229.51
by RogerBacon
02/22/18 06:25 AM
One way to get the rust off under your vehicle...
by rollinpete
02/22/18 04:04 AM
Loud hum noise from front brakes
by Jimmy9190
02/21/18 10:47 PM
Rat: Trap or Poison
by WhyMe
02/21/18 10:27 PM
STIHL Hp ultra fail??? Or my fault???
by Matt2stroke
02/21/18 09:42 PM
Wrestling pretzel hold. Ouch!
by callbay
02/21/18 09:41 PM
Serpentine Belt noise
by Tdbo
02/21/18 09:31 PM
Coolant Leak
by Ducked
02/21/18 09:13 PM
Does lots of starts let gas get in oil?
by tc1446
02/21/18 08:44 PM
Avalanche front and rear diff change.
by spasm3
02/21/18 08:40 PM
Abuse proof rental home flooring
by Oldtom
02/21/18 08:17 PM
Low Noise Oil
by Ducked
02/21/18 07:55 PM
2017 Dodge charger review
by gabriel9766
02/21/18 07:51 PM
Dry reusable air filters?
by WillB
02/21/18 07:42 PM
Batteries @ Menards
by Tdbo
02/21/18 07:29 PM
Blotter Spot Test
by Emanuel
02/21/18 07:22 PM
Is arming teachers the answer?
by ZZman
02/21/18 06:45 PM
Another ATF question... I aplogize
by bardos
02/21/18 06:12 PM
To Seafoam or Not?
by Marco620
02/21/18 06:07 PM
2017 Ford ecoBoost 1.5 Oil Filter Top View
by tenderloin
02/21/18 05:50 PM
WiseOne, ryan6548, pjmbull, 92zx, Ara
64253 Registered Users
57 registered (aquariuscsm, Armkb, 2015_PSD, 4WD, alarmguy, 4 invisible), 1078 Guests and 101 Spiders online.
64253 Members
65 Forums
278522 Topics
Page 1 of 2 1 2 >
#4525263 - 09/24/17 09:34 PM Corrosion Test
buck91 Offline
Loc: West Michigan
So in the spirit of DIY Guy's gun oil test, I'm doing a little mini at-home corrosion prevention test of a couple of garage lubes I had laying around. Unfortunately I did not have room for everything I wanted to test, but many of them HAVE been tested. My goal was to provide a little home comparison information for my own decisions. As such, THIS TEST WILL NOT STAND UP TO RIGOROUS SCRUTINY. Please feel free to enjoy any results but it is nothing more than a quick, diy, at home comparison.
To begin with I took a used front brake rotor (Ford OE part, possibly 80k miles but remarkably little wear), sanded it down by hand with some coarse wet/dry paper and cleaned it off real good with non-chlorinated brake cleaner. There are a few dents and divots which aren't perfect but overall it should do well for this test. I then divided it into eight parts to test the following (In clockwise fashion from the top):
1. PP 5w30
2. Chevron Supreme 10w30
3. Kano Microil
4. Tri-Flow Superior Lubricant, drip bottle
5. Boeshield T9, drip
6. Fluid Film, non-aersol
7. Fluid Film, aerosol
8. Mobil 1 ATF
Added:
9. Super-Lube Silicone Oil, small area on rotor hat
10. Control, the rest of the rotor hat (which was sanded and prepped along with the braking surface)
All samples were applied in the same fashion, by wetting a piece of blue shop towel and "buffing" onto the rotor surface. No further treat was done (no wipe off, no heat treat, ect). I would say that the "buffing" on didn't seem to leave a very heavy coating but felt analogous to how I would wipe down any gun part which didn't specify a "run wet" type of condition (i.e. my glock rails have more oil but my shotgun receiver has about this amount).
At this point in the test, the samples are sitting in a non-climate controlled garage in 90+F daily high temps and high humidity. I have seen tools rust in a few weeks if not wiped down. Unsure the "best" way to progress from here. A good long term test would be to just leave the rotor unmolested for a few months and see what holds up best. This would be a great test for storage applications. Alternatively, I could move it outside into any type of spot ranging from primarily sunny (weather permitting) to shady and damp. It is currently early fall in Michigan, so the weather will be (or should be) rapidly cooling and becoming wetter. Open to input. Pics below.
2011 F150 4x4 5.0L
1996 Mustang GT 5spd/ragtop
#4525265 - 09/24/17 09:36 PM Re: Corrosion Test [Re: buck91]
buck91 Offline
Loc: West Michigan
Pics of initial setup. Remember this is pretty informal.
