Anyone go to the Formula 1 US Grand Prix at cota?
by gatorfast
03/22/18 10:15 AM
06 Mustang with the 2 piece spark plugs ugggg
by gmh101357
03/22/18 09:55 AM
Putting a Toyota filter on a Ford?
by mrdctaylor
03/22/18 09:30 AM
Latest And Greatest For Oil Stain Removal
by Propflux01
03/22/18 08:56 AM
repair or replace time?
by joaks
03/22/18 08:39 AM
15 escape tranny mtc question
by alphasparky353
03/22/18 08:23 AM
Funny pic
by Chris142
03/22/18 08:23 AM
Ebay Coupons
by krismoriah72
03/22/18 08:17 AM
Mitsubishi Outlander 2.4
by mobilaltima
03/22/18 07:59 AM
cvt transmission oil
by ernied
03/22/18 07:54 AM
Spring in New York
by michaelluscher
03/22/18 07:48 AM
Metal Cutting Wheels
by krismoriah72
03/22/18 07:44 AM
What Year Did you Start Using Synthetic Motor Oil?
by Speak2Mountain
03/22/18 07:25 AM
Mobil 1 differential fluid?
by lawnguy
03/22/18 07:03 AM
New Tractor Fluids sub-forum
by Shannow
03/22/18 06:29 AM
So what exactly is, and what oils
by Shannow
03/22/18 06:22 AM
Castrol 0w 40
03/22/18 05:50 AM
3D holographic magnifying glass...
by Shannow
03/22/18 04:36 AM
Tesla getting in to ride sharing
by Shannow
03/22/18 01:55 AM
Brake hub resurfacing kit
by pda1122
03/21/18 11:46 PM
jongpoole, MCM, zhang, sshuangyc, adubg
64528 Registered Users
110 registered (adubg, Alfred_B, 28oz, 1JZ_E46, ArrestMeRedZ, Andrei, 9 invisible), 1591 Guests and 103 Spiders online.
64528 Members
68 Forums
280250 Topics
#4578106 - 11/18/17 03:10 PM Sea Foam?
poikaa Offline
Loc: Ishpeming, Michigan
What is your opinion of Sea Foam? While I'm at it.... in the gasoline or oil or both?
#4578110 - 11/18/17 03:13 PM Re: Sea Foam? [Re: poikaa]
AVB Offline
Loc: Georgia
I am not a fan, I think it is way over priced for what it is. I like Berrymans B-12 better, not sure I would use it in oil though.
#4578122 - 11/18/17 03:29 PM Re: Sea Foam? [Re: poikaa]
i_hate_autofraud Offline
Loc: Canada
The only Seafoam product I use is the Trans Tune for GM 4T60 / 4T65E transmissions,
great on slow shifts and hard shifts, not recommended for shudder issues.
#4578126 - 11/18/17 03:48 PM Re: Sea Foam? [Re: poikaa]
Jimzz Online   happy
Loc: NoVA
You can use it but it won't really do much. The 3 ingredients are...
40-60% Pale oil - Thin oil that's why it smokes
25-35% Napata - A basic solvent Can find in some carb cleaners
10-20% IPA (Isopropyl alcohol) - Same active ingredient in rubbing alcohol.
As you can see there is not much solvent in there and naphtha is a very common one at that. If you want to help your car, esp after its got some miles on it, is get the CRC Mass Air Flow sensor cleaner and clean the MAF sensor. Then get a can of spray carb cleaner and spray out the throttle body, intake, and PCV lines.
#4578143 - 11/18/17 04:28 PM Re: Sea Foam? [Re: poikaa]
Ethan1 Offline
Loc: 'murica
It gets way too much credit. Probably 90% of sales are due to the white smoke it produces.
HOWEVER, if you watch Project Farm's youtube video where he uses it in his old Ranger, you'll be amazed at what it can do to some vehicles.
