Originally Posted By: earlyre
Originally Posted By: 2012AccentSE
5k interval ok for mixing it and using it all?
it will be fine. they are designed to mix. i do this myself. keep an old 5qt jug around, and add the leftovers from oil changes (pint or less normally), and when it gets to 4.5 qts in the jug, Woohoo! "Free" oil change!
even sent the first such batch in for a UOA before running it.
they(blackstone) saw no issues with it.
Do you happen to have that UOA still?
umm somewhere... and clearly i meant VOA, since it was before running the oil...
here's the original thread.
https://bobistheoilguy.com/forums/ubbthr...mp;#Post3167824
looks like my pic version of it (in the thread) isn't working anymore, but the link to the pdf in the second post does.
As did I.
Because clearly you said "BEFORE RUNNING IT".
*I would say that oil did pretty good with a TBN of 8.4 considering it was nearly a 50/50 of 5w20 and 5w30.
