Received this nugget from a friend of mine. Below is the Ford Engineering Material Specification WSS-M2C171-F1
ENGINEERING MATERIAL SPECIFICATION
Date Action Revisions Rev. 0
2016 Aug 9 Draft C. E Richardson, NA
Controlled document at
www.MATS.ford.com Copyright © 2016, Ford Global Technologies, LLC Page 1 of 12
OIL, ENGINE, DIESEL, SERVICE FILL WSS-M2C171-F1
1. SCOPE
This material specification defines the minimum acceptable performance requirements and physical/chemical properties of all appropriate viscosity grades of engine oils to be used in Ford Motor Company vehicles in its global engine/vehicle service operations.
2. APPLICATION
This specification is released for all appropriate viscosity grades of service fill engine oils used for lubrication of compression ignition engines using diesel fuel. The Documentation, Performance Requirements and Quality Control subsections of the QUALIFICATION PROCEDURE apply only to engine oils supplied directly to Ford Motor Company
3. REQUIREMENTS
3.1 APPROVED SOURCES FOR FORD MOTOR COMPANY INTERNAL USE
This specification requires the use of approved sources. Only the sources identified on the Ford Approved Source List (ASL) can be used when this specification is listed on the drawing, CAD
file, or other documents. The list of approved sources is located within Ford at
www.mats.ford.com or available externally through a Ford Materials Engineer.
3.2 PERFORMANCE
Shall meet all the requirements of and be licensed to display API service category CK-4 and also meet additional Ford test requirements.
All required engine tests shall be conducted in accordance with the most recently approved procedures as described in ASTM Standards and the applicable ASTM Standards Research Reports and Information Letters. All tests under surveillance by ASTM must be conducted using test equipment monitored by and calibrated to the requirements of the ASTM Test Monitoring Center.
3.2.1 Mack T-11 (ASTM D7156)
3.2.2 Mack T-12 (ASTM D7422)
3.2.3 Cummins ISB (ASTM D7484)
3.2.4 Cummins ISM (ASTM D7468)
3.2.5 Caterpillar C13 (ASTM D7549)
3.2.6 Caterpillar 1N (ASTM D6750)
3.2.7 Roller Follower Wear (ASTM D5966)
3.2.8 Caterpillar C13 Engine Oil Aeration (ASTM D8047)
3.2.9 Volvo T-13 Oil Oxidation (ASTM D8048)
WSS-M2C171-F
Copyright © 2016, Ford Global Technologies, LLC Page 2 of 12
3.2.10 Valve-Train Wear, Ford Diesel Engine Test (Consult Ford Engineering for test requirements)
3.2.10.1 Ford Engineering should be notified prior to scheduling/conducting the Ford Valve-Train Wear test. Test requester shall also provide test information, including, test lab, formulation code and test identification number prior to the start of the test.
3.2.11 Additional requirements:
Preliminary approval may be granted without the valve train wear test based on evaluation of other data by Ford Motor Company. This could include but is not limited to the following:
3.2.11.1 Previously licensed CJ-4 formulation (licensed prior to January 1, 2016) that also meets and is licensable to CK-4.
3.2.11.2 Previously licensed CJ-4 formulation (licensed prior to January 1, 2016), with only the addition of an antioxidant boost to pass the T-13 test that also meets and is licensable to CK-4. All other engine tests beside the T-13 and D4037 aeration tests must have been conducted on the original un-boosted CJ-4 formulation. Based on the type of antioxidant boost used, level 1 or 2 support data must be provided to show the antioxidant boost will not degrade oil performance in the other tests. Any other formulation rebalancing due to the addition of the antioxidant must also be supported with data to show no degradation in performance in other tests.
3.2.11.3 Other testing conducted on the 6.7L engine may be used if approved by Ford Motor Company prior to testing. This can include, vehicle testing or, dynamometer testing.