#4578147 - 11/18/17 04:31 PM Re: Sea Foam? [Re: poikaa]
StevieC Offline
Loc: Ontario, Canada
Amsoil P.I. or VP Racing Fuels Fuel System Cleaner for the gas tank part of it. Amsoil power-foam for the throttle body etc. and nothing in the oil. Only a quality Synthetic.
I have racked up a ton of miles and never had an issue.
'15 Dodge Journey - 90,000 KM's - SSO 5w20
'06 Hyundai Santa Fe - 535,000km - SSO 0w30 (R.I.P)
#4578154 - 11/18/17 04:40 PM Re: Sea Foam? [Re: poikaa]
BJD78 Offline
Loc: Nebraska
No additive or dope or cleaner is needed or called for by any owners manual that I have ever seen. Millions of vehicles have went well past the 200K to 300K club with just basic maintenance, regular conventional oil changes and air filter changes and the cheapest fuel and no extra additives. But I suppose if one insists on adding a fuel additive, avoid seafoam as it is not an approved fuel additive that the DOT/EPA approves to be used by fuel suppliers. At least Techron is an additive that fuel suppliers use in order to make their top tier fuels, but if you already use a top tier detergent fuel, dumping in extra techron probably wont do much, but drain the wallet, as more is not always better.
2010 Forester:122K
2009 Sonata :189K
2010 Tucson:55K
OCI 5K using cheapest dino oil I can buy,usually NAPA or TSC Travelers oil.
#4578177 - 11/18/17 05:18 PM Re: Sea Foam? [Re: poikaa]
Panzerman Offline
Loc: Port Orange, Florida
I love Sea Foam. It's the only thing I have found that stabilizes gas long term.
Since I started using Sea Foam as a gasoline stabilizer the brass jets in my motorcycles have stopped turn green and crusty white and clogging.
Sometimes my ATVs dit for years. Stabil doesn't seem to cut it. Great for 2 months top. Berryman is too agressive. It cleans and dislikes plastic. If you have a issue with carbon,grime or sludge Berryman will disolve it. All these cleaners are too harsh for oil. MMO is all I ll use in the engine oil.
2006 Dodge Ram 2500 Hemi 4x4
2016 Dodge Challenger Scat Pack
#4578180 - 11/18/17 05:21 PM Re: Sea Foam? [Re: poikaa]
HangFire Offline
Loc: Central Maryland
Useful for, what it's useful for.
Last week I dug out a near 20 year old consumer chainsaw that didn't run, didn't even cough or pop. Bought it 5 years ago for $5, like new but it didn't run when I tried it then, never got back to it.
Drained the old mix, put in fresh e-free/Stihl Platinum mix, nothing.
Put in SeaFoam, primed and pulled a bit to get it into the carb, and let it sit overnight. (Just didn't have time to deal with it at the moment.) Drained Seafoam out the day after next, put in my mix, and it ran. Just like that. It still has issues- not sure if it's leaking air into a cracked primer bulb or old fuel line, or maybe it still needs the carb to be rebuilt. But the difference was there, immediate, and if not amazing, definite.
Various musings:
#4578342 - 11/18/17 08:29 PM Re: Sea Foam? [Re: poikaa]
Brybo86 Offline
Loc: Chicago, IL
I only use seafoam for off season storage... and swear by it.
I have have never had to rebuild a carb that was left with a splash of seafoam in tank over the winter.
Edited by Brybo86 (11/18/17 08:30 PM)
08 Honda Accord EX-L 2.4L Amsoil SS 0w20 142k
01 Kymco People 50
95 Lexus LS400 M1 AFE 0w30 193k
95 Yamaha Jog
#4590368 - 11/30/17 08:31 PM Re: Sea Foam? [Re: poikaa]
Beem Offline
Loc: CT
I seem to disagree with the nay sayers.
Whenever I have spring startup or running issues in vehicles and equipment a shot of Seafoam in the gas, a few cranks to get it in the carb than an overnight wait for action and problems are all gone.
And for cost, how much does a carb removal and cleaning cost in comparison. Five or six bucks at WalMart is cheap.
