Mattress shopping .....
by dblshock. 12/18/18 04:57 AM
AmazonBasics Oil May Drive Prices Down
by knerml. 12/18/18 04:45 AM
Hemi MDS issues are how common?
by Gasbuggy. 12/18/18 03:21 AM
Why use Redline and Redline Clone oils...
by burla. 12/17/18 11:38 PM
Tire choice
by CincyReds. 12/17/18 11:14 PM
Transmission fluid leak
by dawgn86. 12/17/18 07:53 PM
QuickJack BL-5000SLX and my Optima...
by WhizkidTN. 12/17/18 07:23 PM
Champion Air Filter Opinions?
by JerryBob. 12/17/18 06:18 PM
Tundra transfer case plug torque (Borg Warner)
by Idlewild294. 12/17/18 06:03 PM
Winter tire question?
by Muskieteer. 12/17/18 05:31 PM
Who makes good ball joints these days?
by GSCJR. 12/17/18 04:51 PM
Bought a used Ford Fusion
by krismoriah72. 12/17/18 04:14 PM
Valvoline NextGen Tech Oil
by DirtyOilGuy. 12/17/18 04:08 PM
Witty comment regarding a lame car
by Number_35. 12/17/18 03:43 PM
'80s oil literature
by Number_35. 12/17/18 03:26 PM
Recommend on oil for 2017 Kia Sportage 2.4
by SlavaB. 12/17/18 02:57 PM
No more Delo at my Costco. T4 now
by BeerCan. 12/17/18 02:16 PM
Found this
by davedude. 12/17/18 02:15 PM
hopsofir, genera2800, oghl, hdlss, dsmdylan
66711 Registered Users
45 registered members (alarmguy, Char Baby, bullwinkle, AZjeff, Ctreasure, 5 invisible), 1,039 guests, and 45 spiders.
Topics295,207
Posts4,929,909
Members66,711
Most Online2,553
Oct 27th, 2018
Engine Mounts 02 Honda Accord V6 #4578547
11/19/17 12:36 AM
11/19/17 12:36 AM
USA, FLA
David1 Offline OP
David1  Offline OP
USA, FLA
Okay... I have over 230K miles on my Honda Accord and I changed the TOP Passenger side Motor Mount.. Actually I'm on my 2nd.
Now I changed the 2 Automatic Transmission Mounts...
Now here is where Im confused.. I have read that the REAR Mount has OIL in it..
Also I can see that the front mount has a hose running to it.. Now on some sites like AMAZON they say its Vacuum hose
and others they say its Hydraulic Mount..
So again I replaced the 2 AT Trans Mounts and the TOP Passenger Side Top Mount.. ** TORQUE STRUT **
It says this on some sites like AAP
Product Application
2002 Honda Accord V6
Front; Front; Denotes Hydraulic Mount
Rear; Rear; Denotes Hydraulic Mount
I read this on a site
We offer it both ways as the vacuum is only activated under a fail safe low idle condition and very few vehicles actually need it. When the vehicle is at normal idle or above the vacuum does not even come into play. For that reason if your vehicle has a normal idle you can install a mount without the vacuum line and just plug off the tube on the engine side. For your information - it is not a seal of any kind, the vacuum just controls the stiffness of the mount below normal idle.
Then I read how people say you can get with or without the Vacuum.. like above..
However I like it to be Exact OE...
I'm totally confused
Look at AMAZON
So Now Im do not know if the front is Vacuum even though I can clearly see a Hose when i pop my hood and look at the
mount and see a what I think is a vacuum hose connected to the mount..
However the Rear mount I do not see a Hose.. Now 1 person told me that Hydraulic oil is inside the mount... However the
picture clearly shows a Line / hose.. So Im very confused
Anyone else run into this problem..
Any Info would be great.
Thanks
2002 Honda Accord V6 3.0 Automatic Trans 250K Miles
Valvoline Maxx Life FULL SYN 5W30
HAMP or FULL Or HONDA Filtech A01s
Re: Engine Mounts 02 Honda Accord V6 [Re: David1] #4578566
11/19/17 02:06 AM
11/19/17 02:06 AM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
Ask Honda ?
