Does lots of starts let gas get in oil?
by tc1446
02/21/18 08:44 PM
Avalanche front and rear diff change.
by spasm3
02/21/18 08:40 PM
Abuse proof rental home flooring
by Oldtom
02/21/18 08:17 PM
Low Noise Oil
by Ducked
02/21/18 07:55 PM
2017 Dodge charger review
by gabriel9766
02/21/18 07:51 PM
Dry reusable air filters?
by WillB
02/21/18 07:42 PM
Batteries @ Menards
by Tdbo
02/21/18 07:29 PM
Blotter Spot Test
by Emanuel
02/21/18 07:22 PM
Is arming teachers the answer?
by ZZman
02/21/18 06:45 PM
Another ATF question... I aplogize
by bardos
02/21/18 06:12 PM
To Seafoam or Not?
by Marco620
02/21/18 06:07 PM
2017 Ford ecoBoost 1.5 Oil Filter Top View
by tenderloin
02/21/18 05:50 PM
Castrol Edge 0w40 Formulation Change
by Tmaslar
02/21/18 05:41 PM
Another Brake Fluid Flush Question
by artbuc
02/21/18 05:19 PM
Preventative Care ?
by maverickfhs
02/21/18 05:14 PM
my best deal ever
by 93cruiser
02/21/18 05:08 PM
Motorcraft fl1a cut open 3yrs oci
by rollinpete
02/21/18 04:05 PM
Slapped my FilterMag onto a Fram Ultra
by ZZman
02/21/18 03:59 PM
Toyota OEM Oil Filters: 5 for $15 or 10 for $30
by NYSteve
02/21/18 02:37 PM
Need Oil Change Advice
by Fulgore
02/21/18 12:51 PM
WiseOne, ryan6548, pjmbull, 92zx, Ara
64253 Registered Users
122 registered (AlaskaMike, 2003f7, 14Accent, 4WD, 2004tdigls, 901Memphis, 12 invisible), 1658 Guests and 97 Spiders online.
64253 Members
65 Forums
278514 Topics
Page 1 of 2 1 2 >
#4573651 - 11/14/17 10:08 AM sub-compact AWD vehicles HR-V C-HR CX3
2008wrx Offline
Loc: CA
Do all these new little AWD vehicles have tight tires (tolerance)? Like, we replace tires, it must be all 4 at the same time?
#4573666 - 11/14/17 10:26 AM Re: sub-compact AWD vehicles HR-V C-HR CX3 [Re: 2008wrx]
NormanBuntz Online   content
Loc: Outer Banks, NC
Unless you blow one, you shouldn't have to worry about it if you keep them rotated. No way a CX-3 or HR-V should be hard on tires.
"What is it, the first hole I dug?"
2017 Honda Odyssey SE
2013 Honda Accord LX
2007 Honda Ridgeline RTS
2007 Infiniti M35
#4573747 - 11/14/17 12:07 PM Re: sub-compact AWD vehicles HR-V C-HR CX3 [Re: 2008wrx]
gathermewool Online   content
Loc: New England
I don't know the exact setup of these two mico-CUVs, but here's how most great AWD systems tend to work, with my logic for saying that even tire wear all around would be important.
Front and rear are open differentials; however, stability and dynamic control (TCS and VDC, as an example) will not only cut power when wheel slip is detected, but selectively brake individual wheels that are sensed to be slipping. So, a minor difference in tire diameters likely won't have any affect, but mixing worn tires with new, left-to-right, might lower the marginbto when brakes are applied, potentially increasing wear. You'd have to research how their traction control scheme is setup.
The bigger concern, and likely more prevalent condition, is uneven wear, front-to-rear. In this case, and in very simple terms, when the center "differential" clutch engages to connect the front to rear, it will slip and increase wear if the front tires are spinning at a different rate than the rear tires. Luckily, the clutch likely doesn't engage unless front-to-rear slip is detected, at which point the clutch would be cycling to transfer power anyway.
So, differential tire wear would lower the margin to engagement of traction control, but how much wear would be induced at how much differential wear is hard to guess. The overall effect will likely be less than for a vehicle that had a true center differential or limited slip differential(s), but I wouldn't risk it; I'd ensure even tire wear and replace all tires if on or more needs to be replaced and the rest are worn significantly more.
14 Forester XT Touring w/ Eyesight (her)
Castrol Edge 0W-40 + Fram Ultra (FU) filter
15 Legacy Premium w/ Eyesight (me)
Edge 0W-20 + Subie blue filter
#4573760 - 11/14/17 12:24 PM Re: sub-compact AWD vehicles HR-V C-HR CX3 [Re: 2008wrx]
dlayman Offline
Loc: pennsylvania, usa
I know for sure that the CX3 has the tire equipment the OP is asking about, don't know on the Honda.
#4573781 - 11/14/17 12:52 PM Re: sub-compact AWD vehicles HR-V C-HR CX3 [Re: 2008wrx]
glock19 Offline
Loc: Virginia
Not sure about the specific models, but I believe AWD systems generally require the tires be within 2/32-4/32"
2017 GMC Sierra SLT Z71 Crew Cab - His
2016 Toyota Highlander Limited - Hers
#4573825 - 11/14/17 01:52 PM Re: sub-compact AWD vehicles HR-V C-HR CX3 [Re: 2008wrx]
JohnnyJohnson Online   content
Loc: Wet side WA
Another better idea to make you spend more money on your car.
