1992 Olds Eighty Eight with 36,000 miles
by atikovi. 10/20/18 07:16 AM
ISUZU 3.9l Diesel 4bd1
by Wreckage. 10/20/18 04:11 AM
Repainted hood- when is it safe to wash and wax?
by PlzRepond. 10/20/18 01:23 AM
75w90 vs 75w140
by SnowDrifter. 10/20/18 12:38 AM
Wash and Spray Wax
by Marco620. 10/20/18 12:05 AM
Marine fuel injection musings
by OVERKILL. 10/19/18 09:45 PM
Finding a new mechanic
by AZjeff. 10/19/18 09:30 PM
Castrol Stop-Start oil
by Silver. 10/19/18 09:13 PM
5.7 vortex Fresh air hose?
by Serolim. 10/19/18 09:11 PM
New Oil Refiner (Frantz) purchased from Ed
by FlyNavyP3. 10/19/18 08:45 PM
1988 Dodge B250 Conversion Van Shocks?
by petes67bird. 10/19/18 08:44 PM
20KW Standby Generator Recommendations
by MParr. 10/19/18 08:15 PM
2003 Diamante, SHU 5W40, 6817m OCI
by Spetz. 10/19/18 07:48 PM
Can you tell a difference between a 305 and 350
by ram_man. 10/19/18 07:45 PM
Changing Fuids
by Snagglefoot. 10/19/18 07:38 PM
Subaru Forester tire pressure?
by Joeescape63. 10/19/18 07:30 PM
PC Duron Synthetic 5W40
by PeterPolyol. 10/19/18 06:43 PM
unreng, lzhome, keninger, Werdage, Frank_C
66249 Registered Users
79 registered members (53' Stude, 2dogs, 2009Edge, 65convertible, 69Torino, 94astro, 7 invisible), 1,208 guests, and 31 spiders.
Topics292,210
Posts4,876,103
Members66,249
Most Online2,494
Oct 17th, 2018
New formula Rotella (ck-4) for gas marine engines? #4623876
01/04/18 02:46 PM
01/04/18 02:46 PM
ca
monster1 Offline OP
monster1  Offline OP
ca
I've been running the older formula (cj-4)Rotella 15w-40 in my 04 volvo 4.3gxi. It doesnt appear that the new ck-4 rated oil has a sn rating like the cj-4. Is it rated for gasonline engines? Mire importantly, is it ok to run in marine engines?
Thanks
Re: New formula Rotella (ck-4) for gas marine engines? [Re: monster1] #4623916
01/04/18 03:19 PM
01/04/18 03:19 PM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
A lot of marine engines are flat tappet cams. Best to have >800 PPM ZDDP. So it's a searching game to find the HDEO with the right numbers.
Off the top of my head, I'd go with Delo 15W-30 SD (severe duty) as the go-to oil for a while. It's very well respected and has >1,000 PPM ZDDP and a food add pak. You motor should be fine on 30 at op temp unless it has a zillion hours on it ...
Re: New formula Rotella (ck-4) for gas marine engines? [Re: BrocLuno] #4623972
01/04/18 04:06 PM
01/04/18 04:06 PM
wv
krismoriah72 Offline
wv
Here is Chevron 15w30SD ran in a lexus UOA
https://bobistheoilguy.com/forums/ubbthreads.php/topics/4528999/1
Here is a side by side VOA of Rotella 5w40 beloved by all for 4 strokes.. CJ vs CK
https://bobistheoilguy.com/forums/ubbthr...SM_#Post4490450
Re: New formula Rotella (ck-4) for gas marine engines? [Re: monster1] #4623976
01/04/18 04:11 PM
01/04/18 04:11 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
a 2004 4.3 liter doesn't have a roller cam?!?!
Re: New formula Rotella (ck-4) for gas marine engines? [Re: monster1] #4624031
01/04/18 05:02 PM
01/04/18 05:02 PM
South Florida
bubbatime Offline
bubbatime  Offline
South Florida
It should have a roller cam.
The Rotella will be fine. It is no longer gas rated, BUT, it will be fine.
17 Chrysler Pacifica Mobil 1 5W30
13 Yamaha XT250 Valv MC 10W40
12 Suzuki S40 Rotella 15W40
10 Acura TSX 2.4 PZL Plat 5W30
06 GMC Sierra Nextgen 10W30
Re: New formula Rotella (ck-4) for gas marine engines? [Re: monster1] #4624097
01/04/18 06:11 PM
01/04/18 06:11 PM
ca
monster1 Offline OP
monster1  Offline OP
ca
That is correct. It has a roller cam.
Re: New formula Rotella (ck-4) for gas marine engines? [Re: monster1] #4624148
01/04/18 07:03 PM
01/04/18 07:03 PM
ca
monster1 Offline OP
monster1  Offline OP
ca
I guess I could switch to T6 5w-40. It's still gasoline rated.
Re: New formula Rotella (ck-4) for gas marine engines? [Re: monster1] #4624176
01/04/18 07:30 PM
01/04/18 07:30 PM
Fort Lauderdale, FL
DoubleWasp Offline
DoubleWasp  Offline
Fort Lauderdale, FL
A lot of this "gas rating" is due to additive level limits to protect catalytic converters. There is nothing in there that will hurt your engine. You have no catalytic converters.
Dump it in, and enjoy.
That's a roller engine for 100% certain.
Stick with a 40 oil. VP stopped using and recommending 30s in that engine for a reason.
If your engine does not have an oil cooler, then definitely stay away from 30. Oil gets nuclear hot in those engines under load.....fast.
Re: New formula Rotella (ck-4) for gas marine engines? [Re: monster1] #4624186
01/04/18 07:52 PM
01/04/18 07:52 PM
Ruidoso, NM USA
ammolab Offline
ammolab  Offline
Ruidoso, NM USA
Nope!
2009 Honda CR-V
2011 BMW R1200R
2005 Kaw Ninja 250
1994 Jeep Wrangler 2.5L
2016 Chevy SS Sport Sedan
Re: New formula Rotella (ck-4) for gas marine engines? [Re: ammolab] #4625519
01/06/18 02:24 AM
01/06/18 02:24 AM
ca
monster1 Offline OP
monster1  Offline OP
ca
They must not have changed the info on the website. Oh well. I'll just keep running this or chevron. Whatever is on sale.
Re: New formula Rotella (ck-4) for gas marine engines? [Re: monster1] #4625839
01/06/18 12:45 PM
01/06/18 12:45 PM
Central Wisconsin
dwendt44 Offline
dwendt44  Offline
Central Wisconsin
I doubt the formula has changed enough to worry about.
The change was the 'rating' over pressure by the government
and MFGs not wanting anything that might foul the converters.
There's no such thing as:
Too big of a battery,
Too large of a gas tank,
or too loud of a horn,
or too bright headlights.