Best of luck to you all , :-)
Wyr
God bless
Re: Engine Mounts 02 Honda Accord V6 [Re: David1] #4578576
11/19/17 03:03 AM
11/19/17 03:03 AM
Athens, GA
ctechbob Offline
ctechbob  Offline
Athens, GA
They are both vacuum operated and contain oil in them. All the vacuum does is alter the stiffness of the mount slightly. There's really not much difference in them. I've got 2 J3X engine cars, one with and one without vacuum mounts and you really can't tell much difference between them. Just make sure if you replace a vacuum mount with a non-vacuum mount that you cap off the line as then you'll have an intake leak.
Also, if you're not going to spend money for OEM mounts, I highly doubt that they work much differently at all. I can't imagine China put a lot of engineering into their knockoffs. "That looks about right" is probably what you're getting. I just picked some of the cheapest ones on Ebay and rolled with it, even on my TL-S. The J-Series motors are so smooth it doesn't matter much.
2008 Acura TL Type S - 154k
2003 Honda Accord V6 - 207k
2000 Honda Accord I4 - 311k
Current Oil - Milesyn SXR5W30
Current Filter - Partsmaster 61334
Re: Engine Mounts 02 Honda Accord V6 [Re: ctechbob] #4578615
11/19/17 07:01 AM
11/19/17 07:01 AM
USA, FLA
David1 Offline OP
David1  Offline OP
USA, FLA
Thank you for info....
Re: Engine Mounts 02 Honda Accord V6 [Re: David1] #4578662
11/19/17 08:02 AM
11/19/17 08:02 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
The biggest favor you can do for yourself today is pay a bit more money and order OE mounts from an online dealer. Aftermarket mounts will haunt you until you break down and redo the job and put OE ones in.
Re: Engine Mounts 02 Honda Accord V6 [Re: Trav] #4578691
11/19/17 08:33 AM
11/19/17 08:33 AM
Orlando, FL
Mr Nice Offline
Mr Nice  Offline
Orlando, FL
A few more buck for this is worth it.
Re: Engine Mounts 02 Honda Accord V6 [Re: Trav] #4578790
11/19/17 09:52 AM
11/19/17 09:52 AM
USA
thrace Offline
thrace  Offline
USA
Honda brand mounts also fail frequently in my experience in Honda Acura V6. Maybe not failing as often as aftermarket. Especially that hard to get to rear mount. There seems no way to get durable Honda engine mounts for this year Honda.
Re: Engine Mounts 02 Honda Accord V6 [Re: thrace] #4579086
11/19/17 03:13 PM
11/19/17 03:13 PM
Trav Offline
Trav  Offline
That's true enough but good lord I have seen some aftermarket junk not last a hundred miles, literally. I do run into OE that have gone 100K. No brainer IMO I don't like doing the job multiple times, that gets old fast.
Re: Engine Mounts 02 Honda Accord V6 [Re: David1] #4579315
11/19/17 06:06 PM
11/19/17 06:06 PM
Athens, GA
ctechbob Offline
ctechbob  Offline
Athens, GA
The most common mounts to fail on the J-Series is the Pass side and the front. Usually the rear is still in pretty good shape so long as you've kept up with those two. As far as OEM or not....meh, its a [censored] shoot, I don't particularly think the pass side lasts any longer either way. FWIW I got more miles out of the front mount on an 03 Accord than I did on my 08 TL-S. Granted, they're the same(ish) mounts and the TL-S has another 40hp on the Accord so you would expect the mounts to take more abuse.
Re: Engine Mounts 02 Honda Accord V6 [Re: David1] #4579437
11/19/17 07:54 PM
11/19/17 07:54 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
Read the article on page 34 and everything will make sense.
http://edition.pagesuite.com/html5/reade...22a9&pnum=1
