Originally Posted By: bunnspecial
S&W Model 16(or related) chambered in 327 Federal Magnum.
The last "new" gun made in this chambering was a Ruger Single 7 a couple of years ago. They made it in 3 barrel lengths, and I think set an initial run of 2000 in each barrel length. After calling several stores in town as soon as I heard about it, I managed to get one from the first batch in 5 3/8"(I should have just bought all three-the store had them in stock). That was the only store to get these.
I was told that demand was such that they made an additional 1000 in each barrel length. From what I've seen, the used market price has held steady on them, although I would not part with mine.
S&W made a model 16 in 32 H&R Mag. Apparently it received the same heat treatment as the 19, which means that the cylinder is MORE than strong enough to handle 327 Mag pressures. The K-frame cylinder is also-relatively speaking-quite long since it's a legacy design from the 32-20(one of the two original chamberings of the K frame) and the 327, although longer than a 357 Magnum, is shorter than a 32-20. I've known of many Model 16s in 32 H&R that have been rechambered for 327(all that needs to be done is cut back the throat in the cylinder to allow the longer cartridge) but I'd like to have an officially sanctioned one.
Unfortunately, I think 327 is a cartridge that may well has seen its peak in popularity(if you could ever have called it popular). The Single 7 in 2014 or 2015(I forget when exactly) caught some attention, but it still mostly fell back under the radar afterwards.
I know you probably aren't looking at the Ruger LCR and LCRX .327 models, but what about the SP101 in .327? A little smaller than the K-frame, but a good little revolver.
http://www.ruger.com/products/sp101/specSheets/5773.html
Thanks. I actually have one of those, albeit with a shorter barrel.
The beauty of a longer barrel 327 is that in a lot of ways it's almost a perfect varmint pistol.
Fast 32 caliber handguns are VERY flat shooting and pack a decent punch in terms of kinetic energy. They're almost an ideal long range pistol thanks to this also, but you have to have the barrel length.
While we're at it, I'd love a carbine on a 92-type action in 327
There's always the Blackhawk in .30 Carbine. I had one back in the '80's. Shoots very flat. Loudest handgun I ever owned.
