Originally Posted By: goodtimes
It may be the small gap for oil flow combined with a strong oil pump moves the end cap points against the can, and that is what I thought was talked about as the debris source. The end cap on the base plate side on yours has flattened beaten up points, or nubs, as well, that's what the picture shows. Right side. Pictures worth 1000 words.
Well I'll say that if nub wear is your major concern, it looks like the filter did very well.
Sure it held up well, VERY well, sure it did. Can't see a thing wrong here, no funny stuff under the rubber, can't see it, just can't.
The filter was on the vehicle for 2 years. That is 4X what Fram recommends.
The nubs are there to keep the filter centered during manufacturing. Once assembled, their need goes down.
