Abuse proof rental home flooring
by Oldtom
15 minutes 57 seconds ago
Low Noise Oil
by Ducked
37 minutes 29 seconds ago
2017 Dodge charger review
by gabriel9766
41 minutes 25 seconds ago
Dry reusable air filters?
by WillB
50 minutes 43 seconds ago
Batteries @ Menards
by Tdbo
Today at 07:29 PM
Blotter Spot Test
by Emanuel
Today at 07:22 PM
Is arming teachers the answer?
by ZZman
Today at 06:45 PM
Another ATF question... I aplogize
by bardos
Today at 06:12 PM
To Seafoam or Not?
by Marco620
Today at 06:07 PM
2017 Ford ecoBoost 1.5 Oil Filter Top View
by tenderloin
Today at 05:50 PM
Castrol Edge 0w40 Formulation Change
by Tmaslar
Today at 05:41 PM
Another Brake Fluid Flush Question
by artbuc
Today at 05:19 PM
Preventative Care ?
by maverickfhs
Today at 05:14 PM
my best deal ever
by 93cruiser
Today at 05:08 PM
Motorcraft fl1a cut open 3yrs oci
by rollinpete
Today at 04:05 PM
Slapped my FilterMag onto a Fram Ultra
by ZZman
Today at 03:59 PM
Toyota OEM Oil Filters: 5 for $15 or 10 for $30
by NYSteve
Today at 02:37 PM
Need Oil Change Advice
by Fulgore
Today at 12:51 PM
Weather
by bigj_16
Today at 12:27 PM
2013 Ford Focus 2.0 GDI: OE Spark Plugs, 94k miles
by Nick R
Today at 12:26 PM
WiseOne, ryan6548, pjmbull, 92zx, Ara
64253 Registered Users
131 registered (2004tdigls, 4WD, 901Memphis, 14Accent, AdditiveOCD, 15 invisible), 1669 Guests and 100 Spiders online.
64253 Members
65 Forums
278513 Topics
Page 1 of 2 1 2 >
#4574180 - 11/14/17 07:44 PM Head gasket on 2.2 Chevy
ram_man Offline
Loc: southern mo
So starting tomorrow I have a 95 cavalier in my garage that has a slight coolant leak at the back of the head (transmission side) just leaks externally. Hopefully I can just replace the gasket and the head be in good shape. Any tips or tricks when doing this? Short cuts ect. I know they are pretty easy all things considered.
2014 dodge dart GT "mine"
2013 Dodge Dart limited "hers"
1995 Dodge ram 1500
#4574204 - 11/14/17 07:57 PM Re: Head gasket on 2.2 Chevy [Re: ram_man]
clinebarger Offline
Loc: Fort Worth, Texas
Have the head pressure checked & Surfaced, Check the block deck for flatness, Chase all the head bolt holes with a thread chaser, Use a GOOD torque wrench, Clean the mating surfaces really well.
Stay away from extra thick "rebuilder" head gaskets! These engines are dogs anyway without killing the "quench" & compression ratio.
2001 Chevy Camaro L92/4L80E
2007 Chevy Cobalt SS LSJ/F35
2010 Toyota Corolla 2ZR-FE/Auto
#4574291 - 11/14/17 09:02 PM Re: Head gasket on 2.2 Chevy [Re: ram_man]
andyd Online   content
Loc: Marshfield , MA
Generic advice only: Establish TDC and set cam timing marks before removing anything beyond the spark plugs. Back the head off in 3 stages. Use a carpenter's level to check for flatness. If the engine has a timing chain. Check on line for a how to on immobilizing the chain.so you don't have to drop the oil pan to set the chain.
'16 Camry LE STP synth 0w20 and STP filter.
'16 Camry SE, Valvoline bulk 0w20 and ? filter
#4574303 - 11/14/17 09:15 PM Re: Head gasket on 2.2 Chevy [Re: ram_man]
wtd Offline
Loc: southwest Mo.
The 2.2 was famous for head gasket leaks. Every one I have owned, I've had to put a head gasket on and every one that I know that has a vehicle with the early 90's 2.2 had to have head gaskets as well.
2014 Mustang GT
1998 Chevy K3500
1998 Chevy K1500
(2) 1992 Cavaliers
1970 Monte Carlo
#4574317 - 11/14/17 09:34 PM Re: Head gasket on 2.2 Chevy [Re: ram_man]
gabriel9766 Online   content
Loc: Missouri
Fairly simple job. I did my first head gasket on a pontiac sunfire with the old OHV 2.2. It had an external HG leak right behind the motor mount.
2015 chevy malibu 1LT DI 2.5L I4- Mobil1 AFE 0w20 w/ a acdelco ph64 34,384K
2003 ford taurus ses FFV-150,298 Pennzoil HM 5w30 w/ a red purolator 20195
#4574327 - 11/14/17 09:50 PM Re: Head gasket on 2.2 Chevy [Re: ram_man]
cronk Online   content
Loc: Watertown, New York
I believe the head bolts are one time use on those engines. Looks like Fel Pro sells them so should be able to get where you buy the gasket kit.