3.2.12 Once the Valve-Train Wear Test is available to run, all formulations approved against the requirements of 3.2.11 must be run and pass the test to stay on the list of approved formulations. The test must be run within 6 months of the test becoming available. All required ASTM engine tests shall be conducted in accordance with the most recently approved
3.3 PHYSICAL/CHEMICAL PROPERTIES
3.3.1 High Temp/High Shear Viscosity at 150 °C 3.5 cP min (ASTM D4683)
3.3.2 Phosphorus (ASTM D5951) 0.10 - 0.12 % (minimum limit may be waived based on valve-train wear test results)
3.3.3 Sulfated Ash (ASTM D874) 1.0 % max
3.3.4 Noack Volatility (ASTM D5800) 13 % max
3.3.5 Seal Compatibility (ASTM D7216)
3.3.6 Physical Appearance and Odor Shall be clear and bright with no objectionable odor.
3.3.7 Contaminants
WSS-M2C171-F
Copyright © 2016, Ford Global Technologies, LLC Page 3 of 12
Shall be free of carcinogens, toxins, and metals not removed in refining or from previous use.
3.4 QUALIFICATION PROCEDURE
3.4.1 Documentation
Applicant must furnish to Fuels and Lubricants Engineering a completed and certified copy of the attached Supplement A and test reports demonstrating full compliance with all the requirements of this specification. The test reports must include results on both the candidate oil and the appropriate ASTM reference oils. The standard photographs of the test components are considered an essential part of the required test documentation. The oil sample code used for identification in each test document must be consistent. Any deviation in sample code
uniformity must be explained and shown on the cover of each test report. All tests must be certified by a qualified and authorized representative of the test facility. The applicant shall identify all the formulation changes and modifications that occurred in the test program that coincide with the tests listed in the ACC Monitoring Agency summary. Individual formulations should be listed in Supplement A, and for ACC registered tests, identified by the line item number and the formulation code. Fuels and Lubricants Engineering will review all data and determine if it adheres to the requirements of this specification. After review of the data, Fuels and Lubricants Engineering will notify the applicant of its decision in writing. If approved, the applicant will receive a letter of approval and will be placed on a list of approved formulations. At this time the applicant may display that their product is approve to this specification. If the applicant's formulation is not approved, Fuels and Lubricants Engineering will contact them in writing with the reason for rejection and additional sting/documentation necessary to continue reviewing the formulation.
3.4.2 "Read Across" Guidelines
It is recommended that all performance tests be conducted on the final formulation. The API Base Oil Interchangeability Guidelines and the API Guidelines for SAE Viscosity-Grade Read Across may be used. However, Fuels and Lubricants Engineering reserves the right deviate from tthese guidelines and additional testing or support data may be requested.
3.4.3 Fleet Testing
Materials which constitute a significant departure from conventional formulations, whether in base stocks, refining processes or additive packages, must be fleet tested, in addition to the
requirements outlined herein. These tests must include the type(s) of service judged to be affected by the difference in formulation technology. Fuels and Lubricants Engineering
should be consulted prior to testing.
3.4.4 Verification
Fuels and Lubricants Engineering reserves the right to conduct verification testing. If the test results do not support the originally submitted data, the fluid supplier must re-test the
product in coordination with Fuels and Lubricants Engineering. This re-test must be ENGINEERING MATERIAL SPECIFICATION WSS-M2C171-F Copyright © 2016, Ford Global Technologies, LLC Page 4 of 12 conducted and certified by a mutually agreed upon test facility.
3.4.5 Chemical and Physical Properties
Applicant shall furnish appropriate chemical and physical properties as required on Supplement A along with the manufacturing limits that apply to the material as requested.
3.4.6 Quality Control
The applicant and Fuels and Lubricants Engineering shall establish mutually agreed upon quality control limits to be listed in Supplement B. These will be used for ongoing product verifications at mutually agreed upon frequencies. The infrared absorption spectra of the approved material shall constitute the reference standard and shall be kept on file. All samples shall produce infrared curves that correspond to the reference standard when tested under the same conditions as those specified on the master curve.
