1992 Olds Eighty Eight with 36,000 miles
by atikovi. 10/20/18 07:16 AM
ISUZU 3.9l Diesel 4bd1
by Wreckage. 10/20/18 04:11 AM
Repainted hood- when is it safe to wash and wax?
by PlzRepond. 10/20/18 01:23 AM
75w90 vs 75w140
by SnowDrifter. 10/20/18 12:38 AM
Wash and Spray Wax
by Marco620. 10/20/18 12:05 AM
Marine fuel injection musings
by OVERKILL. 10/19/18 09:45 PM
Finding a new mechanic
by AZjeff. 10/19/18 09:30 PM
Castrol Stop-Start oil
by Silver. 10/19/18 09:13 PM
5.7 vortex Fresh air hose?
by Serolim. 10/19/18 09:11 PM
New Oil Refiner (Frantz) purchased from Ed
by FlyNavyP3. 10/19/18 08:45 PM
1988 Dodge B250 Conversion Van Shocks?
by petes67bird. 10/19/18 08:44 PM
20KW Standby Generator Recommendations
by MParr. 10/19/18 08:15 PM
2003 Diamante, SHU 5W40, 6817m OCI
by Spetz. 10/19/18 07:48 PM
Can you tell a difference between a 305 and 350
by ram_man. 10/19/18 07:45 PM
Changing Fuids
by Snagglefoot. 10/19/18 07:38 PM
Subaru Forester tire pressure?
by Joeescape63. 10/19/18 07:30 PM
PC Duron Synthetic 5W40
by PeterPolyol. 10/19/18 06:43 PM
unreng, lzhome, keninger, Werdage, Frank_C
66249 Registered Users
69 registered members (65convertible, 53' Stude, 2009Edge, 69Torino, 94astro, 2dogs, 5 invisible), 1,134 guests, and 33 spiders.
Topics292,207
Posts4,876,100
Members66,249
Most Online2,494
Oct 17th, 2018
Torpedo heater on WVO #840134
02/21/07 10:09 PM
02/21/07 10:09 PM
Detroit, MI
crackerloco Offline OP
Detroit, MI
I currently use a 100K BTU ReddyHeater to heat my garage. Kerosene is $3-4 a gallon around here, and I really don't want to run #2 diesel inside the garage as I'd have to vent it more and it wouldn't be much cheaper than kerosene. I've heard that a cheap way to run one of these heaters on WVO is to heat up filtered oil on a hotplate, and stick the intake hose into the pan. Has anyone had any experience with this? I know good filtration is essential, and I have access to about 50 gallons/week of WVO so if I can get this setup to work it would save me about $60/month.
Re: Torpedo heater on WVO [Re: crackerloco] #840135
02/22/07 02:49 AM
02/22/07 02:49 AM
Frankfort, Kentucky
Shaman Offline
Shaman  Offline
Frankfort, Kentucky
I would check out the biodiesel.infopop.cc first. There is also a forum that does what you are saying, I think the name is something like biofuel for heating or something. Sorry, but the name escapes me.
It will take a good amount of work to get the WVO to runnable product. I donít know about the setup on the heater, but you need to get the junk and the water out for vehicles. Heaters may be different, I donít know.
Also, just found this in a link on infopop.
http://greasecar.com/forum_topicview.cfm?frmtopicID=324
Re: Torpedo heater on WVO [Re: Shaman] #840136
02/22/07 10:11 AM
02/22/07 10:11 AM
Frankfort, Kentucky
Shaman Offline
Shaman  Offline
Frankfort, Kentucky
Did some reading since I donít have any classes today. The important things that I found out are whether or not you have spark plug ignition or glow plug ignition. Also, it seems a lot of people are blending kerosene and WVO without many modifications, but when you try to run all WVO, you need to block flow of air in the back, heat the fuel with something, either a pot warmer, or some people have rigged the fuel hose to stick into the fire stream to preheat the fuel. I found the biodiesel/WVO/WMO for heating subforum on infopop and did some poking around.
Bio for heating
It looks like running 100% WVO will take some work. Read up and let me know what you decide.
Found the altfuels for home heating yahoo group
Altfuel
Re: Torpedo heater on WVO [Re: Shaman] #840137
02/23/07 05:01 AM
02/23/07 05:01 AM
Central Coast, Calif.
tom slick Offline
tom slick  Offline
I would be a little afraid of carbon monoxide from an improper mixture by messing with the fuel source.
