Originally Posted By: ziggy
Never reused a premium,as the risk,the o ring seal on top of the filters,might fail,from re training it back into filter adapter. It's happened too me, once I remember, way back, 1995, 20 years old, putting a used fra m extraguard back on a 1985 isuz u I mark hatchback. Screwed it on till it stopped, turned it 1/4 turn,started car,looked under, oil was [censored] fast,like it was trying too escape from the engine,all over the garage floor. Took filter off,and noted ,still remember, the black o ring on top of the can,completely appeared,warped,and crushed. Never again. One filter,one interval.
You could always run the filter for two intervals but don't remove it to pour out the old oil. It's not like that amount of oil is going to harm anything anyways, there is a lot more old oil that is still trapped in the head(s) of an engine when you're draining the oil and that never comes out.
