Originally Posted By: Panzerman
Originally Posted By: kschachn
Originally Posted By: benjy
here in PA i use 10-30 group III oils mostly, no starting issues + better protection than the thinner xxW-20 when hot oils!!! on that note its known that any oil except real synthetic group IV PAO + group V ester + other oils continue to thin after the advertised viscosity tested @ 212F, + actually are thinner in hotter areas of an engine on a regular basis!!
Uhh, all oils continue to thin as the temperature is increased.
Exactly so why is everyone so concerned with using a super light weight oil for start up when that's Great but not so Great after a hour of heavy pulling. I am with Bengy 100%.
All this wear [censored] at start up, tell you what 100% of wear happens when metal touches metal, hot or cold.
Why did you call 20 wt oils "super light weight oil"? Heck, I was using 20 wt oils in the 60's and 70'S. Hundreds of thousands of truck owners use 20 WT oils in their tow vehicles. I also remember many years ago when 5-30 was considered Too light by some "who knew not what they speak of".