Re: Torpedo heater on WVO [Re: crackerloco] #4174043
08/10/16 11:27 PM
08/10/16 11:27 PM
WA
DeafBrad Offline
DeafBrad  Offline
WA
One thought comes to mind... will you have oily residue everywhere?
Toyota Echo 250,000 + miles
Geo XFI 50+ mpg
Honda CBR250r 65+ mpg
Re: Torpedo heater on WVO [Re: crackerloco] #4196498
09/06/16 01:10 PM
09/06/16 01:10 PM
Ocala, Florida
racin4ds Offline
racin4ds  Offline
Ocala, Florida
I burn off road diesel in mine all winter with no issues whatsoever. Contrary to belief its all ULSD now and off road fuel is $1.89 a gallon. It burns just as clean as K1 does in my opinion. My garage isn't well insulated but I don't have any ventilation or windows cracked either. YMMV.
Just say NO to thin oils and M1!
05 F350 Powerstroke
05 Hyundai Tucson
08 Legacy GT
Re: Torpedo heater on WVO [Re: crackerloco] #4239550
11/02/16 06:48 AM
11/02/16 06:48 AM
PA
Gasbuggy Online happy
Gasbuggy  Online Happy
PA
Can you run waste engine oil in those?
CTS-V+Recaros 5w30 Magnatec
Volvo P1800 5w30 Euro L
Land Rover Series 10w40 VWB
76' 300D Edge 0w40
02 Yukon 10w30 MaxLife
95 Accord - 386k. Mobil 2 RIP
Re: Torpedo heater on WVO [Re: crackerloco] #4254296
11/21/16 10:55 AM
11/21/16 10:55 AM
down in the park
Jetronic Offline
Jetronic  Offline
down in the park
if you thin it out enough with kerosine, yes.
AR Giulietta 2.0 JTDM-2 -- Total Quartz 9000 Energy 0w30
Hankook Ventus Prime 2 215/50R17 (front)
Pirelli P7 Cinturato 225/45R17 (rear)
Re: Torpedo heater on WVO [Re: crackerloco] #4264310
12/03/16 02:41 AM
12/03/16 02:41 AM
Litchfield, Ohio
CDX825 Offline
CDX825  Offline
Litchfield, Ohio
Ive messed with different fuels in mine quite a bit. My experience with waste motor oil was a smokey garage. It burns but it smokes a bit. So that's not good. I would assume high levels of CO off of that.
Waste vegetable oil will work if you thin it with kerosene like mentioned. Works pretty good too.
Ive just been running on road diesel in mine. The dyed stuff stinks like crazy where as on road seems to burn just as clean as kerosene and here its significantly cheaper. Clear kerosene is 3.89 and diesel is 2.39
1984 Ford F250 6.9 Diesel C6 2WD Rotella T 15W40 NTZ Bypass Filter
1992 Ford F150 5.8 4x4 Rotella T5 10W30
Re: Torpedo heater on WVO [Re: crackerloco] #4595976
12/06/17 12:03 PM
12/06/17 12:03 PM
A Highway Near You
PiperOne Offline
PiperOne  Offline
A Highway Near You
I use regular on road diesel in mine as well. It's cheaper than kero and to me it burns with less odor and cleaner once you up the air pressure a bit. I have 2 flags that hang in my shop...when I used kerosene they needed washed every year to make the white, white again. Now they stay clean.
I like the idea of WVO tho!
HDEO in Diesel Engines. No spark plugs here.
Re: Torpedo heater on WVO [Re: crackerloco] #4600957
12/11/17 07:44 PM
12/11/17 07:44 PM
NE,Ohio
Rand Offline
Rand  Offline
NE,Ohio
For any kind of waste oil I think you need to go whole hog furnace style.. anything that burns nasty used oil isnt going to be clean enough for me without some sort of vent.
And that is more of a shop thing than a garage heater.
Re: Torpedo heater on WVO [Re: crackerloco] #4644791
01/24/18 10:32 AM
01/24/18 10:32 AM
Cincinnati, OH, USA
bullwinkle Online confused
bullwinkle  Online Confused
Cincinnati, OH, USA
Winterized on road diesel in mine, it's a small one, only 35K BTU-but the fuel cranked up until 1 inch flames come out the front of it! WVO would be a good idea if warmed first, it would smell like fries!
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
