The oil in my RX8 Mazda is 6.5 years and 6500 miles old.
I guess I'll break down, and change it in the spring at 7 years.
It's got Mobil 1 0w40 in it, and I'll test it too make a point that time is mostly irrelevant as long as no known coolant loss or other contamination.
I've read others having long term changes with very little use of vehicle, and those tests were fine.
I used to sell lots of industrial oils, and maybe the additives in motor oil could settle somewhat, but if you keep it shaken or driven occasionally, not a problem.
So I guess I'm independent Oil company A.
