BG Engine Assurance: Someone talk me out of this
Originally Posted By: Shannow
Hi,
I'm seriously considering pulling the trigger on a BG Engine Assurance program for my RX8, obviously fitted with a Mazda Rotary Engine.
Could you please advise me as to what the coverage of your policy is with regard to these non typical engines, and are they covered similarly to their reciprocating counterparts ?
Thankyou for your time in advance.
xxxxxxxxxxxxx
Originally Posted By: BG
I hope the above coverage sheet helps you make your decision.
More information on the program and coverage is available at www.bgprod.com/ea
In other words won't answer the simplest of questions...
Yes your engine has a crankshaft, and I'd guess that would be about it...
Almost exactly the response I got.
Technically not even the crankshaft is a common part. The Wankel equivalent is an "eccentric shaft" (and some gears).
