DriveHard
Thread starter
Originally Posted By: Audios
Theres something going on with the fuel injection on that bank, possibly carbon buildup is starting to show its face. Ill bet if you can take a look at the back of the valves there will be buildup. The catalyst is an emissions component and should be covered under extended emissions warranty, in NJ its 8 or 9 years I think, so check the info for your state.
There is evidence that MB has solved the carbon issue by having the injection pulse while the intake valves are open and it actually sprays on the back of the open valves. There is no evidence of carbon problems on this engine that I have been able to find. Also, full throttle power is still great! It hasn't seem to lose any power through this whole thing.