2004 Toyota Corolla 117796
Out: QSUD 5W-30 Purolator One 5030 mile OIC
In: Valvoline Maxlife 5w-30 Fram TG4967 117530
2006 Duramax 73642
#4573875 - 11/14/17 02:58 PM Re: sub-compact AWD vehicles HR-V C-HR CX3 [Re: gathermewool]
Loc: New England
Originally Posted By: gathermewool
I don't know the exact setup of these two mico-CUVs, but here's how most **GENERIC** AWD systems tend to work, with my logic for saying that even tire wear all around would be important.
Auto-correct. Meant *generic* above
#4573889 - 11/14/17 03:13 PM Re: sub-compact AWD vehicles HR-V C-HR CX3 [Re: 2008wrx]
2008wrx Offline
Loc: CA
thanks for all the inputs... i can understand "got to pay to play" that's why our family is hesitated on these 3 models. we are kind of lazy; we have 2wd vehicles and we never rotate tire and we only buy 2 tires at a time LOL...
#4573959 - 11/14/17 04:19 PM Re: sub-compact AWD vehicles HR-V C-HR CX3 [Re: 2008wrx]
Loc: New England
Well, what do you need the AWD for? My very recently sold '08 Civic with Blizzaks was pretty darned good in the snow. A FWD vehicle with even more ground clearance would do pretty well in moderate snow/slush/ice. It will certain brake as well as any AWD vehicle.
#4574656 - 11/15/17 08:24 AM Re: sub-compact AWD vehicles HR-V C-HR CX3 [Re: 2008wrx]
Miller88 Online   content
Loc: Onondaga County
2WD with snow tires has never let me down in the snow!
In fact, I would have been perfectly happy if I could have got my Forester in either FWD or RWD.
18 Forester 2.5I 6M
00 Jeep Cherokee
01 Ford F-350 XL 4x4 5M
#4575108 - 11/15/17 03:10 PM Re: sub-compact AWD vehicles HR-V C-HR CX3 [Re: gathermewool]
UG_Passat Offline
Loc: NJ
Well what do you need AWD for? why didn't you get a FWD HR-V or CR-V when you sold the Civic?
#4575139 - 11/15/17 03:29 PM Re: sub-compact AWD vehicles HR-V C-HR CX3 [Re: UG_Passat]
Probably the same boat I was in. I didn't want AWD and I tried to avoid it. But the Forester was the only vehicle on the market that met all of my criteria. So that's what I got even though it was AWD.
18 Forester 2.5I 6M
00 Jeep Cherokee
#4575157 - 11/15/17 03:42 PM Re: sub-compact AWD vehicles HR-V C-HR CX3 [Re: 2008wrx]
nthach Offline
Loc: California
The HR-V should use Honda's Real-Time 4WD, which uses a simple PTO at the transaxle and a diff equipped with a dual oil pump mechanism along with a clutch in the back. Any differences between front and rear wheel speed will create a difference of oil flow between the 2 pumps which will engage the clutch to drive the rear wheels.
I'm not sure what Mazda uses, but seeing their past Ford/Volvo connection I wouldn't be surprised if it was an Haldex-based system.
I would try to keep the tires within 1/32-2/32" of each other and rotate religiously. I'm not sure if Honda or Mazda's system is as sensitive as Subaru or Audi, there have been reports of Toyota RAV4s with AWD trashing their PTOs due to sudden AWD engagement or tire size mismatch. It has happened on many Subarus with mismatched tires.
#4575266 - 11/15/17 05:23 PM Re: sub-compact AWD vehicles HR-V C-HR CX3 [Re: UG_Passat]
Loc: New England
I never liked the Civic - I'm 6' tall, 200# and the coupe was very uncomfortable to get in and out of. I did not intend to replace it so soon, but the '15 Legacy was being sold with just the right features and for a very good price. The owner was from North Carolina until this year, and had zero rust or corrosion anywhere.
AWD isn't necessary, but I like Subarus and their safety rating is top notch. It also came with the Eyesight package.
Finally, the Civic was great in snow for the vast majority of snow days, just as a midsize FWD sedan would be with snow tires. The stopping power was great. With that said, the tires still spun and traction was questionable at times when I was snowed in or while driving in deep, slushy stuff, where the AWD maintains a truer track. When it's really bad, like it was during last winter's one white-out-bad snow storm, I opted to take the Forester (also with Blizzaks) and was able to fully stop and then get going, whereas many people stopped and were then stuck. Not only was I able to get going in that nasty stuff, but I was able to do so safely - no perceptible wheel spin and no fish-tailing at all. It was actually pretty amazing.
Anyway, my question wasn't to convince the OP he didn't need AWD - it was to simply ask IF he needed it ever or just liked the idea of it. He's from CA, so unless he's doing some light off-roading, beach driving or taking weekend trips to the mountains, the need for AWD is all but nonexistent. I wouldn't purchase AWD just to get better going power in wet weather, personally.
#4575316 - 11/15/17 06:03 PM Re: sub-compact AWD vehicles HR-V C-HR CX3 [Re: 2008wrx]
nthach Offline
Loc: California
I'd get AWD to pass through chain control, but AWD is nothing without the right tires. A Subaru on winter tires is nearly invincible. However FWD does fine in the snow with winter tires but you'll still need chains if local rules require it.
Just don't be that guy thinking a BMW X5M can make it up Highway 50 towards Tahoe on Bridgestone Dueler Sport run-flats but had to pull over since they were losing traction fast. This was also during a winter storm alert, we happened to be the unlucky ones in a Forester with OEM Yokohamas behind it.
Top Gear thinks BMW's xDrive is worthless.
Page 1 of 2 1 2 >
