I had this come into work today for a WoF (warrant of fitness) our road safety check. A blast from the past for me, I 've worked on a lot of Bedfords, one place I worked at had a fleet of them, and a couple of J1's for the workshop. Made from the JO, which was the smallest, powered by a Vauxhall car engine and drive line, up to the J6. The J1 had a 214 engine, almost the same as the 216 Chev engine, but full pressure bigends. Very popular back in the pirate tow truck days.
I was expecting the usual V8 conversion, but happy to see the stock 214 in there. The owner said he served his time (apprenticeship) at another company that had a fleet of them, so like me he doesn't want a hot rod, but the truck he drove and worked on in his youth.
This is a '78, so the road tube now goes into the oilbath airfilter. He's fitted an electric fuel pump, and electronic ignition.
Extractors, probably because the stock cast iron one was cracked. That's the wrong carb, it's off the 300cu engine. That small housing on the side is the govenor - we used to set them for 35mph in 3rd gear.
