It's pointless to try to test the A/C in cool weather.
DoubleWasp points out that the computer senses the high side pressure and uses that as the trigger to clutch the fan up. You need to be watching the pressure with a gauge to be sure that is really happening.
It sounds like from previous tests, that really is happening and the fan isn't clutching up like it should.
If the weather is hot and the fan is really slow, eventually the compressor will start to cycle off/on on excess pressure and cooling in the cab will be diminished. If weather is cool you may get enough condenser cooling from the slow fan to cool the cabin, though pressure will be abnormally high.
If there is an official procedure to test the clutch by hotwiring it to confirm the fan speeds up, that is what should be done.
