
by Snagglefoot. 10/19/18 07:38 PM
unreng, lzhome, keninger, Werdage, Frank_C
66249 Registered Users
78 registered members (BTLew81, alarmguy, Audios, atikovi, 2003f7, Blueskies123, 9 invisible), 1,607 guests, and 25 spiders.
Topics292,212
Posts4,876,155
Members66,249
Most Online2,494
Oct 17th, 2018
E85 Storage and Pump #4622589
01/03/18 11:25 AM
01/03/18 11:25 AM
Florida
Nrok83 Offline OP
Nrok83  Offline OP
Florida
Hi all,
I drive an 08 135i and have been running E50 since last year. The most diifult part of running E85 is storing it, transporting it and getting it into my tank. I've gone through 3 pump tansfers from amazon within a year. Any suggestions or options on storage and transfering? I buy 2 5 gallon tanks fill them up and that'll last me 3 weeks. Thanks
Re: E85 Storage and Pump [Re: Nrok83] #4622613
01/03/18 11:51 AM
01/03/18 11:51 AM
MN
tmorris1 Offline
tmorris1  Offline
MN
You can't just buy it at the pump and put it in your car?
Re: E85 Storage and Pump [Re: Nrok83] #4622620
01/03/18 12:01 PM
01/03/18 12:01 PM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
Originally Posted By: Nrok83
I drive an 08 135i and have been running E50 since last year. The most difficult part of running E85 is storing it, transporting it and getting it into my tank. I've gone through 3 pump transfers from amazon within a year. Any suggestions or options on storage and transferring? I buy 2 5 gallon tanks fill them up and that'll last me 3 weeks. Thanks
Is that a typo about E85? Doesn't your BMW owner's manual say:
Quote:
Do not fill the tank with E85, i.e. fuel containing 85% ethanol, nor with FlexFuel. Otherwise the engine and fuel supply system will be damaged.
You appeared to be confused about oil in your previous thread so maybe that carries over into fuel as well. Can you post some pictures of your storage and transfer setup for the fuel? I'd like to see what you've got.
1994 BMW 530i, 231K
1996 Honda Accord, 263K
1999 Toyota Sienna, 402K
2000 Toyota ECHO, 272K
Re: E85 Storage and Pump [Re: kschachn] #4622658
01/03/18 12:43 PM
01/03/18 12:43 PM
Florida
Nrok83 Offline OP
Nrok83  Offline OP
Florida
Sorry let me re-clarify some things. I'm running Ethanol fuel lines and an ethanol sensor prior to using the E85 (installed last year). The app tells me the exact content reading.
Here's the sensor:
http://www.fuel-it.biz/bluetooth-flex-fuel-analyzer/
Upgraded fuel lines:
http://www.fuel-it.biz/e-series-135i-and-335i-fuel-line-and-ethanol-sensor-upgrade/
Plus I upgraded my low pressure fuel pump to a stage 2 LPFP, because the factory one was weak and failing:
http://www.fuel-it.biz/e-series-bucketless-lpfp-upgrade/
Re: E85 Storage and Pump [Re: Nrok83] #4622686
01/03/18 01:16 PM
01/03/18 01:16 PM
Where the wind comes sweepin'
Reddy45 Offline
Reddy45  Offline
How is E85 turning into E50?
Re: E85 Storage and Pump [Re: Nrok83] #4622717
01/03/18 01:52 PM
01/03/18 01:52 PM
Des Moines, IA
Loi Offline
Loi  Offline
Des Moines, IA
He purchases E85 at the gas station and blends it in his car to 50% ethanol content. I just use VP Racing Jugs with the fill hose which can be bought on Amazon.
'05 GDB STI
'16 VAB STI
Re: E85 Storage and Pump [Re: Reddy45] #4622728
01/03/18 02:04 PM
01/03/18 02:04 PM
Florida
Nrok83 Offline OP
Nrok83  Offline OP
Florida
E50
In the picture I added is the sensor giving me the current ethanol rating in my tank. I always have it at E50, however today I need to run to the gas station. My problem is the gas station that sells the E85 is 25 miles away from my house (one way).
Re: E85 Storage and Pump [Re: Loi] #4622730
01/03/18 02:05 PM
01/03/18 02:05 PM
Florida
Nrok83 Offline OP
Nrok83  Offline OP
Florida
correct 93 50% E85 50% = E50
Re: E85 Storage and Pump [Re: Nrok83] #4622854
01/03/18 04:10 PM
01/03/18 04:10 PM
Reddy45 Offline
Reddy45  Offline
You can buy more fuel storage cans like the NATO 20ltr ones or you could buy a truck and install an aux fuel tank in the bed with a pump.
The former option would be cheap and portable and the latter would be quite expensive.
If you go a different route and buy a large fuel storage tank like an airport would have, then that could carry HOA or insurance implications.
Re: E85 Storage and Pump [Re: Nrok83] #4630194
01/10/18 10:38 AM
01/10/18 10:38 AM
MN
tmorris1 Offline
tmorris1  Offline
MN
E85 contains up to 85% alcohol, but it isn't always that. I have seen stations that say contains 50-85% ethanol. I think it varies from station to station how it is mixed.
Re: E85 Storage and Pump [Re: Nrok83] #4642615
01/22/18 09:18 AM
01/22/18 09:18 AM
Central Iowa
TiredTrucker Offline
Central Iowa
And seasonally. In my area, E85 is usually around 70% in winter months. Different states have different standards on this. Iowa demands that E85 has no less than 70%.
Freedom is not about having the choice to do what you want, but the choice to do what you ought.
