Originally Posted By: SilverFusion2010
It can be multi-grade. 5w-40 or 15w-50. 20W50 conventional will do fine if it is changed.
The short OCI isn't really that short. With the syn you can push it longer but there is no filtration on these small engines. Changing the oil is the only way to get the crud out.
Fuel dilution is the other problem. You really need to check and top off oil every time you fuel. Under max load they will start burning oil. They only have about a quart to begin with so it doesn't take long to get into trouble.
Break-in also matters. My brother has the 7kW predator generator. 420cc Chonda. Filled it with some M1 EP 10w-30 he had and proceeded to work the snot out of it. Changed the oil at 10 hours to get the sparkles out. That was some black nasty oil that came out. He has another 20hr on it now and the oil is a nice dark amber. That engine will run a long time because a little care was taken.
It can be any oil really as long as it is topped off. The heavier syn are going to burn off less and offer a bit more insurance.
Thanks.
Inventories are slim down here with all of the landscapers having stocked up and some small engine shops are still without power or phone.
I have a gallon jug of Conventional Delvac 1300 15w40 CK-4.
With frequent OCI do you think this would be fine? The HDEO qualities should assist with suspending particulates in the absence of an oil filter.
Originally Posted By: 4WD
My Delvac 1300 15w40 is 4.3 HTHS - 10.8 NOACK - 1300 calcium - 850 mag - 1017 phos - 1140 zinc and I need T6 why?
This is the same jug I have: https://mobildelvac.com/en/engine-oils/mobil-delvac/mobil-delvac-1300-super
Thanks.
