Originally Posted By: aquariuscsm
How much different is the K24 in the Acuras that spec 5W30? Someone here had said it's a higher output version,but are the internals and construction the same basically?
2009 was the last year they spec'd 5W30. My 2010 calls for 5W20. It has had 5W30 in it most of its 185,000 miles.
They have a different cam, and higher compression as far as I know. Over 11:1 compression. Everything else is probably about the same.
