ST Conventional SN Plus
by motorguy222. 10/19/18 02:42 AM
schaefferoil or Amsoil
by s2krunner. 10/19/18 02:29 AM
Pennzoil conventional oil meets api sn plus
by chris_84. 10/18/18 11:45 PM
TGMO in new Honda turbos?
by BTLew81. 10/18/18 11:26 PM
'02 Explorer Sport Trac: 302k mile update
by 14Accent. 10/18/18 10:43 PM
BMW 335 Quick Coolant Change
by antonmnster. 10/18/18 09:58 PM
190k miles
by Marco620. 10/18/18 09:56 PM
tire rotation/jack location
by mobilaltima. 10/18/18 09:23 PM
Apparently I'm not allowed to...
by BMWTurboDzl. 10/18/18 08:41 PM
2014 Cruze 2.0, AMSOIL DHD 7k miles 68k total
by Rat407. 10/18/18 08:32 PM
Stabilizer needed for 5-6 month storage?
by Quattro Pete. 10/18/18 08:29 PM
Clearance ST filter cut open
by barkingspider. 10/18/18 07:56 PM
0W20 Required for Jeep Auto Stop/Start
by harbor. 10/18/18 05:42 PM
School buses + Colder Temps = MPG Nosedive
by RayCJ. 10/18/18 05:20 PM
Whyssosseriouss, TNflash, The74impala, Ryan1122, ston123
66244 Registered Users
29 registered members (berniedd, bullwinkle, AdRock, BlakeB, Dan55, Bailes1992, 3 invisible), 741 guests, and 26 spiders.
Topics292,163
Posts4,875,177
Members66,244
Most Online2,494
Oct 17th, 2018
greasing leaf springs to prevent rust? #4580542
11/20/17 10:17 PM
11/20/17 10:17 PM
Houston, Texas
motor_oil_madman Offline OP
Houston, Texas
I'm going to put new leaf springs on my boat trailer since the old ones are getting too rusty. I figured I'd coat the new ones with grease since I have a ton of it that never gets used. Opinions?
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
Re: greasing leaf springs to prevent rust? [Re: motor_oil_madman] #4580548
11/20/17 10:24 PM
11/20/17 10:24 PM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
I would use CarWell or Fluid Film to soak in between the leaves. I have started to do that on my boat trailer. You have them not installed so turn them sideways and let the stuff seep down.
2015 Ford F250 w/Powerstroke
Re: greasing leaf springs to prevent rust? [Re: motor_oil_madman] #4580559
11/20/17 10:37 PM
11/20/17 10:37 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
You need something more penetrating than grease.
Re: greasing leaf springs to prevent rust? [Re: motor_oil_madman] #4580593
11/20/17 11:12 PM
11/20/17 11:12 PM
Phoenix, AZ
Nick1994 Offline
Nick1994  Offline
Phoenix, AZ
Auto Zone sells an aerosol can of Fluid Film, Even here in Phoenix.
2015 Hyundai Sonata 2.4L 85k Mobil 1 AFE 0w30 & OEM
2000 Toyota Camry 2.2L 230k Valvoline 5w30 & Fram Ultra
1996 Jeep Cherokee 4.0L 147k Mobil 1 HM 10w40 & Fram Ultra
Re: greasing leaf springs to prevent rust? [Re: Merkava_4] #4580618
11/21/17 12:46 AM
11/21/17 12:46 AM
New Jersey
JHZR2 Offline
JHZR2  Offline
New Jersey
For starters, yes. This is a case where I'd coat with carwell/known and then pack with a waterproof grease after.
Re: greasing leaf springs to prevent rust? [Re: motor_oil_madman] #4580622
11/21/17 01:01 AM
11/21/17 01:01 AM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
Greasing leaf springs was a weekly chore on the '23 Chrysler lube schedule.
Thick oil is better grin2
Re: greasing leaf springs to prevent rust? [Re: motor_oil_madman] #4580627
11/21/17 01:10 AM
11/21/17 01:10 AM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
It works fine unless you are drive/towing in extremely dusty environs. The dust will work into the grease between the leaves and can act a polishing agent. You'll get accelerated wear. But, if not pulling on desert roads, no biggie laugh
We used to oil and grease the springs on the horse trailers so thet'd ride better and to resist the horse p laugh
Re: greasing leaf springs to prevent rust? [Re: motor_oil_madman] #4580637
11/21/17 02:01 AM
11/21/17 02:01 AM
Houston, Texas
Houston, Texas
I just see any kind of aerosol spray washing off as soon as it's dunked in the water.
Re: greasing leaf springs to prevent rust? [Re: motor_oil_madman] #4580643
11/21/17 02:43 AM
11/21/17 02:43 AM
Reno, NV
redbone3 Offline
redbone3  Offline
Reno, NV
I wonder if motorcycle chain lube might do for this job?
2014 Passat Wolfsburg, 1995 Miata.
Re: greasing leaf springs to prevent rust? [Re: redbone3] #4580653
11/21/17 03:22 AM
11/21/17 03:22 AM
NY
demarpaint Offline
demarpaint  Offline
NY
It will work as good as FF, maybe better. It will have to be reapplied often though, just like FF.
God Bless Our Troops
Re: greasing leaf springs to prevent rust? [Re: motor_oil_madman] #4580657
11/21/17 03:43 AM
11/21/17 03:43 AM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
I think some leaf springs are drilled and have a grease nipple so youy can grease them with a gun from the inside out
You could perhaps get that done if you can find someone who knows what they're doing. DIY or inexpert pro you might risk starting cracks.
Failing that heat the grease to above its melting point and run it in sideways, as suggested above
Or use oil. If concerned about it washing off, use vegetable oil, (though this will eventually set solid) or a blend.
You can get or make spring covers but you probably dont want that on a boat trailer.
Re: greasing leaf springs to prevent rust? [Re: motor_oil_madman] #4580720
11/21/17 07:29 AM
11/21/17 07:29 AM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
Is the trailer dunked in fresh or salt water?CarWell or FF or Krown will not easily wash off. But they will eventually need to be reapplied.
Re: greasing leaf springs to prevent rust? [Re: motor_oil_madman] #4580723
11/21/17 07:38 AM
11/21/17 07:38 AM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
Some British Leyland Sherpas had fibre reinforced plastic spring leafs. Dunno how unique that is but if you could get something similar it'd solve your rust problem.
Corvette transverse, some Mercedes and Audi, apparently
http://www.flex-form.com/products.asp
Re: greasing leaf springs to prevent rust? [Re: demarpaint] #4580729
11/21/17 07:47 AM
11/21/17 07:47 AM
New Jersey
JHZR2 Offline
JHZR2  Offline
New Jersey
Yeah, that's why I didn't recommend FF prior to greasing, I feel that known/carwell film lasts a bit longer in hi wash areas.
My Saab, which had been to Krown multiple times, always had a slight dirt/oily residue on the struts and wheelwell components which was reassuring to me.
Top the known with grease to lock it in and I'm hoping it will stay wicked in longer.
Re: greasing leaf springs to prevent rust? [Re: motor_oil_madman] #4580775
11/21/17 08:53 AM
11/21/17 08:53 AM
Florida, Cape Coral
Eddie Offline
Eddie  Offline
Florida, Cape Coral
Many leaf springs are meant to not have an external lubricate applied. The spring lief themselves are supposed to have a specific friction between them. I once had a vehicle with leaf springs and I jacked up the vehicle and sprayed oil between the leafs. The rear of the vehicle became very soft and was a danger to turn quickly. Ed
CX5 Touring 2.5L :-)
