Quick question for you guys on an observation I made this morning. It's 22* here (finally warm!) and decided to do a quick once-over on the CX-5 while it was in the driveway. Everything was good to go, as expected, except for the coolant. On the reservoir tank it read about 2" below the low line, I popped the Rad cap and it was full to the top. Mind you this is on a cold engine.
The system is clearly full, I'm not having any external leaks and my UOAs don't indicate an internal leak. It seems as though the very cold temps are causing the fluid to be pulled into the block, I'm just surprised by the amount.
Any others notice this much variance with their reservoir tanks?