4. GENERAL INFORMATION
The information given below is provided for clarification and assistance in meeting the requirements of this specification. Contact
[email protected] for questions concerning Engineering Material Specifications.
4.1 APPROVAL OF MATERIALS
4.1.1 FOR FORD MOTOR COMPANY INTERNAL USE
Suppliers desiring approval of their materials shall first obtain an expression of interest from Purchasing, Design or Product Development, and Materials Engineering. The supplier shall submit a completed copy of their laboratory test reports, signed by a qualified and authorized representative of the test facility, demonstrating full compliance with all the requirements of the Material Specification. Tested material samples must be available for review upon request and kept for a minimum of one year. Upon request, the supplier will review the associated quality control documents (Process Failure Mode and Effects Analysis, Control Plans, Certification testing) with Ford.
4.1.2 APPROVAL OF MATERIALS FOR THE APPROVED FORMULATIONS LIST
Oil marketers and additive companies desiring approval of their materials shall contract Fuels and Lubricants Engineering and provide the required documentation listed above using the supplements in this specification. Once the information is provided it will be evaluated by Fuels and Lubricants Engineering. Fuels and Lubricants Engineering will contact the provider in writing if the data provided is acceptable or if more information and testing is required.
4.2 SUPPLIER'S ONGOING RESPONSIBILITY
4.2.1 FOR FORD MOTOR COMPANY INTERNAL PRODUCTS
All materials must be equivalent in all characteristics to the material upon which approval was originally granted. Prior to making any changes to the material originally approved, whether or not such changes affect the material's ability to meet the specification requirements, the supplier shall notify the affected Supplier Technical Assistance (STA), Purchasing, and Materials
Engineering activities of the proposed changes (with reasons) by submission of a completed Suppliers Request for Engineering Approval, SREA. ENGINEERING MATERIAL SPECIFICATION WSS-M2C171-F
Copyright © 2016, Ford Global Technologies, LLC Page 5 of 12 For parts and components using Ford Engineering Material Specifications, all samples tested to the specifications for Design Verification (DV), Production Verification (PV) and Production Part Approval Process (PPAP) sign off must be kept until Job 1.
4.2.1 FOR THE APPROVED FORMULATIONS LIST
For any products on the approved formulations list, Fuels and Lubricants Engineering must be made aware of and approve any formulation changes, information provided on page 1 for supplement a, prior to these changes going into production. Fuels and Lubricants Engineering reserves the right to request testing or support data for any formulation changes.
4.3 RESTRICTED SUBSTANCE MANAGEMENT STANDARD
Substance restrictions imposed by regulations or Company direction applies to the materials addressed by this document. The restrictions are identified in the Restricted Substance Management Standard WSS-M99P9999-A1 which is updated yearly. It is the supplier’s responsibility to comply with this standard on a continuing basis through IMDS and or GMAP reporting. KV at 40 °C Additive In Finished Oil, Vol. % Name/Group Type Vol. % KV at 100 °C Sulfur, % ENGINEERING MATERIAL SPECIFICATION WSS-M2C171-F1 Supplement A / Page 1 of 6
Supplier Product Name
Product Code Viscosity Grade
Plant Location Date
Base Oils
________________________________________________________________________________________________
A.
B.
C.
D.
Refinery Name & Location Process Type Crude Source
A.
B.
C.
F.
D.
Formulation Additives
Additive /Type Mfg. Name Additive Code Description
E
page 6 of 12
G.
H.
I.