2011 F150 4x4 5.0L
#4525288 - 09/24/17 10:08 PM Re: Corrosion Test [Re: buck91]
SOHCman Offline
Loc: USA
cool, looking forward to results!
"R&D costs money. Consumers complain for free."
-Greasymechtech
#4525312 - 09/24/17 10:34 PM Re: Corrosion Test [Re: buck91]
SuperDave456 Offline
Loc: Dallas, Texas
Sounds like a cool test.
I guess you now get to take 1 pic a month.
Then at the end of 6-12 months you get to do a lot of detailed pics and write up.
If you are really bored you can go longer than 12 months.
#4525315 - 09/24/17 10:38 PM Re: Corrosion Test [Re: buck91]
JHZR2 Offline
Loc: New Jersey
Will you keep the blue tape on to try to prevent one section from segregating into another?
#4525636 - 09/25/17 10:16 AM Re: Corrosion Test [Re: JHZR2]
Kira Online   content
Loc: Champlain/Hudson Valley
Looking forward to the "results" too.
Upon rotating my wheels for the first time I was amazed how much white crud there was.
I used a wire wheel to decrud where rotor and alloy wheel touched.
I carefully sprayed the rotor-to-wheel mating surfaces with 5-56 in order to stave off such corrosion.
I'll tell you how that works when next I rotate.
#4525709 - 09/25/17 11:55 AM Re: Corrosion Test [Re: buck91]
Rolla07 Offline
Loc: MTL, CANADA
Outside in winter will be a test id like to see!
2007 Corolla Red Pearl 151k miles
Castrol Magnatec 0w20 & Napa Proselect
#4525844 - 09/25/17 02:21 PM Re: Corrosion Test [Re: buck91]
billt460 Offline
Loc: Glendale, Arizona
Brake rotors are a good test medium. They really LIKE TO RUST! When I wash my vehicles, by the time I get them dried off, the rotors are covered with a nice light coat of rust. Just from sitting there for 15 minutes after rinsing the wheels. I swear, you can actually watch them rust, sitting in the driveway. I've never seen anything made from metal rust so fast in my life!
#4525877 - 09/25/17 02:53 PM Re: Corrosion Test [Re: buck91]
Linctex Offline
Loc: Waco, TX
Use a misting bottle to apply uniform, light moisture occasionally.
#4525892 - 09/25/17 03:06 PM Re: Corrosion Test [Re: billt460]
Kamele0N Offline
Loc: Slovenia
Next time when you will buy new discs...try to buy OEM/quality ones...
ATE Pagid etc tend to rust less then cheapo no name ones wink
2011 Hyundai i30 1.4 CVVT Shell Helix Ultra 5w40
1997 Toyota Landcruiser KZJ95 3.0 TD various 10w40
#4525921 - 09/25/17 03:37 PM Re: Corrosion Test [Re: Kamele0N]
billt460 Offline
All of my rotors ARE OEM. I've never changed them. They came with the vehicle.
#4526316 - 09/26/17 12:36 AM Re: Corrosion Test [Re: buck91]
Popsy Offline
Loc: Frogland / Brittany
I only buy corrosion resistant rotors when possible (generally not available for rear rotors unfortunately). I put ATE Powerdiscs on my old Fiat, they aren't rusting, and they somewhat improved the feeling when braking smile
96 Barchetta, Motul 300V 5W40 | 98 Barchetta, SHU 0W40
05 Forfour 95, SHU 0W40 (gf's car) | 10 Colt Ralliart, Syntium 7000 0W40
#4526816 - 09/26/17 02:59 PM Re: Corrosion Test [Re: buck91]
AMC Offline
Loc: South Eastern, CT
Cool test!
Here are the results: 1st place: Boeshield
2nd place: Fluid film liquid
3rd place: fluid film aerosol
4th place: Tri-flow
grin2
11 Chevy Silverado - PP 5w-30
10 Ford Focus - QSAD 5w-20
14 Yamaha Super Tenere - Delo 15w-40
#4526818 - 09/26/17 03:02 PM Re: Corrosion Test [Re: AMC]
SatinSilver Offline
Loc: OH
Any pictures please??? Thank you.
2012 Toyota Camry 71k-PUP 5w20,OEM filter, RT43s.
2005 Toyota Matrix 135k miles - VWB 5w30 conv, Valvoline oil filter. Nokian eNTYRES.
#4526820 - 09/26/17 03:03 PM Re: Corrosion Test [Re: buck91]
billt460 Offline
Here ya' go. One of the best....... WD-40.
http://www.brownells.com/.aspx/lid=10700...t-Preventatives
Page 1 of 2 1 2 >