Definitely have a machine shop check the head, they typically weren't cracked when we did them at the shop , but did have a couple that were.
The old pushrod 2.2 was a tough engine, one in my S10 had around 200k with nothing but a water pump and a valve cover gasket.
The external head gasket leak was something I occasionally saw with them, but mine was a good one.
1998 GMC C1500
2003 Chevy Cavalier
2011 Nissan Quest
1986 Pontiac Trans Am
1940 Ford 9N Tractor
Amsoil lubes and filters!
#4574331 - 11/14/17 09:54 PM Re: Head gasket on 2.2 Chevy [Re: ram_man]
FlyNavyP3 Offline
Loc: Jacksonville, FL
Pretty simple job all things considered. Leaving the intake and exhaust manifolds on when pulling the heads saves time. I'd highly recommend having the head machined and if in any doubt about if its the gasket or a cracked head have it pressure tested. While it's off at the machine shop getting milled have them install new valve seals.
New head bolts are a must.
Consider thermostat while its apart.
I prefer Fel-Pro gaskets personally. Victor gaskets are also acceptable. Stay away from no name eBay gasket sets.
Take lots of pictures and share.
Luke
#4574339 - 11/14/17 10:03 PM Re: Head gasket on 2.2 Chevy [Re: ram_man]
Bud_One Offline
Loc: Spring,Texas
Yes, pics please grin
16 Civic-M1 EP 0W-20,TG7317
14 Civic- DLR bulk oil and A02
05 Chevy 2500HD-QSUD 10W-30, XG3675
97 Accord Wagon-Havoline Conv 5W-30, PH3593A
#4574375 - 11/14/17 10:40 PM Re: Head gasket on 2.2 Chevy [Re: ram_man]
ram_man Offline
Loc: southern mo
I'll take pics. I hope to start on it in the next day or so depending on how busy work is.
1995 Dodge ram 1500
#4574396 - 11/14/17 11:13 PM Re: Head gasket on 2.2 Chevy [Re: ram_man]
Merkava_4 Offline
Loc: Clovis, CA
https://www.alldatadiy.com/buy/
#4574595 - 11/15/17 07:35 AM Re: Head gasket on 2.2 Chevy [Re: wtd]
edwardh1 Offline
Loc: Coastal South Carolina
our bought new 84 oldsmobile Ciera 4 cyl when new, would leak about one drop out of the head to block area each night..
Olds dealer under warranty replaced the head gasket once, then did it again after surfacing the head, then later (no computers in 84?) found a service bulletin that said many blocks built in a certain time span had a "porosity" in the block. so they replaced the block, reusing all the internal parts, though new bearings. that took dealer about a week. bad foundary work in making the block even tho GM had been making blockss forever. engine then ran past 100k and was passed on to my children.
However that was my last domestic car, since then Nissans, Honda and Toyota.
Edited by edwardh1 (11/15/17 07:36 AM)
Prius? In line water heater? Solar?
All save energy, but may not save money (complicated, no DIY, parts hard to get, , parts expensive, etc).
#4574610 - 11/15/17 07:47 AM Re: Head gasket on 2.2 Chevy [Re: ram_man]
StevieC Offline
Loc: Ontario, Canada
I think from the ones dad and I did we backed off the tightness of the head bolts on the timing chain side ever so slightly from factory spec to extend head gasket life. Might want to google it but if memory serves me correctly that is what we did.
'15 Dodge Journey - 90,000 KM's - SSO 5w20
'06 Hyundai Santa Fe - 535,000km - SSO 0w30 (R.I.P)
#4574738 - 11/15/17 09:29 AM Re: Head gasket on 2.2 Chevy [Re: ram_man]
MarkM66 Offline
Loc: stl
I'd buy a cheap used repair manual. Or maybe check the library.
#4576734 - 11/17/17 06:50 AM Re: Head gasket on 2.2 Chevy [Re: ram_man]
jacobsond Offline
Loc: warm and sunny ND
If your not watching the head gasket can be put on backwards.There is a small coolant passage on one end and will be blocked if you have it flipped wrong.Not that I would ever do that and have to do the whole job over again after you hear coolant popping in the area of the head. smile
#4577298 - 11/17/17 05:23 PM Re: Head gasket on 2.2 Chevy [Re: andyd]
eljefino Offline
Loc: ME
This car has a timing chain but the cam's in the block so it can just stay there all happy.
I did one of these on a 96 and it couldn't be simpler or more rednecky. I left the manifolds attached, lifted the head 1.5 inches, got in there with a scotchbrite* to clean stuff up, slipped a new gasket in, done in an afternoon.
This car isn't worth going to a machine shop over. The leak is 99% likely due to a crummy gasket and not some stress in the head or block warping it and taking the gasket with it.
* they say scotchbrite sheds stuff that winds up in the bearings wrecking them.
Page 1 of 2 1 2 >
