Adventures with my 42 yr old Stihl's Loose Muffler
by andyd
02/23/18 06:00 PM
Big rubber mats on the backs of cars.
by simple_gifts
02/23/18 05:28 PM
3 MC FL-400S oil filters FREE
by car51
02/23/18 05:12 PM
How is your brain?
by vavavroom
02/23/18 04:59 PM
Can my CVTF be too cold?
by pilot1226
02/23/18 04:57 PM
PSA BCG
by BlueOvalFitter
02/23/18 04:50 PM
Motorcraft made in Japan spark plugs
by Whimsey
02/23/18 04:07 PM
Direct injection problems.
by Bullwinkle007
02/23/18 01:43 PM
2013 BMW 535i F10
by Kaiser
02/23/18 01:02 PM
Any FWD vehicles with LSD/limited slip?
by Brybo86
02/23/18 12:54 PM
UOA: 2011 Equinox 2.4l - fuel in oil
by Iowegian
02/23/18 12:47 PM
M1 0w20 AFE, 6200 miles, 2006 Civic
by Patman
02/23/18 12:15 PM
Ravenol playing in Formula 1
by H_Tech
02/23/18 12:15 PM
Honda DW-1 UOA 35k miles w/Pics
by GemStater
02/23/18 11:54 AM
Fall Sunset over Albany
by Nick R
02/23/18 11:18 AM
Dielectric grease for Toyota/Lexus coils
by ford46guy
02/23/18 11:11 AM
Pennzoil Licensed Mercon V
by Fordiesel69
02/23/18 11:10 AM
Napa Platinum vs Napa Gold Oil Filter
by Snagglefoot
02/23/18 10:19 AM
Dash cam Recommendations?
by Eosyn
02/23/18 09:44 AM
fram FR10-1
by red7404
02/23/18 09:40 AM
Philsmith, JaCkaL829, kenoshabrew, DIANgEMinONV, smw01
64270 Registered Users
94 registered (2015_PSD, Armkb, AlaskaMike, andyd, 93cruiser, 2009Edge, 6 invisible), 1625 Guests and 95 Spiders online.
64270 Members
65 Forums
278616 Topics
Page 1 of 2 1 2 >
#4573801 - 11/14/17 01:15 PM Synthetic differential fluid - 2 questions?
lawnguy Offline
Loc: Florida
My vehicle - 2000 Ford F150 4x2 4.6V8
1) Is this what I should use? Synthetic Gear Lubricant, SAE Grade 75W-90
2) Is O'Reily brand "synthetic just as good as Mobil 1 ?
#4573816 - 11/14/17 01:34 PM Re: Synthetic differential fluid - 2 questions? [Re: lawnguy]
Char Baby Offline
Loc: ROCHESTER, NY
I am unaware of any conventional gear lube that is 75w90... only synthetics in that grade. My only concern would be whether your diff has limited slip therefore you would need to purchase a seperate LS additive or buy the gear lube with it already in there in which the bottle will say so.
"Retired"
'06 Mazda 3i 2.0L
'15 Nissan Altima 2.5 SV
#4573820 - 11/14/17 01:39 PM Re: Synthetic differential fluid - 2 questions? [Re: lawnguy]
2015_PSD Online   content
Loc: SE Texas
According to what I see in the 2000 Ford F-150 Owner's Manual, your rear axle should use 75W-140 which is definitely a synthetic gear oil. IMHO Amsoil is the best, but M1, SuperTech, Castrol or the like would be just fine (need to check on the LS additive as CharBaby suggested though).
2015 F-250 6.7L Powerstroke Diesel.........Delo 400 LE 5W-40 + CQ Blue (WIX)
2014 Explorer 3.5L Limited...................M1 AFE 0W-20 + FU
#4573829 - 11/14/17 01:57 PM Re: Synthetic differential fluid - 2 questions? [Re: lawnguy]
OneEyeJack Offline
Loc: S California
You might also consider Red Line.
#4573834 - 11/14/17 02:03 PM Re: Synthetic differential fluid - 2 questions? [Re: 2015_PSD]
Jeffs2006EvoIX Offline
Loc: Imperial Valley, California
Cant stand it when folks say "this is the best" There is no "Best" haha. Amsoil is as good as many other products out there and people on these forums know this. So lets keep brand Bias out of it.
OP,
As long as you follow Fords Recommendations of what gear oil to use, you are fine. Just check your manual to verify, and buy a brand you have heard of. If you are not sure who makes O'Riley Oil? Then buy something else that you have heard of, or at least know who made it.
Good Luck thumbsup
Truck On!!
