Originally Posted By: SubLGT
Originally Posted By: artbuc
...I can't assume crank bolt is torqued to factory specs. I am expecting it may be a bear to remove….Also, seems to be a lot of confusion about crank bolt torque. Some say 94, some say 130, some say oil threads, some say dry. Unfortunately, I do not have a FSM. Some of the confusion might be 2.2 vs 2.5 and/or SOHC vs DOHC. Anyone know for sure how to properly torque this crank bolt?
Thanks.
Based on the (poorly written) 2008 FSM:
Quote:
B: INSTALLATION
1) Install the crank pulley.
(1b) Clean the crankshaft thread using compressed air.
(2) Apply engine oil to the crank pulley bolt seat and thread.
(3) Tighten the bolts temporarily with tightening torque of 44 N·m (4.5 kgf-m, 32.5 ft-lb).
(4) Tighten the crank pulley bolt again, to 180 N·m (18.4 kgf-m, 132.8 ft-kb) while monitoring the tightening angle
5) Check that the tightening angle of the crank pulley bolt is 65° or more.
CAUTION:
If the tightening angle of crank pulley bolt is less than 65°, the bolt is damaged. In this case, the bolt must be replaced.
(1) Replace the crank pulley bolt and clean them.
(2) Clean the crankshaft thread using compressed air.
(3) Apply engine oil to the crank pulley bolt seat and thread.
(4) Tighten the bolts temporarily with tightening torque of 44 N·m (4.5 kgf-m, 32.5 ft-lb).
(5) Tighten the crank pulley bolts 65° to 75°.
NOTE:
Conduct the tightening procedures by confirming the turning angle of crank pulley bolt referring to the gauge indicated on timing belt cover.
IMO, it would be wise to buy a new crank pulley bolt.
Yes, I already told owner I am buying new bolt because I have no good way of knowing if existing bolt was torqued beyond yield. Rather spend a few bucks for a new bolt than screw around torquing bolt and then hoping angle is within spec.
