VOA Castrol Edge with Ti - 0w40 - SN - Euro Form
Originally Posted By: txchief
Thanks for the VOA. I found this article about Titanium Oxide function in motor oil:
http://www.sciencedirect.com/science/article/pii/S101836391600012X
Thanks for the article. The problem I see with this, is that the titanium(assuming it is titanium oxide in Castrol)is not anywhere near the level in Castrol, as it is in the tests. I guess it is better than nothing, but then you have to ask yourself if they lowered some other additive when they added titanium. The titanium would have to be in the 3000-5000 ppm range to match the test amounts.