Jeff
2013 VW GTI
#4573842 - 11/14/17 02:13 PM Re: Synthetic differential fluid - 2 questions? [Re: Jeffs2006EvoIX]
Loc: SE Texas
If you can read, you will see that I clearly said IMHO, which means In My Humble Opinion and I clearly noted other brands as well. No one is forcing you to accept my opinion, so climb down off that ivory tower.
#4573858 - 11/14/17 02:30 PM Re: Synthetic differential fluid - 2 questions? [Re: lawnguy]
lawnguy Offline
Loc: Florida
If I gave my VIN# to my local ford parts dept could they tell me if my truck is Limited slip?
#4573868 - 11/14/17 02:50 PM Re: Synthetic differential fluid - 2 questions? [Re: lawnguy]
Loc: SE Texas
I would think so. BDCardinal on here can probably tell you as well (he is a Ford parts advisor and an all around great guy).
#4573878 - 11/14/17 03:04 PM Re: Synthetic differential fluid - 2 questions? [Re: lawnguy]
lawnguy Offline
Loc: Florida
I just called my local ford dealer parts dept. I gave them the last 8 of my vin. He told my my truck had a limited slip,and the rec diff fluid is 75w 140
#4573886 - 11/14/17 03:12 PM Re: Synthetic differential fluid - 2 questions? [Re: lawnguy]
Loc: SE Texas
Just need to find gear oil that already has the LS additive in it or purchase a bottle of it and add it to the axle after filling it. Ford sells it (For a complete drain and refill, some limited-slip axles require addition of Friction Modifier, Part Number XL-3 meeting Ford specification EST-M2C118-A).
#4573898 - 11/14/17 03:22 PM Re: Synthetic differential fluid - 2 questions? [Re: 2015_PSD]
Yes I did read that. But you still said "the Best" regardless. At any point anyone says something is "Best" is an opinion so you basically just repeated yourself.
There is no Ivory Tower, unless you placed me on one.
Maybe just say you like Amsoil, give it a try, rather than "IMHO ITS THE BEST" mmmmmm But thats just me.
Jeff
2013 VW GTI
#4573908 - 11/14/17 03:29 PM Re: Synthetic differential fluid - 2 questions? [Re: lawnguy]
oldhp Online   content
Loc: Southern Illinois
I just put Valvoline Synthetic( it says for limited slip on the bottle) 75W90 in my 2017 Jeep w/trac lock differential on a 1000 mile round trip. Rear diff is quiet as a church mouse.
2017 Jeep Unlimited 3.6/auto,wife's ride
2010 Ranger 2.3/auto,work truck
2016 Challenger R/T 6 speed,Toy
#4573920 - 11/14/17 03:38 PM Re: Synthetic differential fluid - 2 questions? [Re: lawnguy]
meep Offline
Loc: Southeast
From a "risk" standpoint, the LSD additive is the more important thing here. Not enough, or the wrong kind, and the clutches will wear prematurely.
I'm not sure of OEM/dealer fluids, but I find with every aftermarket diff goop in an LSD, the "includes Limitied slip Modifier" is never right. Usually not enough, even with amsoil. I use amsoil and find that their fluid, plus about 1/3 of a tube of their LSD modifier, is about right in my tundra.
We tow a TT on the interstate, and the diff gets plenty hot on hill climbs. I'm a fan for synth in the driveline.
-m
2006 Tundra 2wd
2015 crv (wifey!)
2009 s60 2.5T
#4573982 - 11/14/17 04:47 PM Re: Synthetic differential fluid - 2 questions? [Re: lawnguy]
bullwinkle Offline
Loc: Cincinnati, OH, USA
If you're going to work it, Royal Purple Severe Gear full syn gear oil is pretty hard to beat. Now if you're just putting around empty, just about any decent 75W140 with LSD additive would be more than enough.
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 15 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
#4573986 - 11/14/17 04:51 PM Re: Synthetic differential fluid - 2 questions? [Re: lawnguy]
dlundblad Offline
Loc: Midwest
Typically, store brand gear lube is good for topping off vehicles equipped with LSD. (ie a temporary fix meaning you're better to top off than burn up your diff.) That is it.. it's not replacement worthy. Someone please correct me if I am wrong.
M1 and Synpower will have your LSD additive. Synpower being somewhat cheaper. Both are exceptional products.
03 Jeep WJ 4.0 197k Castrol Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 170k M1 0w40 Mann HU818X
97 Chevy Blazer 4.3 138k Synpower 5w30 Fram TG3980
Page 1 of 2 1 2 >