Signature / Title ____________________________________________________________________________________
Supplier
Product Name
Plant Location
MTAC
Requirements Specification Test Results
Mack T-11 Test (D7156)
Test # / date:
TGA % Soot at 4 cSt increase, 100ºC, min 3.5/3.4/3.3
TGA % Soot at 12 cSt increase, 100ºC, min 6.0/5.9/5.9
TGA % Soot at 15 cSt increase, 100ºC, min 6.7/6.6/6.5
Mack T-12 Test (D7422)
Test # / date:
Average Cylinder Liner Wear, μm max 24
Avg Top Ring Weight Loss, mg, max 105
Oil consumption gph, max Report
Cummins ISB Test (D7484)
Test # / date:
Slider Tappet Mass Loss, mg, max 100/108/112
Cam Wear, μm, max 55/59/61
Crosshead Weight Loss Rate & Report
Cummins ISM Test (D7468)
Test # / date:
Merit Rating, min 1000/1000/1000
Top Ring Mass Loss, mg, max 100/100/100
Crosshead Average Weight Loss, mg max 7.1
Oil Filter differential Pressure, kPa, max 19
Average Engine Sludge, min 8.7
Ave. Valve Adjustment Screw Weight Loss, mg max 4 5
Caterpillar 1N (D6750)
Test # / date:
Weighted Demerits, max 286.2/311.7/323.0
Top Land Heavy Carbon, %, max 3/4/5
Top Groove Fill, %, max 20/23/25
Oil Consumption, g/kW-hr, max 0.54/0.54/0.54
Ring/Liner Scuffing none
Date
page 7 of 12
WSS-M2C171-F1
Supplement A / Page 2 of 6
Product Name
Viscosity Grade
MTAC
1000 min
none
Report
Report
Report
Report
Roller Follower Wear Test (D5966)
7.6/8.4/9.1
11.8/11.8/11.8
Volvo T-13 Oil Oxidation Test (D8048)
125/130/133
75/85/90
Avg. Oil Consumption, 48 h to 192 h, g/h, max Report
Signature / Title _______________________________________________________________________________________
WSS-M2C171-F1
Supplement A / Page 3 of 6
Supplier Viscosity Grade
_____________________________________________________________________________________________________
page 8 of 12
Oil Aeration volume, 40 hr. to 50 hr., %
Kinematic Viscosity Increase at 40 oC, % max
IR Peak at EOT, Abs., cm-1
Caterpillar C13 Heavy-Duty Engine Oil Test (D7549)
Test # / date:
Oil Consumption
Top Groove Carbon
Top Land Carbon
Ford Valve-train Wear Test
(Consult Ford Engineering for specific requirements. Ford Engineering should be notified prior to scheduling/conducting any test. Test requester shall also provide test information, including, test lab, formulation code and test identification number.
Test # / date:
Test # / date:
Caterpillar-C13 Engine-Oil Aeration Test (D8047)
Product Code
Date
Second Ring Top Carbon
Test # / date:
Pin Wear, μm, max
Merits
Hot Stuck Rings
Product Name
Plant Location
Final
Formulation Code
Viscosity Grade
I. Base Stocks, vol. %
1)
2)
3)
II. Additive Treat, mass %
A)
B)
C)
D)
E)
III. New Oil Inspection
KV at 100°C, cSt
KV at 40 °C, cSt
VI
CCS Vis at (-)XX°C
NOACK , %
TBN
Ca
Mg
P
Zn
Ba
Mo
Ba
Na
N
Cu
Cl
Comments
Comments
Comments
Comments
Signature / Title _________________________________________________________________________________________
Elemental, mass % (report numerical values only)
IV. Engine/Bench Tests Conducted (list test conducted for each formulation)
page 9 of 12
WSS-M2C171-F1
Supplement A / Page 4 of 6
Product Name Product Code
Plant Location Date
Reblends/Reformulations
(-)XX = Appropriate temperature for the viscosity grade as shown is the latest SAE J300 Standard
_________________________________________________________________________________________________________
Supplier
Product Name
Plant Location
Physical/Chemical Properties
Mfg.
