i did put a new impeller in this spring and have 1 sitting on my shelf for the coming spring. I also did the tranny fluid when I changed the oil. I used a wix oil filter. Not sure where the fuel filter is yet but I probably won't do that one every year. I actually have a 1/2 closed system so the block is full of antifreeze - it was a huge reason why I got this boat - super easy to winterize. This engine has 375 HP and WOT is 5500. I tested the compression when I got it and it was 180 on each cylinder.
I think 20w50 would be too thick for Ohio - sometimes we start skiing when it's 50 out. I think the 15w50 is on the edge of being too thick.
Cost is not a big deal to me - I will use whatever is best for my engine. Most of my Mastercraft friends run Rotella 15w40. I really feel the M1 15w50 was pretty trashed at 57 hours - seemed thin. I know color is not a big deal but it had a gritty feel to me. I was not expecting that. But I know I'm running this boat a lot harder than the last guy - he was a wake boarder.
