A Leaf in my Oil Bottle!
by Scout1
01/22/18 12:11 AM
Spark Plug Socket
by The Critic
01/21/18 10:55 PM
allen (hex) wrench sets
by spasm3
01/21/18 10:05 PM
Oil Disosal Mineral versus Synthetic
by gahorn
01/21/18 09:54 PM
Kia optima sx 2.0 GDI turbo 5w-40
by timur38
01/21/18 09:12 PM
Here it is!!! First TGMO 0W-16 UOA 2018 I4 Camry
by kaminski54
01/21/18 09:00 PM
Valvoline synpower/ maxlife synpower OCI miles??
by ZraHamilton
01/21/18 08:33 PM
Contacting Me for Amsoil
by Pablo
01/21/18 07:39 PM
Pentosin Oils
by dogememe
01/21/18 07:24 PM
57.000 miles Nissan Sentra, basic maintenance
by sirgerman
01/21/18 06:36 PM
Hi-vis Jacket for Next Riding Season ...
by LoneRanger
01/21/18 06:25 PM
popcorn maker
by zrxkawboy
01/21/18 05:55 PM
Ravenol or Bizol full synthetic motor oil
by BKTX
01/21/18 05:53 PM
Home Buys Columbus, OH closeout oils
by skyactiv
01/21/18 05:27 PM
2 mile sniper kill
by Malo83
01/21/18 04:46 PM
2016 Volvo XC60 - "Don't be that dad"
by rooflessVW
01/21/18 04:28 PM
2017 Mustang 5.0 Oil Advice
by Passport1
01/21/18 04:00 PM
"Raw" water is now a thing...
by 5AcresAndAFool
01/21/18 03:31 PM
Champion Labs PH400 CUT OPEN (UNUSED FILTER)
by car51
01/21/18 03:14 PM
NAPA PLATINUM and Fran XP fails
by Gixxer8989
01/21/18 03:13 PM
nielkfj, moshe, shooter667, Antozik, Toddytt
63989 Registered Users
18 registered (Bugize, bbhero, CleverUserName, gmh101357, Brad_C, Antozik, 1 invisible), 810 Guests and 12 Spiders online.
63989 Members
65 Forums
277033 Topics
Page 2 of 2 < 1 2
#4615362 - 12/27/17 05:51 AM Re: Removing water from tractor transmission-hydaulic [Re: Francis4344]
BlakeB Offline
Loc: Southeast
We have a 2940 JD that is used to grind and mix feed, it's basically stationary, only moving from one feed bin to the next. It is ran at WOT while mixing feed, but the transmission doesn't get hot enough to get rid of the moisture the hydraulic fluid accumulates. I drained the transmission (3 drain plugs and a little over 15 gallons) in October, I'm not sure how long this oil had been in service, but I'm guessing 4-5,000 hours, my PS and Hydraulics were not functioning well if at all on cold days.... or warm days in some cases. The strainer was nasty and the oil looked like pond water. I changed both hydraulic filters and cleaned the suction screen, then refilled with 15 gallons of new hydraulic oil. Then we had the dealership put a new pto bearing and seal in, they drained it again and refilled with new. They noted on the invoice that the hydraulic oil (which had been in service 1 day) was extremely contaminated. I haven't changed it again since, but it's been about 30-35 hours and the hydraulics have been better since I changed it than I ever remember them being. The hydraulics are still weak, but the 2940's aren't known for having real robust hydraulics to begin with. Plus it has over 12,000 original hours.
#4625057 - 01/05/18 02:57 PM Re: Removing water from tractor transmission-hydaulic [Re: Francis4344]
Badroberts Offline
Loc: Illinois
Assuming you are using a universal tractor hydraulic fluid, it will probably stay emulsified for a while. The chemistry of a UTHF is going to be different from a "regular" hydraulic fluid in that the UTHFs (that I have seen anyway) typically have a detergent/dispersant similar to a motor oil.
Typically a regular non-contaminated (as in contaminated by something that emulsifies like motor oil) is specified to separate out pretty much completely in a 50/50 mix in about 30 minutes.
It may separate some, but it is unlikely to separate completely.
Page 2 of 2 < 1 2