Specifications Results Limits
Kinematic Viscosity (D445), cSt
KV at 150 °C report
KV at 100 °C SAE J300
KV at 40 °C r e p o r t
Density, kg/L (D1298) report
CCS Viscosity at -XX °C, cP, (D5293) SAE J300
MRV Viscosity at -XX °C, cP, (D4684) SAE J300
MRV of Sooted Oil at -20 °C (D6896)
180 hr. oil sample, cP 25,000 max
Yield Stress of the 180 h used oil sample, Pa max < 3 5
Pour Point, °C (D97) report
Volatility at 250 °C, % (D5800) 13.0 max
HTHS Viscosity, cP at 150 °C, (D4683)
New Oil 3.5 min
Shear Stability after 90 passes shearing, (D7109)
mm2/s at 100°C, min
xW-30 9.3
0W-40 12.5
Other xW-40 12.8
HTHS viscosity at 150°C, (D4683), min xW-30 3.4
HTCBT at 135°C (D6594)
Copper, used oil increase, ppm 2 0 m ax
Lead, used oil increase, ppm 120 max
Copper Strip Rating, max 3
Foaming (D892)
Sequence I, mL 10/0 max
Sequence II, mL 20/0 max
Sequence III, mL 10/0 max
Phosphorus, % (D4951) 0.10 – 0.12
Sulfur, % (D4951) 0.40 max
Sulfated Ash, % (D874) 1.0 max
Total Acid Number (D664), mg KOH/g report
Total Base Number (D2896), mg KOH/g report
Total Base Number (D4739), mg KOH/g report
page 10 of 12
WSS-M2C171-F1
Supplement A / Page 5 of 6
Date
Viscosity Grade
Product Code
Elongation, %
Hardness, Points
Results Limits Results Limits
Volume Change, % +5/-3
Hardness, Points +7/-5
Tensile Strength, % +10/-TMC1006
+20/-30
Tensile Strength, % +10/-45
Elongation, % +10/-TMC1006
Volume Change, % +5/-2
Hardness, Points +8/-5
Tensile Strength, % +18/-15
Elongation, % +10/-35
Supplement A / Page 6 of 6
WSS-M2C171-F1
Product Name
Plant Location
Viscosity Grade
Product Code
Date
Test Results Mfg. Limits
Volume Change, % +TMC1006/-3
Hardness, Points +5/-TMC1006
Supplier
+7/-5
a. Nitrile/NBR
b. Silicone/VMQ
c. Polyacrylate/ACM
d. Fluoroelastomer/FKM
e. Vamac G
Nitrogen
Potassium
Sodium
page 11 of 12
Phosphorus
Zinc
Magnesium
Boron
Molybdenum
Calcium
Chlorine
Barium
Sulfur Other
Silicon
Copper
Elemental, mass %
Typical Range Typical Range
Phosphorus
Zinc
Calcium
Magnesium
Boron
Molybdenum
Sulfur
-XX = Appropriate temperature for the viscosity grade as shown is the latest SAE J300 Standard
Nitrogen
Copper
Elemental, mass %
Sequence I, mL
Sequence II, mL
Sequence III, mL
HTHS Viscosity, cP at 150 °C (D4683)
Foaming (D892)
Supplier
Plant Location
Product Name
Viscosity Grade
Product Code
Date
Supplement B / Page 1 of 1
WSS-M2C171-F1
page 12 of 12
Kinematic Viscosity at 100 °C, cSt 100 °C
Kinematic Viscosity at 40 °C, cSt
Density, kg/L, (D1298)
CCS Viscosity at -XX °C, cP (D5293)
Low Temp Pumping Viscosity at -XX °C (D4684)
Pour Point (D97), °C
Flash Point,°C (D93)
Volatility, Loss at 250 °C , % (D5800)
Potassium
Sodium
Chlorine
Barium
Other
Limits Frequency
Fuels and Lubricants Engineering concurrence ___________________________________________________________
